Author Topic: Rear Break Dissasembly....  (Read 1432 times)
Roastem
« on: September 27, 2006, 02:55:14 PM »
OK i was gonna tear down the rear brakes today, and was lookin in the service manual and noticed that i have to remove the bearing retainer, and it calls for a special tool.  Do i really need this tool, or can i do it without.
A search i did turned up nil, bu thad plenty of stuff for the front brakes...LOL
Any help appreciated.
Offline Bodi
Re: Rear Break Dissasembly....
« Reply #1 on: September 27, 2006, 03:21:20 PM »
Drum brake? This assembly is independent of the wheel, and just comes out from the brake drum in the hub once you disconnect the torque arm and remove the wheel and brake assembly from the frame. There's no bearing in the brake plate as nothing turns in it - except the brake cam I suppose.
Roastem
« Reply #2 on: September 27, 2006, 03:55:34 PM »
I am using the service manual that is available on the home page of this site.  I removed the wheel from the frame and it is sitting on a table.  I removed the sprocket as it says to, and then it says to "Remove the rear wheel bearing retainer, with the bearing retainer remover, and drive out the bearing from the hub."  then step 8 is to remove pins and inspect brakes....
I dont see any way to just remove the center brake section, am i missing something?
Offline nickjtc
  • I was numero dieci
  • Yamaha XT500 'Gromit'
« Reply #3 on: September 27, 2006, 04:15:55 PM »
As Bodi says, the brake plate should lift off without you having to remove the sprocket at all. On my 650 if you turn the wheel over so that the non-sprocket side is face down the brake plate/shoes/springs etc just fall off as a unit......
Nick J. Member #3247
2008 Triumph Tiger 1050
1977 Suzuki GS750
Roastem
« Reply #4 on: September 27, 2006, 04:23:01 PM »
ok well i know the brakes are frozen so maybe thats why i can drop it out.... I will try some persuasion tomorrow....
Thanks guys.
Offline nickjtc
« Reply #5 on: September 27, 2006, 04:33:05 PM »
Let us know how it works out.
1977 Suzuki GS750
Offline jrrobertsjr
  • If you aren't scared, your not going fast enough.
« Reply #6 on: September 28, 2006, 09:01:59 AM »
You will only need the tool in question if you are planning on putting in new bearings.
Special tools for this would be great but I got mine out with a stout pair of needle nose pliers that would span the gap between the 2 slots to turn the retainer.
Most importantly, you will need to drill out the indentations that were punched by the factory to prevent unwanted loosening of this bearing retainer. Get a drill bit that is just a little larger and drill it just a hair deeper than the punch marks. There should be 4 of these and they are located at the outside edge of the retainer.
The retainer is made of very soft aluminum and the threads will strip if you don't drill these out but manage to turn it.
Spray a little penetrating oil around this retainer and it should come right out.
My bearings were shot more than I could have imagined.
If you are not removing the retainer and just want to separate the brake shoe housing from the rest of the wheel, this should be easy-peasy-lemon-squeezy.
After you remove the axle, it should almost fall apart. If it does not as you stated above, I would re-attach the brake lever to the rear wheel and move it back and forth a bit while trying to separate the housing from the wheel. Your shoes may be holding it in place.
I had the same problem on my wheel.
One final note. If you are putting new shoes on, before you take the old shoes off, wrap them with some fine grit sand paper and re-assemble the wheel. Put the re-assembled wheel back on the bike and rotate the wheel by hand (while on the center stand)  and lightly apply the brakes. Do this several times and you will clean the inside of the drum and remove the imperfections caused by the old shoes.
When you put your new shoes on, you will have an factory-fresh like surface on the drum.
And whatever you do, keep the greasy hands off the new shoes.
Johnny
« Last Edit: September 28, 2006, 09:03:49 AM by jrrobertsjr »
