Author Topic: Points plate wiring CB750 K1?  (Read 506 times)
Offline cakey
  • 5% recipe and 95% process
« on: September 01, 2014, 01:25:12 AM »
Can anyone help with the correct routing for the wiring off the points plate. My bike didn't have the points plate fitted when I got it so I'm not sure the best way to get it up to the coils. Over the top of the engine or underneath. If anyone has some pics it would be appreciated. Thanks in advance.
1971 CB750 K1 (restored)
1975 GL1000 Goldwing (restored)
Offline cakey
Re: Points plate wiring CB750 K1?
« Reply #1 on: September 01, 2014, 04:16:40 AM »
From what I can figure out the wire goes under the clutch cover then up between the oil lines and across the top of the engine to connect with the same harness as the rear stop switch? Any brackets anywhere to hold the wire away from the exhaust or getting caught?
