Author Topic: Patina Hyena - 550/650 674cc Hybrid Cafe Build  (Read 385531 times)
Offline DaveBarbier
Re: Patina Hyena - Dave's '78 CB550K Cafe Build Thread
« Reply #750 on: August 15, 2015, 08:33:34 AM »
Also got a sweet 240GB SSD for my iMac but that's a different forum.
I put a SSD in my Macbook a little while back - so much faster and quieter!
Yeah, just finished setting it up. Super fast startup and shutdown. Big apps launch much quicker. A great way to increase speed on an old 2009 iMac.
Offline DaveBarbier
« Reply #751 on: August 15, 2015, 08:38:33 AM »
I'd imagine there are more out there, but we are the newbies.
Ha, true. I noticed that my pistons all have a little remnant from the milling process. Looks like when you're turning the face surface down on some stock with a lathe, there's often a little "nipple" left over. Does yours?
This picture makes it look insignificant but it's actually pretty prominent.
Is this something I should remove?
Offline DaveBarbier
« Reply #752 on: August 15, 2015, 10:02:22 AM »
That nipple is not an issue. Sent you an email with contact info.
Just got my BMW slugs back- 90.5mm forged aluminum Wossners
Damn, those looks awesome. Got the email, thanks. I'll give him a call.
« Reply #753 on: August 16, 2015, 09:32:07 AM »
I think mine has it,too. Pistons and cylinders are off at the machinist.
Offline DaveBarbier
« Reply #754 on: August 16, 2015, 10:38:02 AM »
I can't wait to send my parts off too. Looks like you're inching ahead and I'm riding your wake, haha. Do you plan to be finished by a certain time?
« Reply #755 on: August 16, 2015, 02:25:27 PM »
No real time line for my project.  It is slated to be finished AFTER my 750 (Bionic Mongrel) project, but it seems like it has my focus as of late, since my 750 is stuck in fabrication (when my fabricator can get to it) and when I get wheels sourced for the 750.
I think you are WAY ahead of the game.  You've already built everything else but the new motor, where I am in the opposite boat, of only working on the motor.
This weekend, I distracted myself further by delivering my CB550K4 to my buddy Ian Halcott (I sold it to him for a flip project) and helped him do a tear down.
Yesterday, we went from this:
To this:
« Reply #756 on: August 16, 2015, 05:38:05 PM »
In the voice of No.5:
No disassemble , no disassemble number 550!
Illustrates how a bike can be stripped after being stolen.
If that were the intent of a thief.
Where's the frame?  What's his plans? Is he going to do a project thread on his build?
Offline DaveBarbier
« Reply #757 on: August 16, 2015, 07:38:39 PM »
To this:
Ah, nice. Yeah I guess it helps that I only have money for my one bike plus a project motor. And that none of my good friends have any interest in old bikes, so fewer distractions.
« Reply #758 on: August 16, 2015, 08:52:57 PM »
It's a quick rebuild and flip project.  It was formerly my CB550K4 build thread.  Ian is a professional builder, so there will be no build thread.  He's going to mow through it like a duck goes through - - - -.  We checked the compression and it was solid (130-140) so it will just get the valves lapped and new gaskets on the motor (along with paint).  Detabbed, gusseted, custom seat and tank.
« Reply #759 on: August 16, 2015, 08:58:03 PM »
I will be doing a clearance check with some clay, when I put it back together.
Offline DaveBarbier
« Reply #760 on: August 17, 2015, 07:15:23 AM »
Do you expect an issue? Obviously it's on me to check my motor but I would think that Dynoman would have accounted for this and added proper valve relief cuts. Unless you're straying from stock and the valve/cam combo you're going with makes for longer travel?
« Reply #761 on: August 17, 2015, 07:39:09 AM »
I am using a Megacycle 126-20 cam.
Offline DaveBarbier
« Reply #762 on: August 17, 2015, 08:41:53 AM »
My guy shoots each for $15/. Oil shed underneath and dry film on skirts. Thermal reflective on top.
Really nice guy. Maybe I misunderstood but it's $15 per coating. Three coatings, $45. Debating whether it's worth it. Thanks Cal!
Oh ok, well I'm planning on stock cam/valve train combo so I'll be good. Maybe I'll get jealous and switch it up, though. Really curious on HP differences when we're both finished. Fun experiment.
« Reply #763 on: August 17, 2015, 10:29:10 AM »
Dave,
What type of work are you doing on the head?  Serdi?  Porting?  Decking?
I decided to just do some mild Stage I-II porting to clean up the ports.  Not a full-blown Mike Rieck Stage III.  Mike says that the 650 head is much better out of the box than the 750 and 550 heads.
Mike hooked me up with the Megacycle cam (based on his and Brent Waller's recommendations) and hardweld rockers.
Offline DaveBarbier
« Reply #764 on: August 17, 2015, 02:24:23 PM »
Dave,
Looking to do a Serdi valve job and Stage II MRieck porting. Decking...nah. I really have no authority to say but I'd think that just with that I'll be pulling pretty good.
I plan on talking with Mike soon and I want to get his opinion...which pretty much means I'll do whatever he says, haha.
« Reply #765 on: August 17, 2015, 02:31:00 PM »
Dave,
You'll have to take some pictures of that head when finished.  His porting work is a thing of beauty.
Offline DaveBarbier
« Reply #766 on: August 17, 2015, 02:40:56 PM »
Dave,
I'll do a before and after if I remember. :)
Offline DaveBarbier
« Reply #767 on: August 17, 2015, 02:42:54 PM »
Got some wire, terminals, heat shrink and crimper in the mail. Wirebarn.com for the wire, this feels like great quality stuff. Cycleterminal.com for the rest.
« Reply #768 on: August 17, 2015, 03:14:40 PM »
I would expect it necessary to mill the piston top for valve relief with that cam, Don. Might dry assemble with clay before you opt for any coatings (if you do opt for them) on the pistons. I am using the same cam and mine (pistons) had to be cut deeper, including the valve pockets and rocker arms needed slight clearancing.
Yes, I am planning to check valve clearance with clay.
« Reply #769 on: August 17, 2015, 06:46:36 PM »
Nice. My engine is fully diassembled. The head and cylinders are about to go to blasting and the the machinist.
Trying to find a new output shift seal.
Are these hard to find? I haven't even looked for seals yet. Looks like we're pretty much at the same stages.
Plenty of places carry those:
http://www.cb750supply.com/products/4/engine
25x62x7 is the size I believe.
No. It is a different size than any other CB model. Waiting to hear back from Western Hills Honda.
91205-426-013   OIL SEAL (36X57X13)
You guys arent the first to be searching for that seal. This may help...
http://forums.sohc4.net/index.php/topic,106988.0.html
Offline DaveBarbier
« Reply #770 on: August 18, 2015, 05:43:14 AM »
Thanks for putting up this link, Stev-o. When I'm in the stage of buying seals I'll re-read through this.
« Reply #771 on: August 18, 2015, 06:12:13 AM »
That thread is 3 years old and those seals are not so easy to find. I was able to find a NOS one with some effort.
Offline DaveBarbier
« Reply #772 on: August 18, 2015, 11:34:55 AM »
Did you say what you're using for exhaust, Don? I don't recall. Been looking into that lately. I would want something cheap but not too cheap where it eliminates the gains from Mike's porting work. I'd like to do a Yoshi replica, but price will be a factor.
« Reply #773 on: August 18, 2015, 12:12:17 PM »
My friend is doing the frame fab work as well as the exhaust.  I have not decided, but it will likely be a 4-1 Yoshimura replica.  I'll be happy to ask him to do 2 sets of headers.
Offline DaveBarbier
« Reply #774 on: August 20, 2015, 01:39:27 PM »
I'd suggest grabbing the H4 LED bulb from CognitoMoto (~$65). It uses 12w/18w lo to hi.
Just got that LED unit. And you're completely right, this says 12w low/18w high. Not sure why their website has such a different set of numbers.
Waiting for the m-unit and switches then I'm off to the races.
