Author Topic: Engine Knock for a Newbie  (Read 2259 times)
Offline coal909
« on: August 25, 2014, 05:43:10 PM »
Hey Guys,
im kinda new to wrenching so im still learning the normal sounds and proper diagnosing so i was wondering if you guys could help me with this or to figure out if this engine knocking is normal to the Cb750 A :-[
video link to it below
https://www.youtube.com/watch?v=4INwbCWJ7CU&list=UUBut_LZ3yhlqg9aSijvXBfg&index=1
Offline Mr Freeze
Re: Engine Knock for a Newbie
« Reply #1 on: August 25, 2014, 08:43:03 PM »
Have you vacuum sync'ed the carbs? These engines tend to get a little rattley if there aren't.
« Reply #2 on: August 26, 2014, 03:33:50 AM »
He is right, you would be surprised what difference properly tuned engine makes.
Offline Glenn Stauffer
  • Administrator
    • The SOHC/4 Owners Group
« Reply #3 on: August 26, 2014, 03:49:07 AM »
Take a look at the various tuning guides you can find here: http://forums.sohc4.net/index.php?action=downloads;cat=4
Your best bet is to go through the whole process - valve adjustment, ignition timing, carb balancing.  That should set your engine straight.
Offline raymond10078
  • Moderator
  • Just learnin' as I go . . . .
« Reply #4 on: August 26, 2014, 05:17:49 AM »
Idle too low.  Possibly need a carb sync (which should be preceded by a full tune-up).
1978 CB750A (upgrading very, very slowly)
Past bikes - Honda: SL350, CX650C, CB900C, CB1000C, CM450A; Kawasaki: several 1972 750 H2's; Suzuki: TC90J.
Bikes I want: CX650ED, a mid-sized japanese V-twin with ABS.
Offline coal909
« Reply #5 on: August 26, 2014, 05:01:40 PM »
Thanks Guys the bike is at the garage getting new tires and points replaced. So when i get it back my next step will to tune and synch the whole thing properly
Offline TIOMACHY
« Reply #6 on: April 03, 2015, 01:33:58 AM »
THIS IS THE SAME NOISE MY 78 CB750A MAKES ON START UP.  IT ALMOST GOES AWAY WHEN WARM.  I TOOK IT TO A COUPLE OF MECHANICS THAT WORK ONLY ON METRIC BIKES AND THEY BOTH TOLD ME IT'S A CLUTCH COMPONENT THAT MAKES THAT NOISE.  ALTHOUGH A PITA TO HEAR, THEY BOTH TOLD ME IT DOES NOT AFFECT THE BIKES PERFORMANCE AND DURABILITY.   I'M STILL LOOKING FOR THE NECESSARY PARTS TO GET RID OF THAT NOISE.  BUT THE BIKE RUNS REALLY WELL.   IT HAS 37,000 MILES ON IT.
REGARDS.
Offline coal909
« Reply #7 on: May 25, 2015, 05:05:34 PM »
i got my bike back and after synching the carbs it was much better it still knocks a bit but goes away right away when warm
hope it helps
