Author Topic: Cb750k2 ngk dr8es-l, are these ok or to long?  (Read 1444 times)
Offline ncstatecamp
« on: August 15, 2014, 01:07:22 PM »
I'm trying to figure out a starting/running issue and am putting in new plugs. I'm getting mixed signals and references on what will fit and would like to make sure these aren't to long.
Re: Cb750k2 ngk dr8es-l, are these ok or to long?
« Reply #1 on: August 15, 2014, 01:18:07 PM »
NGK D8EA
Offline ncstatecamp
« Reply #2 on: August 15, 2014, 01:30:06 PM »
I got that, but I saw somewhere on this forum that the -l was recommended for certain bikes but was discontinued or something
« Reply #3 on: August 15, 2014, 02:00:49 PM »
the proper plugs are D8EA or denso X24ES-U
DR8ES-L
D=12mm
R = Resistor type  (you'll need different plug caps)
8=heart rating
E=19mm thread reach
S= standard 2.5mm electrode
-L =medium heat rating.
not the same plug, but the same thread reach...
Online 70CB750
« Reply #4 on: August 15, 2014, 02:28:45 PM »
I run D7s. First I had them for winter, but they work so well that I keep them year around.
« Reply #5 on: August 15, 2014, 02:33:30 PM »
Here is a good thread about NGK DR8ES-L and the other plugs as well. http://forums.sohc4.net/index.php?topic=77832.0
No problem to use NGK DR8ES-L in a CB750. I used that plug during the 80's and this year too.
I bought several sets of them all:  NGK D8EA, NGK DR8ES-L and Denso X24ES-U.
Lucky for me that I bought several sets when I had carb tuning issues fouling plugs after plugs......
Offline ncstatecamp
« Reply #6 on: August 15, 2014, 03:01:31 PM »
Well I also just moved to the Chicago area, from the south so I'm trying to figure out what I'll need different in regards to weather and traffic
