Author Topic: 1978 CB 550 k start up trouble  (Read 1283 times)
Offline AlekStooge
  • can't afford cheap stuff
« on: August 31, 2014, 12:35:42 PM »
 Hi I just got this bike yesterday and plan on making it a cafĂ©. The bike has a new battery that hasn't been fully charged so it had to be kicked and no electric functions worked. I had trouble getting it back because it kept losing power around 50 mph and dies. At first it ran well for ten miles or so, then kept dying when I had to slow down. It kept getting harder each time to start and eventually got stuck at a gas station for two hours. There I added starter fluid, gas and tried different choke setting. My car battery jumped it and the bike electric started with ease. It had to be kept a 4,000 rpm standing and 5,000 moving to get it home. Then at home shut it off and kick started and electric started again with ease. It won't start again today. I think its a problem between the battery and alternator, the bike just won't generate power. Again the battery is still new. I'm new to forum and will be here regularly for advice and questions.
Thank you
How are the headlight brackets mounted to the forks? I don't see a screw, nut and bolt or weld.
Offline AlekStooge
Re: 1978 CB 550 k start up trouble
« Reply #1 on: August 31, 2014, 08:35:08 PM »
So you suspect it is the alternator that is not functioning right? That does make sense since it starts when charged up but dies later because it doesn't generate power. I assume I have to replace the alternator correct?
Don't worry car was shut off.
Thanks
Offline AlekStooge
« Reply #2 on: August 31, 2014, 10:14:46 PM »
When the battery is below 3,500 rpm it is not charging or at least being drained more than being charged. Since the battery is new and not properly charged, it dies quicker than it should. correct?
Offline rb550four
« Reply #3 on: September 01, 2014, 07:28:10 AM »
Your motorcycle's electricial system was never built to charge a dead battery, it is only meant to retain a healthy battery 's charge through the regulator, which  fails, probably more so than the generator would, then there's the rectifier... which one actually failed?
Hmmmm.
Offline AlekStooge
« Reply #4 on: September 01, 2014, 09:44:04 AM »
Remember the battery is new, which I don't know why the mechanic installing it didn't charge it. I'm going to charge it and hopefully that was the source of the problem and not anything else in the electric system.
Thank you
P.S. Now I know the bike won't charge a battery up just keep it charged.
« Reply #5 on: September 01, 2014, 12:02:10 PM »
Never jump from a car if the car is running. It's too much amperage. Without engine on its fine.
Argh. Cal, you should know better.  A car's charging system is capable 30 to maybe 100 amps (varies with model), a car battery is capable of 1000's.
Current delivery is always based on load factors.  A 50 watt headlight draws the same power from a small or large battery (or electrical system) as long as the voltage is the same.  (Ohm's law.)
AlekStooge:
Your charging system (in proper working order) CAN charge a depleted battery, if you hold the RPM higher than about 2500 RPM for 10 hours.  The stock charging system spares about 1 amp for battery replenishment after providing all the power the other bike systems draw for operation.
If we assume a 12AH battery will provide 1 amp for 12 hours (no, it really can't), charging a depleted battery at a 1 amp rate would take 12 hours or more.  Less is possible of course, depending on the battery depletion level.
This is not to say your battery is the culprit in your situation.  BUT, you must start the investigative process with a known good fully charged battery.
Charging system methodical verification checks, CB750, CB550, CB500, CB400, and CB350.
Begin with problem verification and characterization with recorded data.
A -- Fully charge a known good battery.  Let it rest for 2 hours, off the charger, and measure the battery voltage.  (Target is 12.6-12.8V.)
B -- Start the bike and measure the battery voltage at idle, 2000, 3000, 4000, and 5000 rpm.
C -- Repeat the measurements of B with lighting off.
The above tests identify charging system success, failure, or degree of "faulty".  The success voltages are listed in the Shop manual.
D -- Assuming the above indicates faulty, do check the RECTIFIER diodes with a diode tester or ohmmeter capable of testing diodes and uses more than .7 volts to make the test(s).
Of the twelve test made in D, six must read low ohms and six must read very high ohms.
E- assuming no faults were found in D,  Measure the white and green wires disconnected from the REGULATOR.  CB750s should 6.8 ohms - ish,  CB550s/350s/ and 400s should read 4.9 ohms- ish.
F- If there are no bullet holes or road rash/divots on the alternator case, the stator is probably good.  But, you can check for yellow to yellow continuity (.35 ohms) among all the wires, and that no yellow wire has continuity to the engine case.
G- Assuming no faults found in D, E, and F, measure the disconnected terminals of the REGULATOR.  The black and white terminals should measure zero ohms (subtract meter error if there is any).  Higher than Zero ohms, indicates internal contact contamination needing cleaning and attention per shop manual.
H - Assuming D, E, F, and G have not found faults. We can verify all the of the charging system minus the regulator is functioning correctly, by using a temporary jumper to connect the disconnected white wire (normally attached to the REGULATOR) and connecting the White directly to the the battery POS terminal.  Repeat the B and C tests.  However, if at any time the battery voltage rises above 15V, stop the test.  Such an indication would prove the charging system capable of maintaining a known good battery.  If this test never achieves 15V, then there is a wire/connector issue in either the ground path leading back to the battery NEG terminal, a wiring/ connector issue withe the rectifier RED path to the battery POS terminal, or you made a mistake in D through G.
I - (not used, can be confused with L)
J -  The only parts that remain to prove or expose are the REGULATOR (in active mode) and the electrical path between the battery POS terminal and the black wire that connects to the REGULATOR.
K - Lying to and starving the regulator
The regulator can only do its job correctly if it gets a proper voltage report of true battery voltage status.  The Vreg monitors the Black wire for this status.  Measuring the voltage lost between the Battery terminals and the Vreg connections identifies problems that are not really the charging system's fault.
Two connection paths must be checked, the Battery POS terminal to the Black wire connection at the VReg, and the Battery NEG terminal to the Green wire connection to the Vreg.  A volt meter can measure these losses directly by placing a probe between the two identified points, Black path and then the green path.  The numbers are summed and the error seen by the Vreg quantified.  Anything over .5V loss is cause for concern and anything over 1V is a certain issue to be corrected.  Each connector, terminal, fuse clip, or switch in the pathway can cause voltage reporting loss.
The regulator also passes the received voltage on to to the Alternator field coil to create a magnetic field within the alternator,  The voltage level determines the strength of the magnetic field and the maximum output capability of the alternator.  Therefore, starving  the Vreg of true battery voltage leads to reduced max output capability of the alternator.
L - regulator operation/verification.
  The Vreg sends voltage to the alternator field in response to measured voltage which is battery state of charge.  Any voltage at the battery of less than 13.5V sends full black wire voltage to the alternator's white wire.  The alternator output will vary with RPM, even if "told" to produce max power by the Vreg.  If the alternator has enough RPM to overcome system load, any excess power is routed to the battery which will raise the battery voltage (slowly if depleted and rapidly if nearly full).   When the battery reaches 14.5V, the regulator reduces the voltage to the alternator, reducing output strength and preventing battery overcharge.  If the battery exceeds 14.7V, the regulator clamps the alternator field coil power to zero (0V), effective shutting off the alternator.
Because, there is electrical load from the system, an alternator that is not producing power allows the battery to deplete and the voltage falls.  The Vreg responds by turning the alternator back on in accordance with battery state/ charge level.
The Vreg state changes can be monitored/verified by observing the battery voltage state, and the White wire to the alternator field.  (Two meters are handy for this.)  The "trip" voltages can be adjusted with the adjust screw, while changing engine RPM and electrical load that the bike presents to the battery/charging system to "make" the battery reach the voltage levels need for the set trip points.  IE. with load reduced (lighting off) and the engine above 2500 RPM, a charged battery will attain 14.5 V.  Anything above that and the adjust screw needs to be backed out to keep the battery safe from harm.
The shop manual outlines bench set up mechanical adjustments that should be performed on unknown or tampered units.  These should be resolved before final trip point adjust tuning.
Note that while the system is working, the Vreg can change states rapidly before your very eyes., changing 5 times or more while you blink.  Therefore, you may have to mentally average values measured on the White wire if your selected meter doesn't do that for you.
« Reply #6 on: September 01, 2014, 01:00:05 PM »
I do understand that, TT, yet, I have to disagree with your statement that a cars charging system only puts out 30-100 amps. Even a 2001 Jetta uses a 90 amp alternator. I understand that it's putting that out, and that the bike might not draw that, but with an unknown state of a charging system on the bike, is it not safer to rely purely on the CCA output of huge car battery?
Um, 90 is within the range of 30-100, Cal.  And that 90 amp capability is used infrequently in the Jetta.
The battery and the charging system are tied to the same buss or power distribution rail.  The battery supplies what the alternator doesn't supply related to the demand of the system.  If you demand more than 90 amps from the Jetta alternator, the voltage falls as the watt load output is hard limited.  Watts = I x E.
If your motorcycle starting battery is capable of 210 CCA, that is already more than even a 90 amp alternator.  Would you really expect connecting to either source to be an issue?  I wouldn't as long as the voltage is within expected parameters.  The CCA of a Car battery can be 600 or more.  But, is only delivers what is demanded of it.  If your bike starter motor draw 25 amps to turn, guess what?  The battery supplies 25 amps of its 600 CCA.  You can still run down a car battery if you draw 25 amps from it for a long enough time.
Are you stating that it is safe to use a running auto engine to jump a dead motorcycle? This would seem to be in contrast with everything I've ever read, heard, or practiced. Certainly do want to know the truth.
Yes, it is safe.  Folklore to the contrary has no technical basis, and may have developed due to human errors, excuses, frailties, or testimonials not withstanding accurate scrutiny.  I've jumped both cars and motorcycles from both running and non-running cars with equal success.
Assumptions are that the polarity is NEVER reversed even for an instant.  And, the bike's electrical system is in proper working order.  Electricity is NOT mystical.  There is a reason for everything in which it is involved.
Your house is connected to a power grid, right?  The generation station capacity in WAAAY more than what your house uses.  Still, your power meter turns/ measures according to what you use, not what is available to be used.
You know, I've even jumped a car from a motorcycle (CB550)?  The car owner was in a state of shock about that.  He mentioned something about sainthood before I rode off.  As a teen in high school, I even jumped a car to another car with only one jumper cable.  I didn't even wave my hands.  But, the pre-activity scoffing stopped abruptly with wide eyes displayed.
Offline robvangulik
  • Honda Fourever
« Reply #7 on: September 01, 2014, 03:52:54 PM »
Did you put them positive to pos and bumper to bumper? (I did that once)
« Reply #8 on: September 01, 2014, 03:56:59 PM »
Yup.  The cars had chrome steel bumpers and negative ground systems.
Offline AlekStooge
« Reply #9 on: September 01, 2014, 04:37:25 PM »
Thank you for all the responses. I will try to charge the battery with a charger, not by keeping the bike on for 10hrs. The way I understand is the bike will charge the battery, but has to be done for a ridicules extended period of time. I will start by having a properly charged battery and them try to reference the info provided if that doesen't work. Thanks for all the help.
Offline eastyork1977
  • Tuning and building in the Great White North
« Reply #10 on: September 01, 2014, 09:05:42 PM »
When I was having a similar issue with my '77 CB550K3, I suspected the Regulator or Rectifier, separate units until '79 650s 750s.
Power was cutting out during rides. Turns out it was my old regulator, it was letting over 15v get to the battery, and popping the main fuse. A couple times just before it died, the fuse held on by a thread almost white hot, then once the current fell, it shattered. The high current was making it seem like the bikes was losing power during throttle.
A multi-tester to your battery at 2500, 3500 will show just what kind of charge you're getting. You can also check out your fuse box to see if your fuses are hot and or melting slowly during operation.
Luckily I had spare fuses on me that day. I made it over 100 Kms on a highway on the last fuse and it blew as soon as I got home. About 7 Kms after the highway exit.
'73 CB350G
'75 CB400F
'77 CB550K3 "Swayze"
'78 CB550K Stock
'78 CB750F2 Stock-ish
"take a peak." - Don Cherry
"If I can bounce a wrench off a tyre and it hits you, you're standing too close."
Offline AlekStooge
« Reply #11 on: September 08, 2014, 07:51:52 PM »
This weekend I charged the battery fully. Bike started up and I rode it for about 60 miles.
Then the person who had the charger also had a device that measures the voltage. It increased up the 13 volt range when we would open the throttle. So it seemed like the battery was being charged by the bike.
I rode it some more and when I put on a hundred miles on it, it stated dying again on low revs. Now I am recharging the battery as it is down to half.
What is next? check the Rectifier? What kind of tools will I need to do this?
« Reply #12 on: September 08, 2014, 07:58:17 PM »
See reply #8
