Author Topic: added a mac 4/1, will it run lean or rich?  (Read 1004 times)
Offline carl550k
  • 76 550k, 99 honda shadow aero
« on: September 27, 2006, 04:41:44 pm »
 hey all, i've had my mac for a couple years now with no problem. recently i cleaned my carbs especially the pilot jets. the idle issue has been solved but now the bike(76 550k) seems to be running very rich.does going from a 4/4 exhaust to a 4/1 make the bike run lean or rich?the bike always ran lean because of the clogged pilot jets. i run a uni foam oiled air filter, this and the exhaust are the only non-stock parts. if you clean the plugs which are carbon fouled, and put them back it will run great with good throttle responce, but after a few miles the responce deteriorates and you have to keep the rpms up to keep it going. thanx in advance carl
Offline Loudpipe
  • Broken Vehicle Collector
Re: added a mac 4/1, will it run lean or rich?
« Reply #1 on: September 27, 2006, 06:41:53 pm »
4/1 would mean there is less flow than a 4/4 (read: more backpressure), so it would start running rich, like the symptomes you describe.  The reason for this is the extra backpressure causes the unburnt fuel/air mixture which is in the cylinder after the intake down stroke of the piston to travel BACK into the carb during valve overlap (since the exhaust valve doesn't fully close until the piston is a little ways down on the intake stroke), and get loaded down with a second load of fuel.  Just adjust it and you should be fine.
« Last Edit: September 27, 2006, 06:45:54 pm by Loudpipe »
- LP
1974 Honda CB350F
Previous: 1978 Honda CB750F, 1971 Honda CB500K, 2009 Yamaha YZF-R1
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
« Reply #2 on: September 27, 2006, 11:02:38 pm »
Excellent.!
   You now have the perfect set up to put on pods.   Add some air and OFFFFFFF you go!
Offline ProTeal55
  • Est1968.com
    • Joe's Barbershop Chicago
« Reply #3 on: September 28, 2006, 06:33:59 am »
My bike had velocity stacks and a 4 into 2 when i bought it.
When i made the switch to the MAC un-baffeled 4 into 1  ,the bike ran 10 times better..
I still have yet to touch my carbs, besides messing with the idle  ::)
