Author Topic: 75 550 electric motor gear catch  (Read 1940 times)
Offline Tews19
  • I am no
« on: August 24, 2014, 04:42:39 PM »
I got to working on the electric start motor. I pulled it and the gear spins. It moves forward and backwards.the gear I'm talking about is in the engine itself. The electric motors teeth catch it and spin this gear to start the bike.  I then pulled my other 550 motor out and that only spins in one direction inside the engine itself. Now to fix this will I have to split the cases?  If so I'm going to leave it as is and not mess with it.
« Last Edit: August 24, 2014, 04:51:07 PM by Tews19 »
1970 Honda CB750 survivor.
Offline Tews19
  • I am no
Re: 75 550 electric motor gear catch
« Reply #1 on: August 24, 2014, 04:51:47 PM »
Pic of this gear in the engine.
Offline Tews19
  • I am no
« Reply #2 on: August 24, 2014, 04:52:46 PM »
The metal shaving are from the screws. The impact gun tore up the cover screws. Not the engine itself
Offline Tews19
  • I am no
« Reply #4 on: August 24, 2014, 05:52:21 PM »
I'm not sure.
Offline Bodi
« Reply #5 on: August 24, 2014, 06:26:27 PM »
That's #46. It should turn only one way, driving the primary primary shaft #3 through the one-way starter clutch #48, 49, 50, & 77.
I don't know if you can service this through the sump hole but it would be a bunch easier with the cases apart.
Offline Tews19
  • I am no
« Reply #6 on: August 24, 2014, 06:31:44 PM »
I'm pretty sure that might be the wheezing noise. I thought it was the cam tensioner but I adjusted that when doing the 3k tune up. I think this will be my 650 engine swap. Bummer as she idles awesome , shifts super smooth. Hmm. Maybe save it for the paulages build.
Online dave500
« Reply #7 on: August 25, 2014, 12:01:37 AM »
it can be done,ive done it and so has xsmooth here.
http://forums.sohc4.net/index.php?topic=121832.0
he then did a good write up with great photos so you can see if you want to tackle it?
http://forums.sohc4.net/index.php?topic=122084.0#lastPost
« Last Edit: August 25, 2014, 12:08:38 AM by dave500 »
Offline MiGhost
  • What was that about being an
« Reply #8 on: August 25, 2014, 02:02:31 AM »
The wonderful PITA starter clutch. It is a sprag clutch that turns free one way, but locks in the opposite direction. They ususally get damaged by the engine firing, but not catching fully. Then the starter clutch reengages with a sharp impact.
If the starter cranks. Then spins free. That would be the indication that the springs, caps, and rollers need to be replaced. Otherwise I would not mess with it until you need to split the cases.
If you do pull it. Check the clutch outer to make sure that there are no cracks around the spring bores, and that the springs do not push through the outer wall.
Alternate spring number: CB650
28125-426-000 SPRING, STARTER CLUTCH ROLLER
~ Ghost
Grey Ghost '80 CB650C: Updated Stock Restomod. Period Custom Cruiser (OEM harbags & trunk, Wixom Ranger fairing, Jardine turnouts)
Bad Moon '83 XJ750MK Midnight Maxim: Full Dress Tour Deluxe w/ X-1 Fairing
Online dave500
« Reply #9 on: August 25, 2014, 02:21:35 AM »
it can be damaged by attempting a start then releasing the button before the engine fully fires,then pressing the button again before the spinning engine has come to a complete halt if it didn't start or half started,as the engine stops it may roll backwards a little on the next compression cycle just when you thumb the button again?
Offline MiGhost
« Reply #10 on: August 25, 2014, 02:31:54 AM »
True!
The impact of it reengaging is what causes the damage.
Same thing. Just worded differently.
~ Ghost
Online dave500
« Reply #11 on: August 25, 2014, 02:46:25 AM »
just out of interest its not really a spragg but got nicknamed,its a pinion and plunger type.
Offline Bodi
« Reply #12 on: August 25, 2014, 04:54:39 AM »
No. This is emphatically not a pinion and plunger drive. That system of starter drive moves the driving gear axially to engage/disengage the driven gear - common on cars where normally either a Bendix or pinion & plunger drive are used: both retract the starter motor gear from the flywheel ring gear after startring.
Although calling it a sprag clutch is incorrect, many mechanics use this term for them.
Technically the Honda SOHC4 starter clutches use a "trapped roller" design, with the starter gear train always engaged.
Damage to the clutch can be caused by re-engaging the starter before the engine stops. The three rollers retract against their springs by centrifugal force due to the primary shaft rotation. If the starter motor is spinning while the primary shaft slows down, one roller will always come out of its pocket first: engaging only one roller produces an extreme radial load on the clutch outer housing. This also happens if one or two rollers are gummed up and don't engage properly on a normal start.
Depending on the clearances and wear, the radial force can misalign the housing and gear enough for a roller to pop out or a spring cap to jam or pop out. Once one roller is gone the clutch will soon fail completely. Cracked outer housings are common in this situation.
« Last Edit: August 25, 2014, 05:11:55 AM by Bodi »
Offline Tews19
  • I am no
« Reply #13 on: August 25, 2014, 07:12:50 AM »
So the consensus is to stop riding it as it stands to stop further damage????????Well I will check out your thread and xsmooths. Thanks to all for chiming in.
EDIT: Do I stop riding it or will it be fine for the time being?
« Last Edit: August 25, 2014, 08:14:11 PM by Tews19 »
