Author Topic: 650 or 550 cam chain tensioner  (Read 536 times)
Offline eigenvector
« on: August 09, 2014, 11:37:45 AM »
In my quest to find a new/used cam chain tensioner for my CB550, I ran across a CB650 version.  It was practically unused and to all appearances looked identical except for the means of keeping the tensioner - tensed.
My question, which actually does a better job?  I notice that while the CB650 tensioner looks the same, it isn't.  The tensioner bolt is about 1mm away from where it should line up  :'(.  However that really doesn't present a challenge if a need to retrofit arises.
Ultimately my question is which tensioner actually generally works better?  The one for the CB650 has a very simple mechanism, whereas the one for the CB550 has that funky gear system that really doesn't work all that well (in my experience).
Rob
2018 HD Softail Heritage
1979 CB750K Limited Edition
1977 CB550K
1984 CB700SC Nighthawk
1983 VF750S Sabre
