Author Topic: how to replace final shaft bearing behind sprocket seal  (Read 446 times)
Offline Image Cycle
« on: September 06, 2014, 11:13:12 AM »
i have  a 1972 cb750 here. the final shaft outer bearing ( the one behind the sprocket seal) is bad. am I correct in thinking ill have to split the cases to replace ? I see a clip but cannot remove it as there are no holes or anything for snapring pliers. any help would be greatly appreciated
Nic
Re: how to replace final shaft bearing behind sprocket seal
« Reply #1 on: September 07, 2014, 04:41:57 PM »
Yes you have to split the cases.
