Author Topic: CB550f to 550k exhaust  (Read 433 times)
Offline thep1pe
  • Proud Owner 76 CB550F1
« on: September 01, 2014, 05:02:36 AM »
I have a 76 550f with a 4 into 1 exhaust. I really like the 4 into 4 setup. Is it possible to fit a 4 into 4 exhaust to the 550f without too much modifying?
Offline rb550four
Re: CB550f to 550k exhaust
« Reply #1 on: September 01, 2014, 07:16:17 AM »
At first I would have said yes with minor rear hanger issue but, then I remembered my 77F , the kickstand was frame mounted further back and interfered with the "hang of it all", can't remember if the 76 is the same way.
Offline thep1pe
« Reply #2 on: September 01, 2014, 09:04:33 AM »
[/quote
Yes the 77 has the same mounts as the 76. Just a few minor cosmetic changes and the fork bellows removed.
« Reply #3 on: September 01, 2014, 05:29:48 PM »
the other big difference is the brake pedal and associated frame parts...pretty sure the f brake pedal arrangement will not work with the early style 500/550 4 into 4's, I don't know about the '77/'78 4 into 4's.  Rearsets could potentially solve this problem, although I don't know of a bolt on set up for the '76 f and that can just cause more problems. ???
« Reply #4 on: September 01, 2014, 09:00:55 PM »
You can make anything work with just about anything if you spend enough time, money, and work on it.  Is it a straight bolt on/conversion?  No.
