Author Topic: Any suggestions on starting a sitting engine  (Read 833 times)
Offline arncruz
  • 1977 cb550
« on: September 05, 2014, 07:32:26 PM »
I just picked up my new project motorcycle - a 1978 CB550K.  I bought it for relatively cheap and all the PO said it needed was a new battery, exhaust, and gas.  I took off the spark plugs and shot some engine oil into the cylinders, gas, and a used battery.  I cranked it about 20 times and the engine started.  After 1 year of sitting in a storage shed, the darn thing was alive.  Unfortunately the engine only lasted about 10 seconds.  I was wondering if anyone had any other suggestions on making this puppy hum.  The bike has only 24,000 miles.
Thanks
My Stable
1969 CB750 #6xx
1969 CB750 #20xx
1969 CB750 #27xx
1969 CB750 #43xx survivor
1969 CB750 #12xxx
1970 CB750 K0 survivor
2014 MVP Agusta 675 F3
Re: Any suggestions on starting a sitting engine
« Reply #1 on: September 05, 2014, 07:59:29 PM »
Start with the 3000 mi maintenance items.
Since it started, and ran, this might be all you need.....
Offline arncruz
  • 1977 cb550
« Reply #2 on: September 05, 2014, 08:04:22 PM »
Will do.  You're the second member to suggest this.  Thanks
My Stable
1969 CB750 #6xx
1969 CB750 #20xx
1969 CB750 #27xx
1969 CB750 #12xxx
Offline SOHC Digger
  • I'm not an
« Reply #3 on: September 05, 2014, 08:15:13 PM »
Make sure you are using NEW gasoline, including draining the old stuff out of the carbs. I have been bitten too many times by what turned out to be stale fuel.
Offline arncruz
  • 1977 cb550
« Reply #4 on: September 05, 2014, 08:20:00 PM »
Digger, do you have to remove the carbs to take the old gasoline out?
My Stable
1969 CB750 #6xx
1969 CB750 #20xx
1969 CB750 #27xx
1969 CB750 #12xxx
« Reply #5 on: September 05, 2014, 09:27:40 PM »
Offline BryanR
« Reply #6 on: September 07, 2014, 02:32:36 PM »
Started my own '73 CB750 after sitting for 6 years (damn kids!). Fired right up, even with the 6 year old fuel in it!
Following weekend, changed the fuel, plugs, oil. She's a champ :)
