Author Topic: Oil Light  (Read 533 times)
Offline steve
Oil Light
« on: August 11, 2014, 07:25:20 PM »
My oil light will not go off on a 1976 CB550.  There is oil pressure and I have switched out the pressure switch.  There is power at the sensor connection/should there be?
Offline tlbranth
Re: Oil Light
« Reply #1 on: August 11, 2014, 07:46:04 PM »
Pretty sure the switch is in series with the light with +12v going to the non-switch side of the light. So if you disconnect the switch, the light should be out. If you jump the connector to ground, the light should go on. If these things are true then the switch is bad, the switch doesn't see the oil pressure (clogged line), or you have no oil pressure.
Don't own a Vanagon
Don't work at Boeing
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
Re: Oil Light
« Reply #2 on: August 12, 2014, 03:08:00 AM »
Exactly, the pressure switch grounds the light when there is no oil pressure to keep it open.
