Author Topic: Cb550 question  (Read 852 times)
Offline arncruz
  • 1977 cb550
Cb550 question
« on: August 24, 2014, 03:51:24 PM »
Can you use carbs from a cb650 on a cb550?  Just wondering.  I've heard of 650 camshafts being used on 550's
My Stable
1969 CB750 #6xx
1969 CB750 #20xx
1969 CB750 #27xx
1969 CB750 #43xx survivor
1969 CB750 #12xxx
1970 CB750 K0 survivor
2014 MVP Agusta 675 F3
Offline MiGhost
  • What was that about being an
Re: Cb550 question
« Reply #1 on: August 25, 2014, 02:24:55 AM »
The PD50/51 series mechanic carbs can be used (If you can find any). The VB series CV vacuum carbs can not.
The PD50/51 carbs are 26mm compared to the 550's 22mm.
They might be a bit tough to get seated into the intake boots. Heat, and a touch of lube will help. If your old intake boots are old, and hard. You will likely want to replace them.
~ Ghost
Grey Ghost '80 CB650C: Updated Stock Restomod. Period Custom Cruiser (OEM harbags & trunk, Wixom Ranger fairing, Jardine turnouts)
Bad Moon '83 XJ750MK Midnight Maxim: Full Dress Tour Deluxe w/ X-1 Fairing
Offline arncruz
  • 1977 cb550
Re: Cb550 question
« Reply #2 on: August 25, 2014, 06:38:28 AM »
Thanks Ghost!
My Stable
1969 CB750 #6xx
1969 CB750 #20xx
1969 CB750 #27xx
1969 CB750 #12xxx
Re: Cb550 question
« Reply #3 on: August 25, 2014, 10:53:01 AM »
Yes you *can*.  But why would you?  The larger carb throats will ruin street throttle response, and only be of any benefit when the throttle is 3/4 to full open.  If all you want is a track bike, then go for it.  Be prepared for a lengthy rejetting game.
