Author Topic: Rear turn signal question.  (Read 780 times)
Offline Smokinjoe
« on: August 24, 2014, 03:03:51 PM »
Hi all. A quick question. I assume these ugly blinker stalks are not stock. The bike had a sissy bar in the past. What do I need to buy to install these the way they came from the factory?
« Last Edit: August 24, 2014, 03:57:07 PM by Smokinjoe »
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
Re: Rear turn signal question.
« Reply #1 on: August 24, 2014, 03:30:10 PM »
You would need to find the passenger grab rail plus the rest of the hardware to secure the rear turn signals to the mounting tab:
84101-341-700 (grab rail)
33604-323-670
33605-323-670
33606-074-010 (two req'd, one for each side)
80108-061-010 (two req'd, one for each side)
93700-06025-0B (two req'd, one for each side)
The turn signal stems appear to be intact. The part numbers above are for a 1974 CB750, the part numbers for your motorcycle may be different, since the resident psychic is on sabbatical and you failed to include any information about what motorcycle you are referring to....
partial credit for the sticker in the photo that at least identifies it as a 750...
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
« Reply #2 on: August 24, 2014, 03:31:03 PM »
You need the rear rail bar.
Offline Smokinjoe
« Reply #3 on: August 24, 2014, 03:56:34 PM »
Thanks for the info guys!
So it appears this eBay auction has most everything I need?
http://pages.ebay.com/motors/link/?nav=item.view&id=231299389235&alt=web
« Reply #4 on: August 24, 2014, 04:04:31 PM »
Or ask here in wanted section, people have parts lying around.
Offline Smokinjoe
« Reply #5 on: August 24, 2014, 06:12:57 PM »
The motorcycle in question is a 1972.
« Reply #6 on: August 25, 2014, 04:41:36 AM »
If you wanted to clean it up and not have a grab bar check out how the K1 or 1971 mounts the rear signals. They have some nifty brackets that last I knew were still available from Honda with all the rubber bits and metal dowel. That model had no grab bar. If using a grab bar make sure you get one from a 1972-1974 as the 75-76 are slightly different. If you can find one with the rubber and steel 'clam' mount brackets buy it as those are hard to find and no longer supplied by Honda.
Offline Vinhead1957
« Reply #7 on: August 25, 2014, 11:35:55 AM »
 A picture is worth a thousand words.
