Author Topic: What's the 'Best bang for the $' when it comes to rust remover liquid ?  (Read 4936 times)
Offline grcamna2
I've been hearing a lot of different things over the years about rust remover but can't remember too many of'em.
I used some Oaxalic acid(wood bleach)on some oem spokes and the inside of a little fuel tank and I'm not too pleased w/ the finish after I removed them from the treatment. The stuff took off all the old cad. plating from the spokes and then left a type of white-ish powder sticking to the metal w/ a bare dark grey finish on all the parts & I guess that looks stripped of all the plating.I hope I can remove the white-ish coating from the parts w/ a small wire brush.
A guy really praised that Evaporust even though it's kind of expensive for me;are there a few other options you folks can recommend that works well but still leaves all the old cad. plating? & leaves the items w/ a smooth finish so I don't have to polish them before I (  :-\ :( ) paint/coat the surfaces again so they won't rust up again prematurely ?? Especially spokes..,I'd rather not have to mess w/ them too much...
                                    Your help will be Greatly Appreciated
« Last Edit: September 12, 2014, 12:28:17 PM by grcamna2 »
75' CB400F/'bunch o' parts'
Offline brandEn
Re: What's the 'Best bang for the $' when it comes to rust remover liquid ?
« Reply #1 on: September 11, 2014, 09:04:59 PM »
That Evoporust is awesome. I get it at Harbor Freight. Its expensive but it can also be re-used.
Offline grcamna2
« Reply #2 on: September 11, 2014, 09:10:12 PM »
Did it harm any chrome/cad. plating or paint brandEn ?
Offline brandEn
« Reply #3 on: September 11, 2014, 09:15:47 PM »
I used it on a couple fenders and it worked great. Didn't hurt the chrome at all. Works great inside a gas tank too.
« Reply #4 on: September 11, 2014, 10:04:10 PM »
molasses.
Offline grcamna2
« Reply #5 on: September 12, 2014, 04:29:17 AM »
Hi Dave, they ask a ton$ for that strong Black Strap type molasses,they think of it here as 'Health Food' & market it accordingly.
« Reply #6 on: September 12, 2014, 04:32:36 AM »
go to a farm or horse supply place,its like a buck a litre?water it down 50/50 or so?the original question was bang for buck?health supply places are a #$%*ing rip off man!even if you just want a band aid?
Offline grcamna2
« Reply #7 on: September 12, 2014, 04:58:05 AM »
Dave and Cal, on those two molasses & vinegar., what'll they do to the original steel and cadmium/chrome plating ? also will they stain the metal? do I need to do a special prep before painting after using either ?
Thanks for that tip on the horse supply/feed supply place Dave,it should be cheaper there.
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #8 on: September 12, 2014, 06:10:26 AM »
Likely if you out have that much rust, the plating is what is already sacrificed and turned to rust.
Vinegar won't damage the paint if dealt with while wet. Just add some light oil or 2-stroke oil to the internal after de-rusting. That will treat and protect the tank for a good while until use.
I follow vinegar with a baking soda rinse prior to oil treatment.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline grcamna2
« Reply #9 on: September 12, 2014, 07:01:43 AM »
How long do you leave the vinegar(100% straight or watered down?)in the tank? Do you heat it up before filling up the tank with it ?
« Reply #10 on: September 12, 2014, 08:05:49 AM »
But it's about the cheapest solution outside electrolysis.
And environmentally friendly! It will kill vegetation, so we use it along the fence as liquid weedeater.
TAMTF...
Wilbur
Projects:
Offline grcamna2
« Reply #11 on: September 12, 2014, 08:06:08 AM »
No heat. Pour it in and let it sit. Check it in a couple of days. If murky and frothy, pour out and filter the debris. Refill. Vinegar can work a few cycles. Just leave it in until the tank rinses clear. You may need to add more unused vinegar periodically with rinsing. But it's about the cheapest solution outside electrolysis.
Cal, This must be vinegar 100% solution,correct ?
Offline grcamna2
« Reply #12 on: September 12, 2014, 08:31:11 AM »
Thanks for that feedback
« Reply #13 on: September 12, 2014, 09:31:11 AM »
Kleen Strip Prep-n-Etch
2 day soak @ full strength.
Before and after photos of rear fender
Offline grcamna2
« Reply #14 on: September 12, 2014, 09:39:06 AM »
AH,ok flybox,  8)
I can see how that Prep and Etch product is real good to the chrome plating.,I wonder how it'll treat spokes ? I'd like to save as much of the factory coating(cad.plating?)on my stock parts(spokes,nuts & bolts,brake cam lever,etc.)as I can and then if they're missing some plating in spots I can touch up those spots w/ some silver/chrome paint or something like that. I wonder how vinegar treats those kind of plated parts ?
How much is a gal. of that stuff flybox ?
« Reply #15 on: September 12, 2014, 09:51:25 AM »
It did well on the chromed parts.  Only where the chrome was beyond repair was it clean, but rough, after treatment.
IIRC it was about $20/gal at Home Depot
If i had some old spokes, i'd throw a few in at intervals over the weekend for you.  :D
for most of my bolts and other small items, after i treated them, they came out with the matte gray phos coating this product is known for....
« Last Edit: September 12, 2014, 09:53:12 AM by flybox1 »
« Reply #16 on: September 12, 2014, 01:32:26 PM »
molasses wont hurt chrome or paint,it wont stain just hoses off,dont submerse any aluminium or zinc alloys though it will destroy them,ferrous can be left indefinitely,what ever you use wash it well off afterwards and use oil/atf/wd40 etc as its going to flash rust before your very eyes.
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #17 on: September 12, 2014, 03:05:16 PM »
Prep-n-etch works awesome! That and some fine steel wool on tough sruface rust.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline grcamna2
« Reply #18 on: September 12, 2014, 03:43:26 PM »
Did you ever put spokes into it Dave ?
« Reply #19 on: September 12, 2014, 09:59:45 PM »
if they are zinc coated the zinc will tarnish or disappear.
Offline grcamna2
« Reply #20 on: September 13, 2014, 06:13:53 AM »
ok
« Reply #21 on: September 13, 2014, 06:53:04 AM »
For spokes I would be tempted to sand them down with some 400 wet/dry with soapy water then paint or whatever or better yet just get them re coated with a new finish to prevent future corrosion.
Offline grcamna2
« Reply #22 on: September 13, 2014, 10:33:56 AM »
Have you ever done that w/ spokes or other zinc plated parts after they've rusted halfway ? I wonder who does that type of oem looking coating? I was just going to paint them silver for now.
« Last Edit: September 13, 2014, 05:59:16 PM by grcamna2 »
Offline grcamna2
« Reply #23 on: September 13, 2014, 05:59:56 PM »
bump. Any other idea's out there  ::) ?
Offline faux fiddy
  • bike in a box
« Reply #24 on: September 13, 2014, 11:06:19 PM »
Yeah, VERY fine, some steel wool can scratch.
I get  bang for the buck at a 'Walls Bargain Outlet' where I find stuff called 'Krud Kutter,' which is phosphoric acid  in a carrier with the viscosity of snot so it hangs on a bit.  It comes off the chrome with a rinse, darkens the rusty pits but not  bad if you dry it quick. It flash rusts if you don't wax it or oil it.
I bought some of the reusable stuff at Home Depot, $25 a gallon. It likes warm weather or heat.
If it wasn't the cheapest stuff available I would probably be using something else.
^^^^^^^/l^^^^^^^^^^^^^^/l^^^
