Author Topic: CB125S Fuel Mixture Issue?  (Read 1835 times)
Offline Connor
« on: August 19, 2014, 07:42:54 AM »
My CB125S was running fine for many weeks this summer until I took a ride with someone on the back a few weeks ago. It wasn't the first time I'd done that, but this time, it seemed to be having trouble accelerating. The problem got worse over the course  of the 20-minute ride and eventually the bike died just as I was getting home.
I let it rest overnight and tried to start it up the next morning. I usually engage the choke fully just to start the bike then flick it off to let it warm up a bit. I barely need the choke when it’s at its hottest outside but it usually helps to get the bike started on one kick. When I tried to start the bike that next morning, it wouldn't turn over with the choke on. I kicked it ten or fifteen times with the choke off and got it to start. It idled a bit but bogged and died as soon as I twisted the throttle.
I thought that it might be an air issue, like a clog in the intake, so I removed the intake hose (and noticed while I was doing this that the hose clamp holding the hose onto the carburetor had broken, but the hose seemed to be firmly attached). With the hose disconnected and the carb exposed to open air, I was able to get the bike to run noticeably better than before. I could give it throttle without it dying, at least. I still couldn't really get it to move forward without it stalling out.
Seemed like an obvious mixture issue so I tried adjusting the screw but didn't really see any change either way. I turned it up to a full turn in either direction, ⅛ twist at a time.
I pulled the plug and it was completely black and sooty, which I've read is the hallmark of a rich mixture.
The fuel is brand new and the battery is fully charged.
My question is twofold: How should I proceed in troubleshooting this issue? And what could have caused such a rapid deterioration (over the course of one 20-minute ride)?
Offline Coyote13
Re: CB125S Fuel Mixture Issue?
« Reply #1 on: August 19, 2014, 07:48:37 AM »
How does your air filter look?
'78 CB750K.  Throttle ripper.
'71 CB100.  Grocery getter.
'01 XL883.  Panty dropper. Gone but not forgotten.
Offline grcamna2
« Reply #2 on: August 19, 2014, 07:54:15 AM »
Have you pulled the carb.?
75' CB400F/'bunch o' parts'
Offline Connor
« Reply #3 on: August 19, 2014, 08:10:55 AM »
The air filter looks pristine, actually.
I should add that this bike has less than 1000 miles on it.
Offline Connor
« Reply #4 on: August 19, 2014, 08:23:37 AM »
I haven't yet. Do you recommend that I do that? Do you think something could have gotten in there through the loose hose and caused such a drastic change?
Offline grcamna2
« Reply #5 on: August 19, 2014, 08:57:53 AM »
I think you could have something inside your tank that might have clogged the jet's,etc.,it's what I would check first.
Offline Connor
« Reply #6 on: August 20, 2014, 05:38:30 PM »
Alright then!
Took apart the carburetor and found the pilot jet tube sitting at the bottom of the float bowl. It must have unscrewed itself somehow. Easy fix! As a bonus - there wasn't a speck of dirt inside the carburetor.
Thanks all.
Offline grcamna2
« Reply #7 on: August 26, 2014, 10:43:12 AM »
Nice fix Connor  ;D ,it'd be good if more of the probs. were that straightforward.
