Author Topic: 1978 honda cb750 carb help.  (Read 1059 times)
Offline briancwynn
  • If created then it is for a purpose!
« on: September 04, 2014, 04:40:18 AM »
All, as a mechanically challenged individual I don't know what to do with the carbs. They have to be cleaned thoroughly and I don't think I can do it. With that said it would be around 400 bucks around here to have someone do it. Should I buy the new racing carbs for 800 bucks and save the hassle? I have no plans on racing as well as it is only a weekend rider. Should I man up and try and do the carbs?
Honda CB750 1978 K
Stock Carbs w/ Pods
125 main jets, stock slow, and 2 shims on the needle (equal to about raising it one clip)
M-unit
Bike broken down to bare bones and slowly put back together (except for the engine)
Offline calj737
  • I refuse...
Re: 1978 honda cb750 carb help.
« Reply #1 on: September 04, 2014, 04:42:49 AM »
Send them to member Harisuluv. He knows these inside and out, and is an exceptionally helpful guy when you have troubles. You can find his listing in the Services Offered, or just send him a PM.
Carbs are not hard to do, but you will need to synch them upon installation with vacuum gauges to your motor for optimum tuning.
« Reply #2 on: September 04, 2014, 06:59:33 AM »
many have sent carbs to harisuluv to have carbs cleaned and ready to use, but he wasnt around when i started working on carbs.
I had to figure it out myself, and it turns out it wasnt that hard.  youre still going to need to understand the components for tuning purposes.   might as well try it yourself, first.
you wont need to separate the carbs from eachother and off of the mounting plate, but you will need to take the bowls and the top caps off, and with some cleaning impliments, scrub it clean of all debris and varnished gas.  do one carb at a time, take something off clean it well, and set it aside.  everything goes back on in the reverse order it came off.
not to take anything away from harisuluv, as his work is reported as exceptional, i say do it yourself.
Offline Maurice
« Reply #3 on: September 04, 2014, 07:12:22 AM »
Second that, you shouldn't have to separate the carbs to clean them. As long as you don't open the tops you shouldn't even have to sync., that is, if the slides move freely leave them alone.
Definitely feasible on your own. The only hard part is getting the pilot jets out without damaging them: hey are pressed in. Just pull straight out and carefully, they come out eventually. It's important they're clean because they have small holes on the sides to help atomize fuel.
Thorough cleaning of all the passages gas goes through should do it: stick a tube in each orifice and blow compressed air/carb cleaner. I like to use copper strands through the jet openings so as not to damage them, so far has worked very well.
That being said I am a firm believer in self-cleaning carbs by simply riding the bike (flame away...). Gas is a solvent after all. I've had carburetor issues clear up just by riding, but of course real gunky carbs should be cleaned by hand.
Good luck.
Offline briancwynn
« Reply #4 on: September 04, 2014, 08:37:12 PM »
Thanks all for the suggestions but I think the first time I will have someone do them the suggested user. With that said if I dont want to use the OEM air box what do you suggest to replace it with?  I see that the pods get ripped on the forum.  Any other ideas?
Honda CB750 1978 K
Stock Carbs w/ Pods
M-unit
« Reply #5 on: September 04, 2014, 08:44:47 PM »
The question you should be asking is...
Do I want easy and correct jetting settings and a properly running bike with an.Ken airbox, or do I want a few weeks, or more, of trial and error.jetting, for carbs I don't really know a lot about, to maybe get a properly running bike with pods?
Offline calj737
  • I refuse...
« Reply #6 on: September 04, 2014, 08:46:41 PM »
If you remove the airbox, keep it. Don't destroy or sell it as you may want it back, or need it later.
Pods also require a tuning adjustment, so if you do have Harisuluv rebuild your carbs, you should indicate that to him to aide him in providing the correct jet changes (they'll be closer than stock, but maybe not perfect).
K&N makes a preferred brand of pods filter, or you could try the Steel Dragon products. Good luck-
Offline briancwynn
« Reply #7 on: September 05, 2014, 08:20:04 AM »
All,  http://www.steeldragonperformance.com/contact_us_3.html  will these require alterations to the carbs?  These look much better than stock. Or the Uni KN airbox that Calj737 i dont understand how that is installed on the bike.  Im dumb!
Honda CB750 1978 K
Stock Carbs w/ Pods
M-unit
« Reply #8 on: September 05, 2014, 08:22:38 AM »
anthing other than stock will require alterations to the carbs.
Offline calj737
  • I refuse...
« Reply #9 on: September 05, 2014, 08:42:17 AM »
They offer their version of an airbox as an option to traditional individual pods. Like using pods, and changing from the stock airbox, jetting changes will very likely be required to achieve the best possible tune for your carbs. Physical fitment changes and such to the actual carbs themselves, won't be required. This is a plenum style change, not a carb mounting change.
Is that a bit more clear?
A little primer for you as to why you will encounter member positions on carb changes:
- Your engine is a large air pump. Changing a single aspect of that "system" ie, airbox, filter element, exhaust baffles, pipe lengths, changes the performance of the "pump". It is widely agreed that the stock configuration, for all it's possible faults at peak performance, performs best.
Many new owners, like the appearance of pods or their build/customization benefits from the look of pods. And many who choose that route, feel their engine performs "perfectly well to their opinion". Maybe, maybe not. It is indisputable that a dyno evaluation of a stock system versus a pod-equipped system will identify changes in the performance of the "pump". You can tune the pod-equipped system to perform well, but probably you can't tune stock carbs with pods and exhaust changes to perform "as well" as a stock induction system.
So you have 2 schools of thought here: "stock and why would you ever change it" or custom and "because I'm happy enough with it". Pick your school colors and set out to build your bike that you're happy with.
My recommendation: always try to arrange a dyno tune for every bike you rebuild. Even stock settings can be improved, and only a dyno will truly divulge the correct adjustments.
Offline briancwynn
« Reply #10 on: September 05, 2014, 09:40:15 AM »
Love this. Thank you for the insight.  I will put the original back on. You would think someone would create something that doesn't look like Xanadu.  Thanks again.
Honda CB750 1978 K
Stock Carbs w/ Pods
M-unit
Offline briancwynn
« Reply #11 on: September 12, 2014, 09:49:13 AM »
Since I am going to use the stock airbox . Has anyone ever painted the air box with good results. I'm thinking if I paint it to match the side covers it might flow better looks wise? Not sure about painting plastic.
Honda CB750 1978 K
Stock Carbs w/ Pods
M-unit
« Reply #12 on: September 12, 2014, 10:14:55 AM »
sand it with 1500wet, and then treat it with Mothers Back to Black.
it'll look like new  ;)
Offline briancwynn
« Reply #13 on: September 12, 2014, 10:29:32 AM »
Fly I don't want it to be black. I have used back to black and that stuff works great. I want to paint it cream colored to match the tank and the side covers. Some plastics just don't paint well.
Honda CB750 1978 K
Stock Carbs w/ Pods
M-unit
Wobbly
« Reply #14 on: September 12, 2014, 10:57:14 AM »
@briancwynn
As a side note: I am glad that you like my bike so much that you use my picture of my bike as your avatar.
« Reply #15 on: September 12, 2014, 10:58:19 AM »
as much as it might look good, you'll have your airbox in and out more than a bunch of times, and its not the simplest to get in and out.  everytime you bump it on something, the soft plastic wont hold the paint and you'll have a mark or a chip.
just something to think about.....
« Reply #16 on: September 12, 2014, 10:59:16 AM »
@briancwynn
HAHAHAHA!!!
Offline briancwynn
« Reply #17 on: September 12, 2014, 11:18:51 AM »
Wobbly ...the highest form of flattery!!!!  If it wasn't yours it was going to be someone else's.  I loved it.
Honda CB750 1978 K
Stock Carbs w/ Pods
M-unit
