Author Topic: 76 CB750 - No headlights or rear running lights?  (Read 3858 times)
Offline Jim Harris
« on: September 09, 2014, 07:14:45 AM »
Good morning folks!
Well, I went out for a test ride on the K6 we just picked up recently and everything ran great until I noticed that the headlight and rear running lights weren't working any more. I'm positive the headlight was on when I left and I'm 99% positive the rear lights were on as well. The front running lights are working as are the directional signals front and rear. I checked the fuses, all good. I checked the headlight, all good. I opened the headlight switch on the handle bar and cleaned the contacts, no change. Now I'm thinking that I must have a break in a common ground. Any suggestions would be greatly appreciated.
Thanks!
1969 Honda CB750 K0 - Candy Ruby Red
1972 Honda CB750 K2 - Candy Gold
1974 Honda CB750 K4 - Freedom Green Metallic
1976 Honda CB750 K6 - Candy Antares Red
(2) 2000 Honda ST-1100
1973 Honda CB450
Offline goldarrow
  • one day, i'll be an
Re: 76 CB750 - No headlights or rear running lights?
« Reply #1 on: September 09, 2014, 09:04:02 AM »
old glass tube fuse could look good, but may actually be bad.  test the fuse with meter.
CB550 K0
Offline Jim Harris
« Reply #2 on: September 09, 2014, 10:24:06 AM »
Yes, they are the original fuses and they look old, but they are showing full conductivity with the meter. I'll go ahead and replace the fuses for new ones anyway just in case its an intermittent break in the filament. I'll let you know if that works.
Thanks!
1973 Honda CB450
Offline Jim Harris
« Reply #3 on: September 09, 2014, 11:48:31 AM »
Here's a few more clues...
I changed the fuses, no difference.
I don't think its the ground anymore. I opened the headlight bucket again (all original connections, never been touched) and put the meter on to see if there was any voltage on the headlight "drive" lead or the "pass" lead when connected directly to a ground on the frame, no voltage.
Then I tried the ohm meter, connecting the ground from the headlight to a ground on the frame and have 100% connectivity.
It must be that the power lead that serves the headlight and rear running light has a short somewhere. I'll check the back of the fuse box next as suggested by calj737.
I'll let you know what I find.
Thanks!
1973 Honda CB450
Offline Jim Harris
« Reply #4 on: September 09, 2014, 12:07:32 PM »
OK, we are on the right trail...
More clues...
I disassembled the fuse box to check the connections on the back as suggested by calj737. They were corroded but secure and working. Then I set the bike on 2500 rpm and checked the voltage at each of the three fuse connections. the top 5A fuse and the bottom 15A fuse were each getting 12+ volts, the middle 7A (headlight)  fuse was only getting .6 to .7 volts, so it's not getting enough power. Where does the voltage come from that serves that center fuse? The wires in the back are brown with a red strip.
Thanks!
1973 Honda CB450
Offline Jim Harris
« Reply #5 on: September 09, 2014, 01:00:14 PM »
I check both side of the fuse box, same .6 -.7 volts both sides.
I just looked up the wiring diagram and saw that the center fuse gets its power through the "combination switch" (ignition switch) so I took that off to see if it was working correctly. It has a red power lead, a black neutral, a brown lead and a brown/white lead. If I'm reading the wiring diagram correctly, the power activates the brown leads to serve the taillights when the key is in position 1. I put the ohm meter on the leads in the back of the switch with the following results:
In position one, I got conductivity between the red and black leads
In position two, I got conductivity between the red and brown, but nothing at the brown/white or the black neutral.
I'm sure that can't be right.
Do you think the ignition switch is defective?
1973 Honda CB450
Offline Jim Harris
« Reply #6 on: September 09, 2014, 02:12:21 PM »
OK, I'll order a new ignition switch, thanks!
1973 Honda CB450
Offline goldarrow
« Reply #7 on: September 09, 2014, 03:16:25 PM »
You can try cleaning the contact points behind the switch. Water gets in the rubber cover and cause corrosion
CB550 K0
