Author Topic: Triple tree help  (Read 945 times)
Offline briancwynn
  • If created then it is for a purpose!
Triple tree help
« on: August 31, 2014, 02:17:35 PM »
I have a cb750 78 and don't know what to do with the triple tree. Do most clean them up or replace them when converting to a cafe racer? I am.going brat style so it kinda works as is but don't want to miss something I should have done in the beginning.  Any alternative tt that can be used that have.classic styling not billet?
« Last Edit: August 31, 2014, 02:20:21 PM by briancwynn »
Honda CB750 1978 K
Stock Carbs w/ Pods
125 main jets, stock slow, and 2 shims on the needle (equal to about raising it one clip)
M-unit
Bike broken down to bare bones and slowly put back together (except for the engine)
Offline briancwynn
Re: Triple tree help
« Reply #1 on: August 31, 2014, 02:28:43 PM »
Honda CB750 1978 K
Stock Carbs w/ Pods
M-unit
Offline calj737
  • I refuse...
« Reply #2 on: August 31, 2014, 03:28:44 PM »
If you're doing a brat, I'd think you'd want to keep the clamp-on bars? The clamp is aluminum, so you can grind off the bits you don't want, then paint, powder cost or polish to your heart's content.
Offline RRRToolSolutions
  • I love old Japanese bikes!
« Reply #3 on: August 31, 2014, 06:59:30 PM »
Hi Bryan, how soon will you need it? I've got a full compliment of dashes and brackets coming for Cafe builders. I'll be selling them on KickStarter in about 1 week. I don't want to spoil the surprise right now since my video and promotion is being developed this week.
You can PM me if interested or reach me through my website
www.rrrtoolsolutions.com
Best Regards, Gordon
Kaws, Hondas, Yamahas, and Suzukis - especially Kaws
Offline RobbyD
« Reply #4 on: August 31, 2014, 07:10:29 PM »
This was for my 550 but we just milled down the bar bosses.
Offline DaveBarbier
« Reply #5 on: September 01, 2014, 04:28:22 AM »
I went the route of shaving off the handle bar perches. I'm pretty happy with the turnout. Apparently getting a top triple machined isn't too hard. I could have had that done but shaving the perches was free...
1978 Honda CB550K
« Reply #6 on: September 02, 2014, 05:06:57 AM »
Wonder how much cutting those off weakens that part ?
Offline calj737
  • I refuse...
« Reply #7 on: September 02, 2014, 05:10:00 AM »
+1
Offline lucky
« Reply #8 on: September 02, 2014, 06:17:49 AM »
The triple clamp is CAST. whats wrong with that?
It is actually better. It has a shape that is much nicer than "billet" ( a machined chunk of aluminum)
Cast aluminum has other chemicals included to make it stronger.
The rounded shape makes it stronger by eliminating stress.
For instance silicon (NOT silicone) to make it 22% stronger.
Just use a brass wire brush on a drill to remove the old paint.
WEAR YOUR EYE protection!!
Offline lucky
« Reply #9 on: September 02, 2014, 06:20:20 AM »
« Last Edit: September 02, 2014, 06:22:43 AM by lucky »
Offline lucky
« Reply #10 on: September 02, 2014, 06:23:25 AM »
Very smart thinking Ekpent.
And those handlebar mounts could be used for instrument mounts.
« Reply #11 on: September 02, 2014, 06:36:36 AM »
Just seeing how many broken 750 K0-K2 uppers there are without the washer leads one to believe the metal in those is not the toughest stuff around.
« Reply #12 on: September 02, 2014, 06:39:01 AM »
It does not flex much, that could be why.
Offline calj737
  • I refuse...
« Reply #13 on: September 02, 2014, 07:15:19 AM »
The casting process can not eliminate weak spots in the alloy during cure. There is no disputing that these 40 year old cast parts are weaker than modern billet parts. Certainly most of huge billet products don't have a classic look, but their strength is undeniable.
Offline Oldtech
  • Motorcycle tech: old, cranky and retired
« Reply #14 on: September 02, 2014, 07:43:37 AM »
I've used cb550 front ends with those upper clamps on a number of vintage race bikes. The first thing I did was mill off the bar mounts. These bikes have been hammered around tracks at over 120mph on a regular basis and nothing has failed. The weak point is indeed where they clamp to the fork tubes so be sure to use the D washers to prevent overtightening.
Personally I think the open spaces that appear when you mill them looks pretty cool. The tabs in front that hold the instrument bracket are great for mounting a front number plate on unfaired racers.
« Reply #15 on: September 02, 2014, 07:55:24 AM »
Sounds like a good testimonial-Guess I am done wunderin'   :)
Offline briancwynn
« Reply #16 on: September 02, 2014, 08:23:04 AM »
Thanks all for the help. I think I will take apart and paint the original.
Honda CB750 1978 K
Stock Carbs w/ Pods
M-unit
