Author Topic: Oil Leak Solutions?  (Read 3551 times)
Offline todzilla220
Oil Leak Solutions?
« on: September 02, 2014, 08:43:07 AM »
I have a small leak coming from where the shifter shaft on the left goes into the main engine case on my 75 CB550.  After running the bike and warming up; and then setting on the kickstand...it's a pretty steady drip drip drip drip drip...If I put the bike on the center stand it at least slows down a little.  If anyone saw my other post, I thought it was because the bike was over-filled with oil.  But that's not the issue now.  I'm dead on level with oil now.  Unless there's some residual oil still on the other side?
A) Dont worry about and invest in good pans/kitty litter?
B) Properly fix?  How?
C) Temp fix?  Something I can put around the shaft to keep the oil in?  (hee hee...sounds dirty)   ::)
Offline Deltarider
Re: Oil Leak Solutions?
« Reply #1 on: September 02, 2014, 08:56:25 AM »
Some have good results with Castrol GTX High Mileage motoroil. I am one of them. Although I have the same leak (very little) it hasn't worsened. Until now I didn't even bother to replace the seal.
CB500K2-ED Excel black
Offline Peterengland
« Reply #2 on: September 02, 2014, 09:00:28 AM »
I had oil leaking out where the shifter goes through the side cover, I pulled the side cover and there was no oil there at all...strange, I cleaned everything up and stuck the side panel back on and there has been no leak at all in the last 2000 miles! Weird one that and I already bought a seal for the shifter shaft from DS, so this is in reserve now.
« Reply #3 on: September 02, 2014, 09:05:25 AM »
Regardless of oil level, that seal should not leak. Replacement is easy. Remove pedal. Pick at seal with a pick. Careful not to scratch the shaft. Should pull out fairly easily.
Wrap the shaft with a single ply of oily paper. Offer the new seal. The paper will protect the inner lip of the seal from getting nicked on the splines. Tap it home. Use the old seal or a socket as a drift. Remove the paper.
Offline todzilla220
« Reply #4 on: September 02, 2014, 10:00:25 AM »
DS?
Mind if you send me a link an approx cost of the seal?
Thanks!
« Reply #5 on: September 02, 2014, 10:27:21 AM »
DS?
Thanks!
DS=David Silver Spares
use CMSNL.com to find your bike, look thru the fiche and find the part and associated part number.
search using the part number and you'll come up with a few vendors. its easier than it sounds.
Offline todzilla220
« Reply #6 on: September 02, 2014, 11:03:24 AM »
Cool!  Thanks for the info!
Offline Jimsun
« Reply #7 on: September 02, 2014, 11:16:41 AM »
Not trying to thread hack but this holds true even with the cb550s? I believe mine could be leaking as well by the shifter. So all i have to do is grab a new seal/o ring and use a oring pick to remove the one on the shifter. Question 2. Im assuming that the seal is visibleafter i remove the left side sprocket cover right?
74 cb550
Offline todzilla220
« Reply #8 on: September 02, 2014, 11:26:15 AM »
I believe you and I are in the same boat.  The seal is shot now that I've started riding this barn bike.  Just trying to find and make sure I'm getting the correct one for my '75 CB550.  I'm not sure what K series it is...  Need to do a VIN lookup I think...lol
« Reply #9 on: September 02, 2014, 11:48:13 AM »
My suggestions are with the CB750 in mind. I see that the OP is about a CB550. So...
I think the act of the seal removal is the same, but the 550sprckt cover has to come off, where on the 750, only the pedal comes off.
2. I think so.
Offline Jimsun
« Reply #10 on: September 02, 2014, 12:05:26 PM »
Thanks Mac. From what i see here it's part #22
OIL SEAL (14X24X5)
91202-216-003 91202-KFL-841
It should look like this (except this is from a 750?)
« Last Edit: September 02, 2014, 12:10:56 PM by Jimsun »
74 cb550
« Reply #11 on: September 02, 2014, 12:19:48 PM »
Basically, it should look like that. Though I don't know what that is, not a 750. Not even a Honda?
« Reply #12 on: September 02, 2014, 12:21:38 PM »
Looks lke the 500/550 has a long shift shaft, a lot of which must be traversed by the seal till it finds its home. Be sure the shaft is smooth, free of knicks that can catch and tear the lip of the seal, even microscopically.
Offline todzilla220
« Reply #13 on: September 02, 2014, 12:30:19 PM »
Now I need to go to the dentist to steal one of those pics!   ;D
Offline todzilla220
« Reply #14 on: September 02, 2014, 12:47:15 PM »
I keep stumbling on vendor sites that are in the U.K. for some reason?  Anyone got any local (U.S.) sites?  Ebay isnt even helping me out much here either...
« Reply #15 on: September 02, 2014, 12:49:22 PM »
I use motogrid.com for no good reason other than I know how and they haven't done anything bad.
See how that pic is in the pic? That's OK but you got to be careful not to turn it down and scratch the shaft.
Offline Jimsun
« Reply #16 on: September 02, 2014, 05:53:42 PM »
Thanks. Now i need to figure out how im going to get my hands on one without paying. An arm ad a leg for shipping :(
74 cb550
Offline david 750f
  • 1976 CB750F
« Reply #17 on: September 02, 2014, 10:45:38 PM »
Have you tried Honda? That part number is coming up as still available.
1976 CB 750F
Offline Jimsun
« Reply #18 on: September 02, 2014, 11:43:24 PM »
I havent because last time i was told was that anything for the 74-76 parts are gone. But i guess ill give them a call tomorrow.
Thanks for the heads up!
74 cb550
Offline trueblue
« Reply #19 on: September 03, 2014, 03:29:08 AM »
Pull the cover off first and make sure that your leak isn't coming from your oil pump.  I had a similar leak on my 650 (very similar to the 550) I was certain it was the shifter seal, even went to the point of buying a new seal.  I then pulled the cover and the seal was dry but the oil pump was dripping wet.  Cost me about $2 for some new o-rings for the oil pump and about half an hour to fit them.  ;D
1979 CB650Z
Offline todzilla220
« Reply #20 on: September 03, 2014, 05:51:41 AM »
Thats a good point too.
I really need to get it all cleaned up and dried up to really determine the source before I go buyin a bunch of seals that I don't need.
Offline todzilla220
« Reply #21 on: September 03, 2014, 10:08:36 AM »
I think while I'm in there, I might as replace the seals and o-rings on the oil pump while I'm at it.
Referencing this post:
http://forums.sohc4.net/index.php?topic=112985.0
I should be good with the 46X2 O-ring?
I'm still unsure if I need the 13.8X24X5 or the 14X24X5 oil seal for the shifter?  Only $2.84 on partzilla.com
Dont understand why we got so many darn part #'s!  My John Deere tractor just has one and that's it!  lol
Offline Deltarider
« Reply #22 on: September 03, 2014, 12:08:04 PM »
Don't fix what isn't broken. While I'm in there, while I'm in there... removing the left side cover ain't no big thing, is it?
« Last Edit: September 03, 2014, 12:45:58 PM by Deltarider »
Offline todzilla220
« Reply #23 on: September 03, 2014, 12:24:07 PM »
Don't fix what isn't broken. While I'm in there, while I'm in there... removing the left side cover ain't no big thing is it?
All I have to do with my 75 CB550 is 4 screws and take off the shifter lever.  Pull towards you.   :)
Tech Tip: If you havent loosened those screws in a really long time, maybe borrow or invest in a $15 impact driver.  Hit mine with it to avoid breaking.
Offline Jimsun
« Reply #24 on: September 03, 2014, 12:46:17 PM »
Or you can put the correct size screw some penetrating oil and in 3 mins put the screw, tap with a hammer and uncrew away.
74 cb550
