Author Topic: TRYING TO ID CARBS.  (Read 929 times)
lendog
TRYING TO ID CARBS.
« on: September 26, 2006, 10:52:14 PM »
I bought a 77' cb750f for $500 recenty for a winter project. The previous owner installed a set of mikuni's. He gave me a set of spare carbs that he said were the original set. I did a search to learn how to locate the stamping on the carb bodies. The only stamping I found was 7A-JI.  Can any one tell me what carbs these are? Also am I better off rebuilding the original keihin's......or identifying the mikuni's and rebuilding those? First time post awesome site!  Thanks in advance for any advice.
Re: TRYING TO ID CARBS.
« Reply #1 on: September 26, 2006, 11:12:43 PM »
Go to HondaChopper.com for a carb spec list. 7A's are listed as 69K and 75F if I remember correctly. These carbs would have bowls with clips on them rather than screws like the 77 & 78 have. The Honda Keihins are 28mm.
As far as Mikunis goes, guess if you have smoothbore 29mm carbs I'd probably stick with those.
Offline cben750f0
« Reply #2 on: September 27, 2006, 04:08:09 AM »
yep thee '76, and early '77(mine)... have the clips on the float bowels...peace
lendog
« Reply #3 on: September 27, 2006, 07:45:45 PM »
Thanks for the reply. I need to rebuild these carbs, do I order rebuild kits for '76 carbs
