Author Topic: Patina Hyena - 550/650 674cc Hybrid Cafe Build  (Read 345096 times)
Offline DaveBarbier
Re: Patina Hyena - Dave's '78 CB550K Cafe Build Thread
« Reply #100 on: September 18, 2014, 03:55:19 PM »
Ok, much cleaner now. I noticed some scratches that weren't from me. But all in all I think this'll do.
1978 Honda CB550K
Offline DaveBarbier
« Reply #101 on: September 19, 2014, 02:51:30 PM »
Just cleaned up the head and removed the valves. All springs are about .5 mm out of spec. I found them on DavidSilverSpares and Partzilla for cheaper. Is that very out of spec that it warrants spending around $80?
Also, two exhaust valves have a slight scratch/nick on the tip. Valve guides look and feel ok when a good valve is inserted. Problem? Two new valves?
Pictures are hard to see.
The worst one:
Not really bad, just a nick.
1978 Honda CB550K
Offline DaveBarbier
« Reply #102 on: September 19, 2014, 02:59:12 PM »
Also, the combustion chambers have a lot of carbon in them. Is it ok to use a green scotchbrite pad on them considering I'm going to lap them anyway? Or is that a big no no?
1978 Honda CB550K
Offline Bootsey
« Reply #103 on: September 19, 2014, 04:32:51 PM »
Hey,
Cylinder surfaces look great, what method did you end up using?
The valve tips you might be able to clean up with some emory paper. Don't go too crazy though. As long as they slide through the guides freely, and there isn't too much play, you should be OK.
If you've got a dremel, you can clean up the combustion chambers with a brass wire wheel. Just stay clear of the seats. But some solvent and a scotchbrite pad should do the trick.
Offline DaveBarbier
« Reply #104 on: September 19, 2014, 06:00:05 PM »
Hey,
Ok cool, I did the scotchbrite and solvent. Worked alright, not perfect. I'll try the emory  paper, thanks.
For my gasket surfaces I used a sharp razor...very carefully and a green scotchbrite. I found that using solvent didn't help and actually made it harder to come off. But it took hours. Probably 4 hours or more each side and a lot of beer.
Any idea about the springs in my earlier question?
1978 Honda CB550K
Offline calj737
  • I refuse...
« Reply #105 on: September 19, 2014, 06:02:46 PM »
$80.
Spend the time and polish the combustion chambers to a bright shiny state. Helps in many ways down the road.
Offline DaveBarbier
« Reply #106 on: September 19, 2014, 06:57:26 PM »
$80.
What does the $80 mean? Spend it?
And bright shiny state like mirror or like my gasket surfaces? Ugh, that's going to take tools that I'll have to buy. And what about the tops of the pistons? Same finish?
1978 Honda CB550K
Offline calj737
  • I refuse...
« Reply #107 on: September 19, 2014, 07:12:33 PM »
Sorry, yes, spend the $.
It's reported that a polished chamber helps improve ignition and deter carbon build up. Polish them up. Not to a mirror finish but enough to remove scuffs and scratches as best you can.
Offline DaveBarbier
« Reply #108 on: September 19, 2014, 08:20:03 PM »
Yeah I've heard that. I'll give it a go. Still waiting on parts anyway.
For all I know you could be a salesman for Ebay  or Partzilla, haha.
1978 Honda CB550K
Offline calj737
  • I refuse...
« Reply #109 on: September 20, 2014, 05:13:51 AM »
I'd buy them through dynoman.net personally.
Offline DaveBarbier
« Reply #110 on: September 20, 2014, 06:17:39 AM »
I could spend a lot of money on this site. Yeah I see KPMI Racing Valve Springs for about $60.
Thanks for the link. I'll get them now.
1978 Honda CB550K
Offline DaveBarbier
« Reply #111 on: September 20, 2014, 09:49:20 AM »
When I'm good to get the cases together I have Loctite 518 as the sealant. Do I just put a bit in these crank journal mating faces too? I'm afraid that it'll squeeze out into the bearings when I'm torquing it down. I'm asking because there was factory sealant there previously. Same question for places like between the transmission bearings. Such as the below picture.
1978 Honda CB550K
Offline DaveBarbier
« Reply #112 on: September 20, 2014, 10:57:35 AM »
Also...and crap...but last night I cleaned the head with warm soapy water and dried it with towels and compressed air. For the valve guides I got the water out with carb cleaner and compressed air then left it over night. But I guess I didn't dry them thoroughly enough because inside there's bright orange rust forming. Are these goners? It's on almost all of them, one is fine but here's a photo of the worst one. Can I clean these out with nylon or brass brushes?
1978 Honda CB550K
Offline calj737
  • I refuse...
« Reply #113 on: September 20, 2014, 11:00:19 AM »
Just swab it up well with WD or any penetrating oil. Once cleaned, follow with light coat of Marvel or engine oil.
Offline DaveBarbier
« Reply #114 on: September 20, 2014, 04:34:30 PM »
They're a lot better now after some cleaning. I just used cue tips and oil. I'll go back to it later with a nylon brush or something similar but as of now the valves slide in effortlessly without dragging but that's when they're oiled. In operation conditions it won't be as oiled as this. So, curious what'll happen.
Thanks again Calj, you've been a big help. I greatly appreciate it. But this isn't the end. I'm going to be asking a plethora of questions as the days go by.
1978 Honda CB550K
Offline Bootsey
« Reply #115 on: September 20, 2014, 05:07:05 PM »
If you have to wash any more parts, and are concerned about not getting all the water out, spray in some methylated spirits/denatured alcohol, should help to get rid of any remnants.
Offline DaveBarbier
« Reply #116 on: September 26, 2014, 05:12:17 PM »
Got the engine soda blasted today...actually calcium something or other. $50 and the guy was super nice and very thorough. After I was done and payed he saw a tiny bit of paint left on the oil filter cover as I was putting it in my car and was like, "Hold on, let me get that spot." He might be as anal as I am.
Took it home and opened it back up and cleaned off all the calcium with warm soapy water and denatured alcohol. Tomorrow is painting day after another spray down with denatured alcohol and warming up in the sun.
Progress is happening. The only thing left to do before assembly is pull the rotor off the crank and change out that main seal. Then assembly time. Pistons, rings, bearings, valves, etc. are all clean and within spec. Can't wait to get this painted and ready for assembly.
1978 Honda CB550K
Offline calj737
  • I refuse...
« Reply #117 on: September 26, 2014, 05:17:16 PM »
Nice. Also worth dropping the cases in the dishwasher to help rinse and flush the oil passages of any remaining media.
Offline DaveBarbier
« Reply #118 on: September 26, 2014, 05:29:55 PM »
I'll consider it. I want me a streak free shine!
1978 Honda CB550K
« Reply #119 on: September 27, 2014, 03:50:25 AM »
yeah clean and wash over a few times,get all and anything that shouldnt be outta there,dig and blow out any blind threads aswell twice over,chase a bottom tap through all the threads,then clean and wash again!sounds like you had a blaster guy who really cares?
Offline DaveBarbier
« Reply #120 on: September 27, 2014, 11:45:18 AM »
Yeah it seemed like it. Nice guy and methodical. I should push him into rebuilding carbs...
I'm painting now! Primer coat right now. I didn't chase the threads with a tap. I did that before to clean them out but not after blasting. Hope it'll be ok. I power washed it with warm water and borrowed a friend's air compressor. Cleaned it yesterday and cleaned it again today. For all I know some kid could have come in my shed and touched the motor with his greasy mitts. I let everything warm up in the sun before hand and...ok, ten minutes is up, time for another coat of primer.
1978 Honda CB550K
Offline DaveBarbier
« Reply #121 on: September 28, 2014, 09:21:41 AM »
Ok, so paint is done and it's looking really nice. I was planning on doing black jugs but I put a picture in Photoshop and I don't like the way it looks with my bike.
But, right now I'm trying to pull the rotor off the crank. I just want to make sure I'm doing this right. I have the crank in a vice and I'm using socket wrench to try and break it free. This nut isn't reverse threaded, is it?
1978 Honda CB550K
Offline DaveBarbier
« Reply #122 on: September 28, 2014, 10:12:01 AM »
Ok, got it off after not seeing anyone talking about whether it's reverse or not. So I assumed not. Now I need to pull the rotor off. I thought the rear axle would fit but it's too big. I'll need something else. Off to search the forum.
1978 Honda CB550K
Offline DaveBarbier
« Reply #123 on: September 28, 2014, 10:30:54 AM »
Looks like it's a 16mm 1.5 pitch threaded hole. Damn, it's Sunday and a lot of auto places aren't open.
1978 Honda CB550K
Offline robvangulik
  • Honda Fourever
« Reply #124 on: September 28, 2014, 12:37:24 PM »
Original oilfilterbolt.....
