Author Topic: How do I support the bike so I can remove front wheel/forks?  (Read 5055 times)
Offline jmelche2
  • 1974 CB750K
« on: August 12, 2014, 05:34:24 AM »
1972 CB500.  Not sure of the proper way to support the bike while on the center stand so that I can remove the front wheel.
Re: How do I support the bike so I can remove front wheel/forks?
« Reply #1 on: August 12, 2014, 05:38:57 AM »
I use a small scissor or bottle jack with a block if wood under the front of the engine. A two by four wedged up under the frame can work also. Balance, at least on the 750's is pretty good on the center stand.
« Last Edit: August 12, 2014, 07:29:09 AM by ekpent »
Offline calj737
  • I refuse...
« Reply #2 on: August 12, 2014, 05:42:19 AM »
With bike on center stand, weight rear of seat forcing bike onto rear tire. Wedge a 2x4 of wood under steering neck from below, this will give you enough room to loosen the axle clamps, slide axle out, drop wheel, and roll forward to service. You only need to clear the clamp studs anyway.
« Reply #3 on: August 12, 2014, 05:59:01 AM »
I use a ratchet strap attached to the ceiling rafters to lift the whole front end off the ground.
Works great and no chance that the bike will fall off a jack.
Offline wowbagger
  • Not much of an
« Reply #4 on: August 12, 2014, 07:01:05 AM »
+1 Just make sure the anchor in the ceiling that you hang it off of is structural.
Offline Adam_F
« Reply #5 on: August 12, 2014, 08:32:15 AM »
Its definitely worth it to buy a lift.  I found a decent (craftsman/sears) one on sale for less than $200.  Rolls right under the bike and lifts the entire thing off the ground.  Comes in really handy if you plan on doing a lot of your own work or just need to remove both wheels at once.
'77 cb550F
Offline Lostboy Steve
« Reply #6 on: August 12, 2014, 08:48:23 AM »
+2 Thats what i did as well.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
Offline Schnell
« Reply #7 on: August 12, 2014, 08:52:08 AM »
I have a lift but the exhaust pipes are in the way.
I have a 2x4 cut to the right length to prop up the front end. On the 750 there is a short horizontal frame member between the 2 down tubes that is a perfect prop point.  Or you could suspend the front end with a strap from the ceiling. Both solutions with the bike on its center stand.
I got a shock when I removed the caps at the top of the fork tubes the first time, and the bikes front collapsed with the front coil springs coming out the top! This is because on my other bikes (BMW) on their center stand, the front wheel is off the ground.
primary: 1974 Honda CB750
project: 1971 Honda CL350
project: 1974 Honda CB450
previous:
1975 Honda CB750
1973 BMW R90/6
1981 Suzuki GS650
1973 Honda CD175
Offline lrutt
« Reply #8 on: August 12, 2014, 09:10:26 AM »
I have 2 lifts which work great on the 750 as they are pretty flat on the bottom. HF has some pretty good deals on them.
If not, then center stand and jack under front motor mount.
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #9 on: August 12, 2014, 09:34:21 AM »
This is what someone on another forum I frequent has built, which I also plan to build after my deck. For quick checks I put my car jack onto the oil filter cover because I have a 4-1 exhaust, but usually only just to check if front wheel is spinning freely when adjusting front brake... Anything long-term I have used a strap from my father-in-law's ceiling.
« Last Edit: August 12, 2014, 09:38:06 AM by evanphi »
--Evan
1975 CB750K "Rhonda"
Offline Bankerdanny
  • Endeavor to persevere
« Reply #10 on: August 12, 2014, 09:53:51 AM »
That's pretty ingeniou. That would work fine with my 550, but my GoldWing was really hard to get on the stand from flat ground I don't think I could have hoisted it up on a 2" board without a crane.
Offline Tews19
  • I am no
« Reply #11 on: August 12, 2014, 10:55:09 AM »
I've done this method for a few yrs.31 inches
1970 Honda CB750 survivor.
« Reply #12 on: August 12, 2014, 11:12:50 AM »
+3
I used two straps anchored about 3' apart @ the ceiling.  helps it not swing.
Offline eigenvector
« Reply #13 on: August 12, 2014, 11:30:46 AM »
+3
+4 Exactly right.  Each tie strap goes to its own rafter.
The bike is trivially light, so there's no concern over breaking the rafters.
Rob
2018 HD Softail Heritage
1979 CB750K Limited Edition
1977 CB550K
1984 CB700SC Nighthawk
1983 VF750S Sabre
Offline Deltarider
« Reply #14 on: August 12, 2014, 01:47:37 PM »
Gosh... after reading all the above I'm afraid the way I do it is maybe too simple.
1. Bike is on the center stand.
2. I prepare by positioning a block of wood* of the right height in front of the engine.
3. I grab the frontfender and lift the front of the bike till the rearwheel hits the floor.
4. Then with one foot I shove the block of wood under the oilpan till it won't go any further.
5. Bike rests solid on block of wood and front wheel and/or front legs can be removed.
Actually I use an old car battery with a wooden block on top.
« Last Edit: August 12, 2014, 01:50:02 PM by Deltarider »
CB500K2-ED Excel black
« Reply #15 on: August 12, 2014, 04:18:03 PM »
I use a chain hoist from above with a nylon strap. Around the handlebars keeps the forks aimed straight too.
