Author Topic: White stuff / corrosion  (Read 681 times)
Offline Rufus2010
« on: August 27, 2014, 04:46:38 PM »
What's all this white stuff? I assume it's corrosion. How might this happen? Sitting for 20 years with water in the float bowl?
Offline DavePhipps
  • Reading the entire Hi-Perf forum
    • Hillside Technology
Re: White stuff / corrosion
« Reply #1 on: August 27, 2014, 06:40:03 PM »
Dang Cal, you beat me too it :P
Bikes:
90 FZR600 RA
74 CB550k
78 GL1000
72 CB500K
Offline Bodi
« Reply #2 on: August 28, 2014, 06:39:22 AM »
You should drain the bowls and disconnect the fuel line before storage!
The picture looks to me like someone left the petcock on and put the bike aside for years. The fuel evaporates in the bowl... but it stays full until the tank empties, concentrating the additives and impurities plus any water dissolved in the fuel (there's always some) is trapped at the bottom unable to evaporate once it drops out of solution.
I don't believe a single bowl full of fuel would do this much damage, that leaves a yellow coating of crud on the bottom of the bowl with some corrosion and a bit of white crust - not total devastation.
Storing a fuel tank is another story - leave it as full as you can (with non-ethanol gas if you can find it) for winter storage: drain, air out, and then coat the inside with oil (2-stroke oil, WD-40, or motor oil) for long-term storage. Putting napthalene mothballs in a sock tied with a ribbon put in the (empty) tank with the ribbon out the cap so you can retrieve the sock (a thin flat ribbon won't damage the cap gasket like a string will) will prevent oxidation nicely - the napthalene vapour pushes out the air fairly quickly and the balls last for a long time.
Offline lucky
« Reply #3 on: August 28, 2014, 06:46:53 AM »
Exactly. This is a glimpse at how bad it can be after a decade of neglect.
That is not neglect.
That is corrosion from dissimilar metals that are more than a 30 point difference on the galvanic scale.
Brass next to aluminum . The worst case scenario.
No gas to even help isolate the metals.
The 1969-70 CB750 carbs had aluminum float bowl drain screws to help stop some corrosion.
Online Don R
« Reply #4 on: August 28, 2014, 10:16:39 AM »
 Hondaman thinks carbs left sitting during the time when certain gas additives were used have more white corrosion than others.
« Reply #5 on: August 28, 2014, 11:00:43 AM »
Acid vapour?
My carbs did not look like that after sitting for 20 years  in 2 different barns. Filled with old fuel august-september 1990, carbs removed 2010 in my warm garage.
Online Don R
« Reply #6 on: August 28, 2014, 11:29:24 AM »
The additive was used for a few years then discontinued. Some carbs got it some didn't.
