Author Topic: cb550f carbs  (Read 385 times)
Offline nwb500
cb550f carbs
« on: August 26, 2014, 11:22:10 AM »
what carbs would be best for my 77 cb550f 46cape or 42aapg thanks
Offline Tews19
  • I am no
Re: cb550f carbs
« Reply #1 on: August 26, 2014, 11:24:07 AM »
O69a..... the ones that came stock.
1970 Honda CB750 survivor.
Offline nwb500
Re: cb550f carbs
« Reply #2 on: August 27, 2014, 10:38:09 AM »
anybody have a set
Re: cb550f carbs
« Reply #3 on: August 27, 2014, 12:30:46 PM »
069a would be best if you have the stock exhaust and induction set up, as well as having a true F model, rather than a K model being erroneously called an F.  Otherwise, you'll have to rejet whatever you get to compensate for the change in exhaust pressure and induction characteristics, different from stock.
Edit:  Yes, 46c carbs are Cb550K PD style.  Never found on a stock F model.  They will still need rejetting with the correct induction and exhaust match  up.
« Last Edit: August 27, 2014, 01:13:10 PM by TwoTired »
Offline Bankerdanny
  • Endeavor to persevere
Re: cb550f carbs
« Reply #4 on: August 27, 2014, 12:43:16 PM »
The numbers appeared to me to actually be PD series, the 46C and 42A, which (as you know TwoTired) are from the 78 550K (the 46C) and 77-78 750k (42A) respectively.
So of the two you listed, the 46 is the closest to correct, BUT if by CB550F you mean CB550 Four, then the 46 is the correct carb.
I suspect you are making the common mistake of thinking any 4 cylinder CB550 is a CB550F. On the 550 (and 750) SOHC4, the F is a specific model. The models that originally came with the 4 individual mufflers are K models. The F model 550's had a factory 4-1 exhaust and richer jetting (but otherwise identical engine). The 77 550F uses a different carb than the 77 550K, 069 for the F model and PD46C for the K model.
If you aren't sure what you have look at the VIN tag on the neck. It will say 550K or 550F.
« Last Edit: August 27, 2014, 12:53:48 PM by Bankerdanny »
