Author Topic: Motogadget m-unit help!!!  (Read 24389 times)
Offline Ellz10
  • ZZ
  • Knowledge is Power
Re: Motogadget m-unit help!!!
« Reply #25 on: March 05, 2023, 10:55:02 PM »
You say "COIL to AUX in one post, but then I read you saying COIL to IGN On another.
I mean no disrespect AT ALL; I just want to know which one is correct.
Both are. It lol depends which mUnit model you are using. In v2, there was no IGN only AUX. but it really doesn’t matter because both ports do the same thing; they deliver switched 12v.
But the issue at hand that in your prior post was your confusion about the BLUE and YELLOW wires from the ignition plate to the coils. It took 5 different posts to get you straight on the Reg/Rec wiring.
Wiring a bike from scratch is not hard, but you must take a methodical approach to understanding the basics of an automotive electrical system. Posting “I did this, is it right?” is not a productive method to learning.
I wholeheartedly agree with you. I'm trying to do better - I spent the better part of tonight reading thru open/closed circuits, grounding, interference, and a few other things. I want to know everything I can about it.
One thing I was thinking about and couldn't figure out if it would work properly was if I would be okay with connecting the starter cable to battery POS, and then from battery POS to the starter solenoid.
Or does it have to be from starter to starter solenoid, and from battery POS to starter solenoid.
My understanding is that either way would work as that current is being carried and transferred regardless. Am I correct in that assumption?
Thankful for everyone on this forum. Grateful to continue to learn so much.
'77 K7 - http://forums.sohc4.net/index.php/topic,193043.msg2251436/topicseen.html#new
