Author Topic: Barrel seal differences help please...  (Read 1051 times)
Offline Paul Lowe
  • If you like then it is good...
« on: August 16, 2014, 10:35:12 PM »
Am rebuilding what is a K1 as per engine numbers. The old barrel was poor so bought a low miles K0 barrel and pistons (so I was told).
Looking at manual and parts book it say K2 had metal pins and seal in between barrel and head for inner head bolt locations.
Both the heads I have show a place for these steel pins and my gasket kit (generic ) has little rubber tube type seals.
Based on pics can someone confirm K0 K1 barrels had these type holes or have I got K2?
Depending on answer do I need to worry about having these or just the two o-rings on centre rear stud?
Confused
My Honda sickness deepens
CB350F 1972
CB360G 1974
CB750 K1 1971
CT90 K0 1968
C102 1963
C50 1968
C70 1972
C90 1974
CL90 1968
1/2HP electric bike home made...
Offline bjbuchanan
Re: Barrel seal differences help please...
« Reply #1 on: August 17, 2014, 12:21:35 PM »
You use just o-rings on the inner parts of the head. The longer tube type seals come in later models to help try to kill the head gasket leaks. They have way more dowels and make a lot more sense as to where the tubes go.
Offline Kevin D
  • SE Michigan
« Reply #2 on: August 17, 2014, 01:16:12 PM »
Service bulletin #42 describes the leak problem and the differences between the early and late cylinders. I tried to get the service parts offered for my flat decked cylinder but was told they are no longer available.
http://manuals.sohc4.net/CB750SB/750_42.pdf
Your photo shows a K2 or later cylinder, with counter bored stud holes.
71 CB750 K1
108,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
Offline Paul Lowe
« Reply #3 on: August 17, 2014, 02:47:09 PM »
Thanks for responses.
Hmm was assured the barrel was K0!
Since it has the dowel holes bored can/should I use them to help prevent leaks?  Is the head different between K0/1 and K2?
Don't want to remove engine again later but also won't be doing a lot if miles in it.
CB350F 1972
CB360G 1974
CB750 K1 1971
CT90 K0 1968
C102 1963
C50 1968
C70 1972
C90 1974
CL90 1968
Offline bjbuchanan
« Reply #4 on: August 18, 2014, 07:32:08 AM »
You can choose, if you don't run the tubes it is no biggie. The important one is the two prongs at the back. There is debate as to whether or not the tubes rly did anything
« Reply #5 on: August 18, 2014, 08:01:29 AM »
I omitted the barrels.  No leaks so far.
Offline Paul Lowe
« Reply #6 on: August 18, 2014, 06:23:58 PM »
Thanks so far. I figure the two input seals are high pressure and most critical where the return paths are low pressure. Thoughts?
Can anyone show pic of K1/2 barrel to show difference in this part?
Great to have such help when I'm in the shed scratching my head!
CB350F 1972
CB360G 1974
CB750 K1 1971
CT90 K0 1968
C102 1963
C50 1968
C70 1972
C90 1974
CL90 1968
Offline Kevin D
  • SE Michigan
« Reply #7 on: August 19, 2014, 03:42:57 AM »
That's correct. Pump pressure at two rear center, gravity return to crankcase at 8 studs with/without tube seals.
Have you visited the manuals section? Check the lube flow diagram there. Sorry I dont have pics, hard drive crash.
http://www.sohc4.net/cb750k-manuals/
« Last Edit: August 19, 2014, 11:20:38 AM by Kevin D »
71 CB750 K1
108,000 miles
Original Owner
———past———
70 SL100/125/150
