Author Topic: F1 rear MC - correct order of parts?  (Read 748 times)
Offline Cevan
« on: August 30, 2014, 06:28:05 PM »
Can't seem to find the pictures I took of the parts when I disassembled the MC 3 years ago.  Is this right?
Offline goldarrow
  • one day, i'll be an
Re: F1 rear MC - correct order of parts?
« Reply #1 on: August 30, 2014, 08:32:23 PM »
That looks about right. Though it's a awhile since I replaced mine.
CB550 K0
Offline Cevan
« Reply #3 on: September 03, 2014, 07:51:45 AM »
Just for posterity's sake, the above picture is wrong.  The rubber part on the far left should go on the aluminum piston.  Everything else was correct.
Offline dlhoulton
« Reply #4 on: September 03, 2014, 09:35:03 AM »
Cevan, it looks like you have everything in order but missing a piece. You have in the picture the check valve, spring, plastic cup (spring fits into it), then piston. It looks like you are missing the rubber piston seal. Here is a picture of the part I think you are missing.
Offline Cevan
« Reply #5 on: September 03, 2014, 12:10:50 PM »
Actually it's in the picture.  It's touching the check valve.  That's the piece I moved to the piston.
