Author Topic: Maxim Carbs  (Read 1349 times)
Offline M@gneto
Maxim Carbs
« on: August 13, 2014, 04:34:27 PM »
Has anyone actually used the Maxim CV carbs? I remember reading about it somewhere, so if I remember correctly, I need the boots for a CB750K and probably the airbox. What about the throttle cables. Will the ones I have work or will I need something different?
Offline POPS 911
Re: Maxim Carbs
« Reply #1 on: August 22, 2014, 04:37:00 AM »
XJ750R SECA carbs work same way as your Maxmin maybe smaller = make a bracket for one cable pull. Air box ????? I run pods. Can buy a kit on e-bay for jets to boost the flow, you can call those folks and tell them what you have and they can make you a kit for carbs and pipe or pipes.
