Author Topic: 1980 750 Carbs on a 72 Motor  (Read 1024 times)
cfocats
« on: September 26, 2006, 04:01:54 pm »
I have a 72 motor in my chopper frame, clearance and cabling is not an issue, will the carbs fit my intake boots? and is this a good idea, or a really stupid one?
Offline cb650
Re: 1980 750 Carbs on a 72 Motor
« Reply #1 on: September 26, 2006, 05:11:21 pm »
80 750 carbs are cv's so I dont think so.
                         Terry
Offline batdan
« Reply #2 on: September 27, 2006, 11:45:45 am »
What exactly is the reason newer CV carbs couldn't work an old sohc?
Honda CBer
« Reply #3 on: September 27, 2006, 12:20:50 pm »
i imagine that they could be made to work, but why? you may have to futz with the rubbers (or make your own from radiator hose), as i am pretty sure that the intake spacing is incorrect... it is a fact that DOHC exhausts are not interchangeable with SOHC for this very reason...
Offline cb650
« Reply #4 on: September 27, 2006, 01:00:31 pm »
Spacing is diff.   At least when the 650 changed it did.
                   Terry
Offline Geeto67
  • A grumpy
« Reply #5 on: September 27, 2006, 04:40:09 pm »
in general try to avoid the DOHC cb750/900/1100 carbs whenever possible. They aren't even good on the bikes they were designed for (CR flatslides are popular replacement).
As a general rule constant velocity carbs don't give good throttle response and are difficult to tune on engines they were not designed for.
Maintenance Matters Most
