Author Topic: Kicker oil seal keeps popping out - CB350 twin  (Read 1713 times)
Offline Tugboat
  • Puppet
    • PseudoMoto
« on: August 11, 2014, 01:40:27 PM »
Weirdest thing: the Kicker oil seal on the CB350 keeps popping out after I ride around a bit. As far as I know there shouldn't be any pressure there, since the bottom end is open to atmosphere via the cam chain tunnel & the vent at the top. I've got a new seal to replace the old one with - just wondering if anybody had a clue as to why it's getting pushed out in the first place.
« Last Edit: October 02, 2014, 10:09:23 AM by Tugboat »
Re: Shifter oil seal keeps popping out - CB350 twin
« Reply #1 on: August 11, 2014, 09:56:05 PM »
Has an insect built a nest inside the vent tube, blocking it?
Offline MoMo
  • Ride like you're invisible
« Reply #2 on: August 12, 2014, 07:24:56 AM »
that is a possibility.   I had the same problem with a 350 twin, used Gasgacinch around the perimeter and seated the seal deeper than flush with the case.  No problem since, bike was sold and then resold and driven from Philly to NY....Larry
Offline faux fiddy
  • bike in a box
« Reply #3 on: August 14, 2014, 03:03:20 AM »
My 450 has done that. If it becomes a problem I was told you can tap on the opening and close it up a bit, or use an adhesive or both.
^^^^^^^/l^^^^^^^^^^^^^^/l^^^
Offline Tugboat
  • Puppet
    • PseudoMoto
Re: Kicker oil seal keeps popping out - CB350 twin
« Reply #4 on: October 02, 2014, 10:12:23 AM »
Just to follow up here:
I cleaned it up really well and installed the new seal. Rode around for about 5 minutes and it was good. Another 5 minutes and it had popped out again! I can remove the oil dipstick and blow into the vent tube and it passes air, so I know that's not clogged.
Well, after talking with some guys at the shop I removed the seal, cleaned out the orifice really well, lightly smeared some Hondabond onto the seal and pushed it back in. Let it sit to cure and rode it a couple of days later. So far, so good - the seal is staying in place after a good half-hour of riding.
