Author Topic: question about stuck starter on a bike im considering buying  (Read 2863 times)
Offline NevurMind85
« on: September 02, 2014, 06:06:40 PM »
ok first let me say hi as being new. ok im looking at a few bikes, on my list at the top is a 82 cb650 that needs nothing for $600 other than the left turnsignal doesnt blink, it lights up just doesnt blink. but alot closer to me is a 78 cb750k for $500 that the guy says the motor is good but thinks the starter is in a bind as he cant start it nor kickstart it. i havent seen any info on what it could be or how to fix it. i plan to go look at it tomorrow and see if i can remove the elec starter and kick it over or am i at a lost cause and just move onto the cb650? id like to buy the 750 as its a bit cheaper and there are more parts for it (as well as having a kickstart) but the 650 is in great shape and comes with a windjammer i can sell.
any ideas on the stuck starter? i can post the cl ad if needed. he said it died while running so im somewhat inclined to think it had a loss of oil pressure and toasted the motor.
Offline Bodi
Re: question about stuck starter on a bike im considering buying
« Reply #1 on: September 02, 2014, 06:26:00 PM »
Sounds like it's seized: you can safely assume anything a seller tells you is a lie unless it's truly awful ("it was underwater in seawater").
Maybe the pistons are just rusted tight after poor storage, it might be seized by overheating or lack of oil - possibly just pistons, possibly spun/welded bearings. Worth a look though, I think. You can see in the outer cylinders through the plug holes, and see some of the valvegear through the adjuster holes. Pulling the drain plug will give you a sample of the engine oil - there's no easy way to get the last of the sump oil out with the engine not running even if you drain and fill the oil tank. If it's black tar I would be very worried about the engine bearings.
Offline NevurMind85
« Reply #2 on: September 02, 2014, 07:19:19 PM »
cool ill take a look at all that and see what happens. would it be worth my time to try to buy it and get it unstuck if everything looks good as opposed to buying the 650? that brings up another question, are parts hard to get for the 650 as opposed to the 750 or will the 650 just be a good buy all together?
« Reply #3 on: September 02, 2014, 08:23:52 PM »
Unless you have better luck than most don't plan on a slew of buyers lining up for the windjammer and factor in what parts like headlight etc you will need to buy when you remove it. As for the 750, if its your first bike or you want to be on the road soon I would look for a better candidate, at least something that turns over  ;)
Offline trueblue
« Reply #4 on: September 03, 2014, 02:49:36 AM »
I would personally go for the 650, but I like the 650's ;D
1979 CB650Z
Offline NevurMind85
« Reply #5 on: September 03, 2014, 07:06:53 AM »
I'm actually used to the weight of riding my dads 04 sportster 1200xl so I figure the weight of my first personal bike wouldn't matter much if its less than the sportster. Now then I also have a 81 kz440 near my house forsake for a pretty good price just needs a battery, the guy is just tired of looking at it doing nothing in his shed. Would it be a better buy than the cb650?
Offline Vinhead1957
« Reply #6 on: September 03, 2014, 11:32:18 AM »
You are in the wrong crowd to ask Kawi vs CB
Offline NevurMind85
« Reply #7 on: September 03, 2014, 11:41:41 AM »
Yea kind of a dumb question but I figure someone may know what the advantages are of either bike.  My delima is the cb650 is about an hour away for $600 and the kz440 is 2miles from my house listed for $500. The cb the owner and I agreeded on $600 and I haven't tried to agree to a price on the kz. The 650 is a 650 and he says it starts and runs as it sets. The kz is a twin with roughly 30less HP and needs a battery and hasn't been started for 2 years and the carbs need rejected but he has the bigger jets. Both bikes are complete and I'd like to make a bobber or brat out of whatever I get. (Preferably a bobber). Most of the reason I ask about the kz is its a twin its close to the house and I may be able to get him to come down to 300 or 400$. Should I just ignore the kz and go grab the 650 while I can?
A guy I work with is a big Honda cb fan but he didn't steer me away from the kz. I'd like the extra power from the cb but it will take my entire budget to buy it.
Offline fmctm1sw
« Reply #8 on: September 03, 2014, 12:24:19 PM »
One thing I've learned is that a seller's assessment is often optimistic and, at times, downright deceitful.  If you're limited in budget and/or experience, I'd go with whatever runs.
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline NevurMind85
« Reply #9 on: September 03, 2014, 02:15:30 PM »
Ok cool. Another small reason I asked here was hoping you guys would give me the big ups of the 650 compared to the kz, more or less asking you guys to convince me to get the 650. Granted I'm leaning that way anyways. Big downer for me is no kick start but eh no biggie. Won't die without it.
« Reply #10 on: September 03, 2014, 02:23:23 PM »
A kick start is overrated. The 650 is the culmination of a lot of honda development. I'm a 750 guy but unless you're a decent mechanic avoid the broken kicker, you have to split the cases to fix it.
« Reply #11 on: September 03, 2014, 02:24:34 PM »
Buy the KZ for your girlfriend. L0L!
Offline NevurMind85
« Reply #12 on: September 03, 2014, 02:27:52 PM »
So basically buy the 650?
« Reply #13 on: September 03, 2014, 06:15:55 PM »
Not to be rude but right now you are floundering between a big Honda 4 750 that sounds like a junker, a more possibly refined 650 and a little Kwacker twin 400. Best to just be patient and think it over as to what will make you happy in the long run and the dollars  you will have to spend to create your dream. Everyday is a whole new batch of crap-ERR I mean possibilities that come out on the web. Be patient, think it over as to what direction you want to go and then refine your search for that machine. Plenty out there to choose, especially if you can travel a wee bit.
Offline NevurMind85
« Reply #14 on: September 03, 2014, 06:18:33 PM »
I agree. The more I think about it the more I'm leaning towards the 650. The fact that the kz has sat for 2 years kind of scares me away.
Offline Johnie
« Reply #15 on: September 03, 2014, 06:26:56 PM »
Agree with the guys...don't be in such a hurry or it will cost you! Take your time and like Don said...get the KZ for your girlfriend :) You will not be happy with the twin once you ride a Honda 4. No comparison. Stay away from the 78...sounds like the motor is froze...not good. Resale the 750 will be a better buy and the reliability of the 750, well, look at the 750's the guys have here. Basic maintenance and they start right up after sitting for 20+ years. Your biggest mistake is to rush into something. Run your potential buys past the guys and they will not steer your wrong. Post a wanted ad in on this board...might find something right here. Good luck...
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
« Reply #16 on: September 03, 2014, 06:31:46 PM »
The KZ400 would make for a fun little bar hopper bobber type bike but not a great cruiser and we would lose a new member. Quickly refresh us again as to your goal, is it a custom type of ride you want to make your own or a nice ride-able  stocker.
Offline trueblue
« Reply #17 on: September 04, 2014, 03:35:49 AM »
The only real issue the 650's have that is unique to the 650's in the sohc4 family, is the charge rotor.  They have a habit of shorting out after 30 some odd years spinning round at high revs.  When they short they tend to take out the reg/rec unit as well.  When you go to look at it, take a volt meter and make sure it is charging.  It can be expensive to fix, but isn't a huge issue.  Other than that, they are pretty much bullet proof.  Mine sat from ~'84 till 2010, I put fresh fuel in it and a fresh battery then hit the starter and away it went.  Took a little coaxing to make it run, but it ran.  It needed a few things to run reliably, the worst of which was one of the worst PO #$%* ups I have ever seen.  ;D
1979 CB650Z
Offline Restoration Fan
  • My wife will never call me
« Reply #18 on: September 04, 2014, 04:11:08 AM »
Regarding the 750, kick starting a bike has nothing to do with the starter.  If it won't turn over with the starter or with the kick starter, then the engine is possibly seized.  Now, it could be a situation where something in the starter loop is bad (solenoid, battery, starter motor, ignition coils).  And at the same time, something is wrong with the kick starter (reductor gear, starter clutch or starter spring).
Either way, you're going to have to crack open the engine casing to fix the problem.  If you don't have the experience to do it, it can still be done.  There are a gazillion YouTube videos that will explain the process.  But before you jump on something like that, I would highly recommend having a close friend or family member nearby who knows what they're doing.  Because you are inevitably going to find some things in that engine when you crack it open that are going to cause you to need to ask questions of someone.
Of course, this forum is pretty awesome at handling those kinds of questions as well.
Offline NevurMind85
« Reply #19 on: September 04, 2014, 04:48:36 AM »
At this point I think I'll forget about the stuck 750. I'll keep an eye out for others.
As for what I'd like, I'd like to get one and Bob it. Probably won't cut it just extend the swing arm or get a k7+ swing arm and put in solid struts and lower the front. I really only care for a solo seat, my wife doesn't care to get on the back of one. I'd like to be able to ride to work and I have to get on i64 to do that going up a pretty decent hill. ( I live in southern Indiana across from Louisville ky so anyone should know from around here how that hill is). Not sure the kz could pull it at a decent speed. I'm drawn towards the cb's anyway. I also like that the 550 and 750 are bullet proof and cheap to fix. Wasn't sure how cheap the 650s are to fix.
Offline trueblue
« Reply #20 on: September 04, 2014, 05:27:36 AM »
The only part on the 650s I have come across as being expensive IMO is the charging system.
1979 CB650Z
« Reply #21 on: September 04, 2014, 05:57:12 AM »
Offline NevurMind85
« Reply #22 on: September 04, 2014, 11:18:30 AM »
Unfortunately I only have $600 to play with at the moment. I've seen a few come and go for around that price.
Offline John Eberly
« Reply #23 on: September 04, 2014, 11:40:47 AM »
Lemme hol' that six hundy for ya' - it will do you more good than buying an ol' beat-up scoot.
Seriously - buying the bike just gets you the privilege of buying battery, tires, gas and oil and maybe killing yourself if you cheap out on safety stuff.
Be realistic about what it really takes or you'll just end up with torn apart junk -
« Reply #24 on: September 04, 2014, 11:49:05 AM »
Any old bike that needs tires, brakes, battery, carbs cleaned, filters, serviced etc will set you back a thousand.
 John is correct be realistic and you'll be happier in the long run. .
