Author Topic: will an 18 tooth sprocket fit?  (Read 3788 times)
Offline fergie
« on: April 02, 2005, 05:37:43 PM »
just wondering if an 18 t sprocket will fit on my 78 550 k. It looks to me like there is not enough room ,but I just saw one advertised on ebay for my bike.  I thought I should ask the pro's.  cheers, Fergie.
The most interesting man in the world
Offline Einyodeler
  • Midnight bugs taste best!!!
Re: will an 18 tooth sprocket fit?
« Reply #1 on: April 03, 2005, 07:02:13 AM »
Hi Fergie
 When you take off your sprocket cover you`ll notice a flimsy metal chainguard (unless one of the previous owners has removed it) that actually just keeps things cleaner in there,if you break your chain it`s not going to stop it from doing any damage.I run an 18 tooth on one of my 500`s that I use for the daily commute to and from work mostly highway miles and I had to remove this guard.It does make a notable difference when you`re doing 70mph or freeway speeds.You`ll want to go with a 100 link chain instead of the 98 link.
Cheers,Stephan
1972 CB500 - 1973 CB500 - 1974 CB550K - 1975 CB550F - 1975 CB750F - 1976 CJ360 - 1983 CR480 - 1970 BSA A65T Thunderbolt
Download Motorcycle Shop Manuals here: http://forums.sohc4.net/index.php?topic=17788.0
CHUNG
« Reply #2 on: April 03, 2005, 11:10:20 PM »
Bigger is better.
Offline Six
  • Lucy - CB750F Cafe Racer
    • Motorcycle Diary
« Reply #3 on: April 16, 2005, 08:26:28 PM »
I installed an 18 tooth sprocket along with an O-ring chain.  Right away, it rubbed so much on the crankcase chain cover, I couldn't roll the bike.  I took the chain cover off, and ground it down a bit with a dremel, and Voila! it works just fine now.
Six.
BarryKelly
« Reply #4 on: April 23, 2005, 02:42:53 PM »
Hey Fergie
I just checked mine.  It was an 18tooth sprocket that I put on the front, and it worked fine with no modifications.  I really like it, especially on the highway.
Barry
Offline pmpski_1
  • Beast V and Beast I
    • My CB550 related blog on MSN Spaces
« Reply #5 on: April 24, 2005, 02:16:18 AM »
How does an 18T sprocket help? What does it give you and what, if anything, will you lose?
Thanks,
Brian
Beast   I: 1974 CB550K
Beast IV: 1976 Chevy Blazer
Beast  V: 2003 Buell XB9S
Offline Gordon
  • 750K1, 550K2
« Reply #6 on: April 24, 2005, 08:08:59 AM »
Brian,
A larger front sprocket will lower your RPMs at highway speeds (or any speed, really).  A lot of people make this mod because they don't like running the engine near the redline for long periods of time.  The same effect can be had by going down a couple of teeth on the rear sprocket.  The drawback is that you lose power on the low end (slower accelleration).  Some people say it isn't very noticeable, others say it's very noticeable.  I guess the main thing to consider is whether you do more highway or city driving.
