Author Topic: CB750 K4 Build - The Cafe Tracer  (Read 118885 times)
Re: CB750 K4 Build
« Reply #150 on: March 31, 2015, 03:47:35 PM »
You may want to hit it with some type of primer or sealer while you wait. Otherwise, you will have flash rust which will inhibit the paint from properly adhering to the steel.
The dustless blaster uses water and a rust inhibitor that removes the chlorides from the water.  You have 72 hours before it starts to flash rust.
That's cool.
Fantastic!  Do "we" have a frame color yet?   And it appears the head races are still in the frame, are you upgrading to tapered bearings?
PS. The MotoGP races are in Austin next weekend, you should consider coming up.
Offline budman
  • 1914X
    • LeCompte Electric Bass
CB750 K4 Build
« Reply #151 on: March 31, 2015, 05:26:04 PM »
Gloss black for the frame.  I am upgrading to tapered roller bearings.  I left the old races in because I didn't want to damage the internal surface of the head when I blasted the frame.  I'll knock the old ones out at some point before I paint the frame.
The races sound like fun, but I'll be out of the state that weekend.
Bud
1973 CB750K3 Chopper
2021 Indian Scout
Offline budman
  • 1914X
Re: CB750 K4 Build
« Reply #152 on: March 31, 2015, 05:40:10 PM »
Question...I bought a Rick's solenoid and it has a slightly larger diameter than the stock solenoid.  I had planned on using the stock circular mounting bracket, but it won't close with the ends flush around the Rick's.  Is there a bracket from another year that might be slightly larger?
Bud
2021 Indian Scout
Offline calj737
  • I refuse...
Re: CB750 K4 Build
« Reply #153 on: March 31, 2015, 05:45:20 PM »
It's a tensioned bracket. Slip a washer in between the tabs and clamp it down.
Offline budman
  • 1914X
Re: CB750 K4 Build
« Reply #154 on: March 31, 2015, 05:56:02 PM »
That might work.  It's a pretty wide gap.  Would take 2-3 washers at least.  I was thinking about splitting the bracket and welding a little filler piece as an alternative.  It's piddly stuff and it won't be visible, but I spent a lot of time getting all those parts stuffed in there.
Bud
2021 Indian Scout
Offline budman
  • 1914X
Re: CB750 K4 Build
« Reply #155 on: April 03, 2015, 02:43:39 PM »
I primed the frame today.  I'm supposed to go for a long ride tomorrow, but it's supposed to rain.  If it does I'll probably stay home and prime some more parts.
Bud
2021 Indian Scout
Offline budman
  • 1914X
Re: CB750 K4 Build
« Reply #156 on: April 19, 2015, 03:59:13 PM »
Sanding the frame.
Bud
2021 Indian Scout
Offline budman
  • 1914X
Re: CB750 K4 Build
« Reply #157 on: April 25, 2015, 02:31:44 PM »
I haven't done much in the past few weeks, but today I finished sanding the frame and got the second prime done.  I just need to wet sand it with 400 and it's ready for paint.
I'm going to have to put the 750 on hold for the next couple of months and concentrate on the v-twin bobber.  I've got to get it into shape for Sturgis.  I ordered a new front end and new tires for it this week.  I really need to strip it down completely and paint the frame, but I don't know if I'll have the time.  I was planning on starting on the v-twin at the beginning of the year, but got caught up in the 750.  Now I have to hustle.  Next Saturday will be the last ride in its present form before I start ripping into it.  I would like to get it done by the end of June or the beginning of July so I can do a Hill Country shake down before heading off to Sturgis.  That's the plan anyway.
Bud
2021 Indian Scout
Re: CB750 K4 Build
« Reply #158 on: April 25, 2015, 03:37:08 PM »
Hey Bud - sorry to hear but understand.  Let me know when you come up this way.
Offline budman
  • 1914X
Re: CB750 K4 Build
« Reply #159 on: April 26, 2015, 06:14:24 AM »
The buddy of mine you met at the Harvest Classic and I have been trying to get back to the Hill Country and ride the three sisters.  When I get the v-twin back together that's the plan.  You're welcome to join us.  I've only ridden one of the sisters.
I would like to have the 750 finished for the Harvest Classic.  Don't know if I'll make it.  I still don't have an engine.  That's the biggie.
Bud
2021 Indian Scout
Offline budman
  • 1914X
Re: CB750 K4 Build
« Reply #160 on: May 09, 2015, 05:36:55 PM »
I got the bobber torn down today.  I got the new turn out exhaust tips welded in place before I pulled the exhaust.  I started stripping the frame.  Depending on how it goes I think I'm just going to leave the motor and tranny in the frame and paint around it.  Time is precious on this project.
I'll try not to post too many photos of the bobber.
Bud
2021 Indian Scout
Offline budman
  • 1914X
Re: CB750 K4 Build
« Reply #161 on: May 17, 2015, 10:17:52 AM »
I got the bobber frame stripped and painted.  Came out great!  I went with Deltron instead of Shopline.  Both are PPG products, but Deltron seems to be far superior, at least in this case.  Shopline single stage seems to be too soft and it chips too easily.  Probably not as many solids as Deltron.  I've used Shopline base coat/clear coat before without issue, but not crazy about the single stage.  I'm going to go ahead and shoot the CB750 frame with Deltron, and redo a few of the parts I've already painted.  Seems like the way to go.
I left the engine and tranny in the frame.  I just don't have the time pull it and reinstall it.  I was careful to mask it off well.  I doubt anyone would guess it was painted with the engine in the frame.
Bud
2021 Indian Scout
Offline budman
  • 1914X
CB750 K4 Build
« Reply #162 on: June 17, 2015, 12:16:57 PM »
Getting close to finishing the v-twin bobber.  Everything has been either repainted, polished or replaced.
« Last Edit: June 17, 2015, 01:34:21 PM by budman »
Bud
2021 Indian Scout
Re: CB750 K4 Build
« Reply #163 on: June 17, 2015, 05:29:42 PM »
Looks great, Bud!
Offline budman
  • 1914X
Re: CB750 K4 Build
« Reply #164 on: July 05, 2015, 06:37:39 PM »
Done!  Probably won't be able to get back on the CB until after Sturgis.
Bud
2021 Indian Scout
Offline budman
  • 1914X
Re: CB750 K4 Build
« Reply #165 on: October 03, 2015, 03:10:07 PM »
I'm back on the CB750.  I've been sanding parts for the last few weekends.  I've got the frame all ready to go along with a bunch of parts that will get painted black next Saturday if the weather is decent.  The gas tank is block sanded and ready for some more primer.
Bud
2021 Indian Scout
Re: CB750 K4 Build
« Reply #166 on: October 03, 2015, 06:25:46 PM »
Hey Bud....good to see you back at it.  Want to see this bike at Harvest Classic 2016!
Offline budman
  • 1914X
Re: CB750 K4 Build
« Reply #167 on: October 09, 2015, 12:43:29 PM »
If it turns out good I might think about showing it next year.
Bud
2021 Indian Scout
Offline budman
  • 1914X
Re: CB750 K4 Build
« Reply #168 on: October 17, 2015, 02:28:26 PM »
I'm a week behind.  Got it done though.
Bud
2021 Indian Scout
Offline budman
  • 1914X
Re: CB750 K4 Build
« Reply #169 on: December 12, 2015, 02:02:27 PM »
I've started the assembly.  Still need some new parts, like axle adjusters, brake rod, etc.  I don't want to get too far into it because I still don't have an engine.  Hoping to find one after the holidays.
Bud
2021 Indian Scout
Offline timbo750
Re: CB750 K4 Build
« Reply #170 on: December 12, 2015, 10:13:12 PM »
The shocks look good, what brand are they?
Sent from my GT-I9505 using Tapatalk
Offline budman
  • 1914X
Re: CB750 K4 Build
« Reply #171 on: December 13, 2015, 06:53:34 AM »
YSS E-302 330mm.  I got them from Moto Madness.  The eyelets are a little narrow.  I got some rubber washers to fill in the gaps.  Also the zinc plated clevis bolts look cheap.  I'm going to get some stainless or chrome bolts.  Other than that they seem pretty decent.
Bud
2021 Indian Scout
Offline budman
  • 1914X
Re: CB750 K4 Build
« Reply #172 on: December 21, 2015, 01:24:53 PM »
I really wanted to use Joker Machine headlight ears, but I just couldn't justify spending $200 for them.  I opted for the cheaper Emgo ears and drilled them to lighten the look.  I'm going to glass bead them and repaint them.  I should have bought the silver ones since I'm going to paint them.  Wouldn't have saved me a few bucks more.
Bud
2021 Indian Scout
Re: CB750 K4 Build
« Reply #173 on: December 21, 2015, 03:47:10 PM »
$200 is a bit steep for a pair of ears....
Offline budman
  • 1914X
Re: CB750 K4 Build
« Reply #174 on: December 21, 2015, 04:47:09 PM »
Yeah, that's 1/3 to 1/2 the price of an engine.
Bud
2021 Indian Scout
