Author Topic: 520 spockets for CB500/550  (Read 1523 times)
Offline TerryK
« on: August 15, 2014, 01:28:50 PM »
Anyone have a source for 520 conversion sprockets for the 500/550s?
Offline TerryK
Re: 520 spockets for CB500/550
« Reply #1 on: August 15, 2014, 09:39:02 PM »
Anyone?
Offline DavePhipps
  • Reading the entire Hi-Perf forum
    • Hillside Technology
« Reply #2 on: August 15, 2014, 09:40:49 PM »
Sprocket specialist can make them.
http://sprocketspecialists.com/
Bikes:
90 FZR600 RA
74 CB550k
78 GL1000
72 CB500K
« Reply #3 on: August 15, 2014, 09:47:09 PM »
Rears can be thinned on a lathe.
Fronts are tougher, can be turned, but they are fairly hard.
 Could he ground by handheld grinder if you do one side at a time.
 However, buy the front if you can, i suspect some fronts may be softer than original , after you remove required amount..
Offline TerryK
« Reply #4 on: August 17, 2014, 08:56:30 AM »
Yeah I know about SS, was just wondering if anyone made an affordable kit. Thanks.
Offline xtravbx
« Reply #5 on: September 02, 2014, 08:15:41 PM »
To the top. I'd love to know as well.
Cycle Xchange shows out of stock..
Offline xtravbx
« Reply #6 on: April 12, 2015, 08:02:31 PM »
Still hunting for these!!
Offline FunJimmy
  • Who you calling
  • Vancouver
Offline trueblue
« Reply #8 on: April 13, 2015, 03:42:34 AM »
I think some of the XR series hondas had a 520 sprocket that will fit the front of the 500/550.  If it isn't an XR then it is definately a Honda dirtbike, it has been a little while. ;D
1979 CB650Z
Offline Oldtech
  • Motorcycle tech: old, cranky and retired
« Reply #9 on: April 13, 2015, 04:53:15 AM »
My 83 XL600R uses the same countershaft sprocket in a 520 as my 74 CB550 as well as my CB350 and CB450 vintage racers. I have a complete set of 520 sprockets, front and rear, for both racers from Sprocket Specialists.
Offline Zora
« Reply #10 on: April 13, 2015, 01:04:14 PM »
I'm going through this same process. I bought a 520 front sprocket from Sprocket Specialists, part # 5033-17. I couldn't find a 520 steel rear sprocket anywhere, only expensive aluminum ones that probably wear quickly. So I ordered a steel 530 rear sprocket from JT Sprockets and will get it machined down to the correct thickness.
'77 CB550F - Finally on the road...
'78 CB550K - not running yet...
'06 YZ450F
'01 KLX300
Offline xtravbx
« Reply #11 on: April 14, 2015, 07:52:00 PM »
I think that's the route I will be going. I can't find the rear, even the aluminum ones. Ive found the fronts from a few sources. What's the point in only selling the front??
Offline mrfish2
  • I might be a
« Reply #12 on: April 14, 2015, 09:18:29 PM »
What's wrong with getting a 530 sprocket? Not trying to start a fire here, just wondering what yall are trying to save by converting to the harder to find 520 size when the 530 size is readily available.
1976 CB550K            1979 XS1100
1980 CB650C - Sold
It's a little motor and likes having the tits revved off it.
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #13 on: April 14, 2015, 09:40:58 PM »
Can't run 530 o-ring or x-ring without risk of damaging the cases.
520 is narrower and the o-ring/x-ring version is case safe.
Offline mrfish2
  • I might be a
« Reply #14 on: April 15, 2015, 12:03:00 AM »
Ohh, yeah I forgot about the 520 o-ring chains. It makes sense, but so why not just buy a standard 530 roller chain? Sure it may not last as long as an o-ring chain, but we're only talking a few hundred miles here, and the standard chains are cheaper too.
1980 CB650C - Sold
Offline trueblue
« Reply #15 on: April 15, 2015, 03:31:22 AM »
Not only a few hundred miles, my 650 had a factory o-ring chain, I have fitted it with an x-ring, and it goes about 5000 miles between needing adjusting.  With only a squirt of lube every week or so when I'm using it heavily.  I would like to see a standard chain come anywhere close to that.  ;D
1979 CB650Z
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #16 on: April 15, 2015, 04:14:05 AM »
Well that's because you're using synthetic oil in the engine. Synthetic engine oil will make that standard chains last forever too. Even in dusty conditions.  ;D
Offline trueblue
« Reply #17 on: April 15, 2015, 04:27:32 AM »
I started out using synthetic oil, made the popcorn taste like #$%* ;D
1979 CB650Z
