I have a 74 cb750 that is now a 836 wih an ATP turbo kit running 8psi. I am using a hsr42 carb. I took it to get dyno tuned and they said the carb is too big. So they made a restrictor plate to lessen the air flow. I got the bike back and it cuts out at 4,000rpm and won't go higher. I took the bike back to e place today and in the dyno it goes off the chart lean and then riches up to normal at about 6,000 all the way to 10,000. So now I am tuning it myself. Do any of you guys run an hsr42? If anyone has had this similar issue please let me know the cause. Thanks in advance.
