Author Topic: 1978 CB750A Parts Bike for Sale  (Read 1974 times)
Offline Mr Freeze
« on: August 24, 2014, 09:18:39 PM »
Hey guys. I have some 1978 Hondamatic CB750A stuff for sale if anyone's interested. I essentially have a motor and frame with exhaust. I'd like to sell the motor and frame together and it includes a lowered front end (2" cut off travel springs and spacers installed and I have a set of stock springs that would be included) and 11.5" rear shocks. The exhaust is available separately as are the wheels. The wheels are from a 1978 CB750F Supersport.
The motor has 21,000 miles on it and has had a 1974 K camshaft installed at 13,000 miles. The head gasket is leaking a little, but the motor does run (was taken off the road in May 2014) and has a set of points installed a year ago. It is currently still registered, but does not have a title (the don't require them in CT) I stripped a lot of the part I had on this bike for another build so this is what's left. The reason there's a hole in the side tappet cover above the points is because I had an oil gauge installed there. It's tapped for a 1/4" NPT fitting. What you see is what you'd get.
I'm willing to entertain offers. The bike is located in southeastern Connecticut.
« Last Edit: August 24, 2014, 09:29:31 PM by Mr Freeze »
Offline Mr Freeze
Re: 1978 CB750A Parts Bike for Sale
« Reply #1 on: August 24, 2014, 09:26:28 PM »
Here's the exhaust. It's not super clean, but it doesn't have any rot. Most of the rust is on the surface only. Should clean up pretty nice with some TLC.
« Last Edit: August 24, 2014, 09:30:04 PM by Mr Freeze »
Offline Andrewhaehnlein
« Reply #2 on: August 28, 2014, 08:54:54 AM »
Is the rear swing arm set up for the disk brake and is there a mount for the rear master cylinder on the frame?
Offline Mr Freeze
« Reply #3 on: August 30, 2014, 05:45:15 PM »
No. That's a 78 K swingarm. I used the wheels that were originally on this bike for my current 750 and had bought a parts bike with these wheels on it, so that rear is an 18" from a CB750F. The swingarm from a same year SuperSport has a bracket on the top for the brake stay whereas K and A bikes have the bracket on the bottom for the drum brake. Any adaptation for a rear disc brake would require fabricating a mount for a rear master cylinder or finding Supersport bracket from the same year which were very similar to the A's.
« Last Edit: August 30, 2014, 05:47:34 PM by Mr Freeze »
