Support the site. Your contributions keep this site running.
Quote from: budman on February 11, 2016, 07:23:35 AMQuote from: mystic_1 on February 09, 2016, 04:20:23 PMHere's the thing about this rabbit hole, though: once the top is off, you're only a few bolts away from being able to put in a new cam chain. mystic_1There's that, but there's ways around it.Very true, but it's just a few bolts, and then you'd also have the opportunity to plastiguage your crank and rod bearings. Oh and also replace those pesky seals at the right side crank and final drive shaft. They're 40ish years old!Plus you'd be able to clean out the grunge that accumulates below the transmission, that stuff never flushes all the way out of the sump.AAaaand, inspect/replace your shift forks for smooth shifting.Really, if you're going to take the motor most of the way apart anyway, why not go all the way? mystic_1
Look what arrived today.
Quote from: budman on February 12, 2016, 09:13:48 AMLook what arrived today.Free or seized?
I just read this build all the way through....43 pages. Digging the project and your skills (oh...and the pan head too!!). Just like you thinking about the wooden seat....I was thinking about the oil line. It's gotta be a 3/8 NPT in my eyes because the next size down is 1/4 and that's too small diameter. So the 3/8 thread will bite ok with JB for sealer? My plan was to put a female 3/8 on that side and a male 8an on the other. It may be overkill being that there's no pressure on the hose but this way I won't ever have to buy the whole line again.....just the hose only. That's how I did my oil cooler hoses.
WooHoo!
She's a roller!
Congrats on the roller!! Always a nice milestone in a build. Looks like your project is coming along very well, keep up the good work.
