Author Topic: opinions for ingition system PAMCO vs Hondaman  (Read 8543 times)
Offline arncruz
  • 1977 cb550
« on: August 22, 2014, 10:33:02 AM »
I was going to go with the oem points, new ignition coils and wires with the Hondaman iginition system but I saw some people on this forum using the PAMCO ignition system, and I wanted to get opinions on which would be easier to install and reliability.  I already know the PAMCO system is about $60 more expensive overall.  My CB550 is not for racing but more for riding around my small town.
Thanks
Arnold
My Stable
1969 CB750 #6xx
1969 CB750 #20xx
1969 CB750 #27xx
1969 CB750 #43xx survivor
1969 CB750 #12xxx
1970 CB750 K0 survivor
2014 MVP Agusta 675 F3
Offline Mr Freeze
Re: opinions for ingition system PAMCO vs Hondaman
« Reply #1 on: August 22, 2014, 10:53:49 AM »
Go with Hondaman's box. I have one in my 750 and it's great. It took longer to tie it up behind the battery box than it did to hook the wires up. The other nice thing is that if it fails some reason, you can disconnect it and reconnect the points back directly to the coils because it installs in line. Since it takes the stress of the points of doing all the work, frequency of adjustment and wear are reduced drastically.
The only thing I added was Dyna 5 ohm coils because my originals were bad. I like the Dynas a little more because you terminate the wires yourself so you can change them down the road without having to change the coils too.
« Last Edit: August 22, 2014, 10:56:01 AM by Mr Freeze »
« Reply #2 on: August 22, 2014, 11:21:02 AM »
I use Pamco on my K0 and got Pamco for my build.  I like that it replaces points, I spent too much time in my life setting points on my CZ and I dont want to ever do it again - not even once.
Offline Schnell
« Reply #3 on: August 22, 2014, 01:52:16 PM »
Perfectly happy with Hondaman points saver ignition system here, on my cb750k5.
primary: 1974 Honda CB750
project: 1971 Honda CL350
project: 1974 Honda CB450
previous:
1975 Honda CB750
1973 BMW R90/6
1981 Suzuki GS650
1973 Honda CD175
Offline CB750F2
  • Pat's first Honda 750 F2
« Reply #4 on: August 22, 2014, 02:23:41 PM »
I would go for the Hondaman system because it performs well and in the unlikely event of a breakdown it is very easy to revert back to points - 5 mins. I have had the Hondaman system for some years now and I have not had to adjust points. I have two F2s, one with a Dyna S and the other with a Hondaman. The bike that is registered has the Dyna and my intention is to swap it with the Hondaman. Pat
Regards
Pat from Australia
Offline arncruz
  • 1977 cb550
« Reply #5 on: August 22, 2014, 03:49:15 PM »
So far 3 for Hondaman ignition and 1 for PAMCO.  Just a question about the Hondamans ignition system.   What adjustments do I need to do to the points plate or points if I use the hondaman vs the Pamco?  ie - which system is a plug-and-play system.  I am very new to points and point plate adjustments for timing.  I know that moving the points plate and or the points will mess up the timing. I was wondering if one system is easier to set up versus the other.
Thanks
My Stable
1969 CB750 #6xx
1969 CB750 #20xx
1969 CB750 #27xx
1969 CB750 #12xxx
Offline Trevor from Warragul
« Reply #6 on: August 22, 2014, 03:59:05 PM »
I have a Hondaman on my Kawasaki H1A.
You set the points, fit the Hondman system, then forget that it's there...
Trevor
1971 Kawasaki H1A
1972 Honda CB350F
1976 Moto Morini 3 1/2 Sport
1978 Honda CBX
1997 Suzuki Bandit 1200
1999 Ducati Monster 750
« Reply #7 on: August 22, 2014, 04:48:32 PM »
The benefit of Mark's (Hondaman's) ignition amplifier is that you get a better spark regardless of the condition of your battery, your battery can have as little as 6 volts and your bike will still run, as opposed to an electronic ignition which will run like sh1t if you haven't got a constant 12 volts. For a stock engine, the Hondaman ignition amplifier is a great device, I used to install similar amplifiers on Ford V8's back before Ford installed electronic ignitions, and they were great devices.
I don't know if Mark has changed his design, but one of the problems with the "switch-able" benefits mentioned above, is that, with his earleir design at least, you need to remove, or at least, disconnect your condensors when installing his ignition, so if it does conk out, you need to reinstall/reconnect the OEM condensors before you can ride home, which is a pain, because you need to carry your condensors and some tiny spanners in your toolkit, just in case. You also need to install a new set of points because Mark's ignition won't work well with old pitted points.
I haven't tried the Pamco ignition yet, but I don't think it's any better than a Dyna S, and I think it's over priced for what it is. If I was going to buy a new Electronic ignition now, I'd go for a Dyna 2000 anyway, I installed one on a customers K1 last year, and the difference between the OEM ignition and the Dyna 2000 was like night and day, it did everything better with the Dyna 2000, but it needs to be kept in mind that you need to have a perfect charging system to get the best out of any electronic ignition, and that's why Hondaman's ignition amplifier is better for a stock bike, especially if the charging system is not 100%. Cheers, Terry. ;D
Offline arncruz
  • 1977 cb550
« Reply #8 on: August 22, 2014, 05:32:45 PM »
Thanks Terry,
Great insight on this matter.
My Stable
1969 CB750 #6xx
1969 CB750 #20xx
1969 CB750 #27xx
1969 CB750 #12xxx
« Reply #9 on: August 22, 2014, 05:37:46 PM »
Maybe Pamcopete will now weight in :)
Offline Court750Cafe
« Reply #10 on: August 22, 2014, 05:41:21 PM »
installed my Hondaman at the beginning of the riding season this year. best upgrade i've done yet to this day!!
1973 CB750k
Offline goldarrow
  • one day, i'll be an
« Reply #11 on: August 22, 2014, 09:51:15 PM »
I think main consideration for many people is $.  Hondaman unit I think is $60? Pamco $120, dyna s $150, all still plus shipping.
CB550 K0
« Reply #12 on: August 23, 2014, 12:10:52 AM »
Most important is to avoid the 'Ultimate High Output Coil'. It's crap.
I installed that with Pamco. Had strange engine behaviour and looong story of adjusting stuff.
One day I noticed that the ignition wires from one coil were loose. They just fell out when touching them. The screw inside the coil that the wires is twisted onto had just left the plastic encapsulation of the coil. I used finger power when mounting the wires. That was enough to cause the small wrong designed screws to leave the coil.
I had bought the set over one year earlier, the restore took longer time so no warranty.
This also fried the Pamco electronis for that coil.
I purchased Dyna S instead with 3 ohms coils. The build quality in an other league (better). This is also possible to just connect to OEM harness direct with similar cable as OEM points.
I found that the 3 ohm coils drained the battery. I changed to 5 ohms, a little bit better but not enough with daylight headlight as we have here. I have never had charging issues on my bike.
Went back to points, TEC which is GOOD quality. Direct no charging issues, TEC points with Dyna 5 ohms coils. I have a Hondaman ignition module to mount. Too much other things have delayed that installation.
So:
Go for points with Hondaman module to improve it, last longer. Dyna 5 ohms coils if new coils. Might be others too.
OR
Dyna 2000 where you have different advance curves to use and skip the mechanical advancer.
« Reply #13 on: August 23, 2014, 12:19:29 AM »
I run two dual output .4 ohm coils wired in series,all four fire at once.
Offline Steve_K
« Reply #14 on: August 23, 2014, 06:11:02 AM »
I have Hondaman's unit and I love it.  I did the 3000 mile tune up before I installed it.  Rode it for a day or two and then installed the unit.  I thought it ran well before, but I was wrong.  Major improvement on starting and running.
73 CB750, mostly stock with Mac 4-1 exhaust and 45 mpg
Steve
PS
No experience with the other after market ignitions,  but I like them on my newer bikes(stock ignition)
Steve_K
Offline Lost and Confused
  • Bob
  • An old fart !!
« Reply #15 on: August 23, 2014, 06:47:20 AM »
I believe that you can't go wrong either way. Stay away from Dyna, heard about quality problems. I ran a Pamco, with no worries. So nice not to play with points!!!!.
Bob
« Reply #16 on: August 23, 2014, 10:29:35 AM »
I have never had problem to adjust points.  I remember the Daiichi that was tricky when they changed when tighten the screws.
I understood that when joining this forum. I checked my old scrao points that I have saved from back in the days. 5 bad Daichi and 1 TEC plate.
Did my points almost once a year, some years not at all.  I got problem once in France on a holiday when one point broke, the bakelite stuff against the rotor broke. (Daiichi point) 30-50km driving on 2 cylinders to a Honda workshop and fixed the point.
Offline pamcopete
  • Ride. Enjoy. Life is simple
    • CB750Ignition
« Reply #17 on: August 23, 2014, 11:42:52 AM »
Here is a video of a PAMCO running with a 6 volt lantern battery which was actually 5.5 Volts for the test:
www.youtube.com/watch?v=tzuvyZom0ro
That is a 3/4" gap, so obviously there is sufficient voltage there to jump .03 + .03 = .06" combined gap of two spark plugs. That'll get you home if the alternator fails and you can start the engine with a low battery.
« Last Edit: August 23, 2014, 11:59:58 AM by pamcopete »
Offline pamcopete
    • CB750Ignition
« Reply #18 on: August 23, 2014, 11:58:32 AM »
Well, I think that you have to have a set of points for the Hondaman? All three of these systems will produce at least 50% higher voltage from your stock coils simply because they are electronic ignitions. So, whatever you do, do something about your points.
« Last Edit: August 23, 2014, 12:04:36 PM by pamcopete »
Offline goldarrow
« Reply #19 on: August 23, 2014, 04:15:30 PM »
Correcting myself on the prices listed above.
Hondaman ignition module $77 plus shipping - use your old points
Pamco ignition $119 plus shipping
Dyna s - $117 shipped, cheapest I've found on feebay
CB550 K0
« Reply #20 on: August 23, 2014, 04:39:44 PM »
Unfair comparison, considering the electronic ignitions replace the points and associated parts add those extra parts  to your Hondaman prices and see how that works out...?  The electronics don't use points right..? {that isn't a question}
Offline pamcopete
    • CB750Ignition
« Reply #21 on: August 23, 2014, 05:19:03 PM »
OK. Let me see if I understand you. Your engine is running like crap, hard to start and missing, so you buy a Hondaman system and just wire it in with the old points? That's like putting on a fresh pair of shorts without taking a shower, thinking that you are going to smell better!  :o I think that even Hondaman recommends a new set of points  to go with his system.
Offline goldarrow
« Reply #22 on: August 23, 2014, 05:27:47 PM »
Don't get me wrong Pete. I'm just merely listing prices for different options so that the OP and others to see this in terms of dollars spend.
My 75 750f runs on pamco unit. I'm happy with it. Had a set of dyna s, that 2-3 failed, and I got rid of that so quick. The rest of my other bikes still run on old stinkin' 40 year old points.  I'm happy with them.  Never had hondaman units, so I can't say a whole lot about it.
CB550 K0
Offline Stoli
« Reply #23 on: August 23, 2014, 05:37:25 PM »
It seems to me, comparing a Pamco to a Hondaman ignition is like comparing a CD player to a turntable*.  Or pinball to video games. OK, I know that is a bit of a stretch but it is the best analogy I could come up with. Pamco is an electronic ignition and Hondaman's is a hybrid that uses the points to fire transistors that handle the higher current loads. So the points don't wear down as fast since there is no arcing across them any more. I'd say you'd be pretty hard pressed to prove that one makes the bike run better than the other. It comes down to points or no points. The argument that you can easily switch back to a pure points system on the side of the road (in the event of transistor failure) is enticing and having that peace of mind has steered many to the Hondaman system. On the other hand, I think the Pamco is more reliable than many make it out to be. There is a reason why new vehicles don't have points.
* Some audiophiles prefer the sound of a well amplified turntable to that of a CD player. Others like the pure digital audio produced by a CD player.
« Last Edit: August 23, 2014, 05:39:19 PM by Stoli »
My Project Threads:
Project #1 - http://forums.sohc4.net/index.php?topic=117106.0  First bike
Project #2 - http://forums.sohc4.net/index.php?topic=127364.0  Something different
Project #3 - http://forums.sohc4.net/index.php?topic=123831.0  Long and Low
« Reply #24 on: August 23, 2014, 08:21:22 PM »
If the points not wearing out as fast with Hondaman's ignition amplifier was the only advantage I'd agree with your analogy, but you missed the part where the spark is amplified to produce a spark similar to that of an electronic ignition. So I guess the comparison should be closer to that of a DVD compared to Blue Ray, which isn't really all that much. Cheers, Terry. ;D
