Author Topic: Metal Pieces In Oil  (Read 4110 times)
Offline DaveBarbier
Metal Pieces In Oil
« on: August 22, 2014, 05:05:18 AM »
So I did an oil change and in the plastic drain pan I used I saw these metal pieces. It's like they're strips of metal (ferrous) and they're rolled and bent up. I only found these two but there could have been more.
Bike hasn't been run in about 2 months but before that...well it wasn't running great then either but it seemed like it was carb issues. The engine seemed strong and well running.
1978 Honda CB550K
Offline Vinhead1957
Re: Metal Pieces In Oil
« Reply #1 on: August 22, 2014, 05:26:35 AM »
I'm thinking cam chain tensioner. You can inspect from below
Offline DaveBarbier
« Reply #2 on: August 22, 2014, 05:49:55 AM »
You mean drop the oil pan? I was hoping you'd say not to worry about it, haha.
1978 Honda CB550K
Offline trueblue
« Reply #3 on: August 22, 2014, 05:57:14 AM »
It's a little hard to tell on my phone but they look a little like retainers from a ball bearing. I would definitely go on the hunt for more.
1979 CB650Z
« Reply #4 on: August 22, 2014, 06:03:18 AM »
1978 Honda CB550K
Yeah, if those are steel bits, it doesn't look good to me.  Even if you drop the oil pan and find the source, or more of the same, you've still got to fix it. Cam chain tensioner or a bearing.
Could they have been in the drainpan from some other source, like your lawnmower or such? OR was the pan clean when you started.
« Reply #5 on: August 22, 2014, 06:09:42 AM »
Do you know if the previous owner had done any major repairs/top end rebuilds, engine torn down etc before you got it. Stuff can fall in or junk from an earlier fix.  Not fun finding stuff like that though.
Offline DaveBarbier
« Reply #6 on: August 22, 2014, 06:25:55 AM »
I'm almost certain the drain pan was clean to begin with.
I don't think the previous owner did any rebuilds to this or opened it up at all. He didn't say he did, at least.
So what do you think my next step is? Drain the oil and drop the pan and have a look see? If I then don't find anything does the motor have to be disassembled until I find a culprit, assuming that these pieces are actually from my motor?
1978 Honda CB550K
Offline trueblue
« Reply #7 on: August 22, 2014, 06:29:50 AM »
I would drop the pan and check it. If you find more debris, go looking. Otherwise ride it and do a short oil change, 500ish miles. Then drop the pan again and if it is still clean with no debris put it out of your mind and ride. That's what I would do anyway. ;D
1979 CB650Z
« Reply #8 on: August 22, 2014, 06:31:42 AM »
I missed that this was a 550. No first hand knowledge. Still, doesn't look good to me.
Good luck.   :(
Offline Calumjs
« Reply #9 on: August 22, 2014, 06:32:41 AM »
What he said
Offline eigenvector
« Reply #10 on: August 22, 2014, 06:43:12 AM »
Those are too big to ignore, but if I had to guess I'd say the tensioner.  Others have said the same and how to verify.
The tensioner design is really not very good on this bike.
Rob
2018 HD Softail Heritage
1979 CB750K Limited Edition
1977 CB550K
1984 CB700SC Nighthawk
1983 VF750S Sabre
Offline DaveBarbier
« Reply #11 on: August 22, 2014, 06:51:23 AM »
Ok, thanks guys. Ugh, bikes...can't live with 'em, can't live without 'em.
1978 Honda CB550K
« Reply #12 on: August 22, 2014, 06:59:43 AM »
Is it magnetic? If not it could be bearing material, I spun a rod bearing in a car engine that looked like that. Pieces went all the way into the valve covers.
Offline DaveBarbier
« Reply #13 on: August 22, 2014, 07:14:38 AM »
Yes, it is magnetic. Are you then saying that if it IS magnetic then it ISN'T a bearing?
1978 Honda CB550K
Offline lrutt
« Reply #14 on: August 22, 2014, 07:27:46 AM »
If it's ferrous, (magnetic), then it's some portion of a bearing or gear or shaft or possibly the cam chain tensioner or some fastener. Those are the only items in our motors that are ferrous.
The shape of those look like remnants of a bearing cage almost. No matter what, it's not something your going to fix without a tear down I'm afraid.
« Reply #15 on: August 22, 2014, 07:42:46 AM »
tWO DIFFERENT KINDS OF BEARINGS. a BALL BEARING IN A CAGE, LIKE A TRANSMISSION BEARING, WOULD BE FERROUS (MAGNETIC).
Oops cap lock.
Material from the crankshaft main bearings or rod bearings would not be magnetic. Both require tear down.
CamChain tens too, magnetic, tear down. Nothing can shred that much metal without being terminal.
Offline DaveBarbier
« Reply #16 on: August 22, 2014, 07:50:44 AM »
So pretty much I'm looking at pulling the motor and taking it apart. Can the cam chain tensioner be replaced from underneath? I'm at work right now and don't have my Clymer manual handy.
1978 Honda CB550K
Offline DaveBarbier
« Reply #17 on: August 22, 2014, 08:01:00 AM »
Thanks guys. I'll keep you posted. I'm bummed out. Just getting my new carbs today in the mail and now I have this on my plate. Oh well, with each repair I gain knowledge and my bike becomes more reliable.
1978 Honda CB550K
Offline MiGhost
  • What was that about being an
« Reply #18 on: August 22, 2014, 03:24:54 PM »
Start by draining the fresh oil into a clean drain pan. If any more bits show up. You will know that they are out of the motor, and pan will need to come off for inspection.
When you get the top cover off. Check the sides of the cam chain tunnel for signs of the chain rubbing. Any signs of grooves in the walls of the tunnel will indicate a loose cam chain, and likely tensioner/guide problems.
~ Ghost
Grey Ghost '80 CB650C: Updated Stock Restomod. Period Custom Cruiser (OEM harbags & trunk, Wixom Ranger fairing, Jardine turnouts)
Bad Moon '83 XJ750MK Midnight Maxim: Full Dress Tour Deluxe w/ X-1 Fairing
Offline DaveBarbier
« Reply #19 on: August 30, 2014, 09:26:42 AM »
Ok, so I finally have been able to drain the oil again. First, I pushed the kick starter a few times to get things moving then drained the oil in a clean pan. I don't see any more metal bits. Not even small ones. I even took a magnetic screw driver and swished it around in the oil and there was nothing on the end. Just as a reminder the little pieces I found the first time were magnetic.
What do you guys think? Should I still drop the pan and open the top? If I drop the pan I'd need a new gasket, right?
1978 Honda CB550K
Offline DaveBarbier
« Reply #20 on: August 30, 2014, 02:25:33 PM »
Alright so I took the pan off anyway just to be sure. And sure enough there are two more little pieces in there that look like the first two. BUT! There is something else. Something, I'm guessing, that is very important. See pictures. I bet someone here can identify this broken piece. I looked up in the motor and I really have no idea what the heck I'm looking at. More pictures to come.
1978 Honda CB550K
Offline DaveBarbier
« Reply #21 on: August 30, 2014, 03:09:00 PM »
It's really hard to get a picture of this but I found what's broken. It's the gear in the middle rear. If you look in the center of the photo you can see a chunk taken out of a gear or something.
1978 Honda CB550K
Offline DaveBarbier
« Reply #22 on: August 30, 2014, 03:17:50 PM »
Bill Benton eh? Ok I'll check him out. Is he a member?
1978 Honda CB550K
Offline DaveBarbier
« Reply #23 on: August 30, 2014, 03:54:06 PM »
Ok cool, thanks Calj. Do you think I should just go ahead and replace the whole tranny or just that gear? Obviously determined by what else I find broken in there when I get it apart.
1978 Honda CB550K
« Reply #24 on: August 30, 2014, 06:02:07 PM »
That bigger chunk is a shift dog that has broken off one of the gears.  It probably got jammed between something spinning and shredded some metal making the shavings.
