Author Topic: CB750 K4 Build - The Cafe Tracer  (Read 137201 times)
Offline budman
  • 1914X
    • LeCompte Electric Bass
Re: CB750 K4 Build
« Reply #250 on: March 20, 2016, 04:40:21 PM »
I started stuffing some wires today.
Bud
1973 CB750K3 Chopper (in pieces)
Offline budman
  • 1914X
Re: CB750 K4 Build
« Reply #251 on: March 22, 2016, 04:31:53 PM »
Working on the seat.  I got the pan painted and my foam arrived.  Still got some glueing and shaping to do.  Now that I've gotten this far with the seat it looks like I'm going to need some more leather.
Also, took the family to the art museum for a "Sculpted in Steel" exhibit.  Mostly Art Deco cars, but they had this cool old Henderson with the in line four.
Bud
Re: CB750 K4 Build
« Reply #252 on: March 22, 2016, 04:37:40 PM »
That's a very Art Deco Jetson's bike.
Offline budman
  • 1914X
CB750 K4 Build
« Reply #253 on: March 26, 2016, 12:44:44 PM »
Just bought a never-been-used 1974 plate for the bike.  Still has the paper on the back.
« Last Edit: March 26, 2016, 05:41:51 PM by budman »
Bud
Re: CB750 K4 Build
« Reply #254 on: March 26, 2016, 01:37:46 PM »
Nice touch.
FYI - if you register as an antique vehicle, no need for annual inspection [and unsightly sticker]
Offline budman
  • 1914X
Re: CB750 K4 Build
« Reply #255 on: March 26, 2016, 01:46:36 PM »
Nice touch.
To run the plate I'll have to register it as an antique or a classic.  I think you still have to have it inspected as a classic and you can ride it anywhere/anytime vs. limited use as an antique...which from what I have heard isn't really enforced.  They don't do the sticker anymore on anything.  It's all in the system.
Bud
Re: CB750 K4 Build
« Reply #256 on: March 26, 2016, 01:49:50 PM »
Nice touch.
It's def not enforced, but unless being used as a daily rider, you can always just say you are "testing" it or headed to a Rally.  I always register as an antique, the plate is good for 5 years [but prorated] and only $60.
Offline budman
  • 1914X
CB750 K4 Build
« Reply #257 on: March 26, 2016, 04:13:23 PM »
Good to know, Steve.
On another note, I now have one rebuilt oil pump.
« Last Edit: March 26, 2016, 05:40:41 PM by budman »
Bud
Offline budman
  • 1914X
Re: CB750 K4 Build
« Reply #258 on: March 28, 2016, 05:22:04 PM »
I've run into a little predicament.  The engine I bought was running an oil cooler and there's a threaded adapter mounted in the lower case.  The problem is the adapter has splines on it where it goes into the case.  I bought a chrome one piece oil filter with an adapter that screws into the case, but obviously I won't be able to use it if I can't get the other adapter out.  There's a second part to the oil cooler adapter that holds the oil cooler housing on that has a big nut on one end.  I don't know if I should try to get that oil cooler adapter out of the case with some vise grips or not.  I don't know how far the splines go into the case and how bad the threads are screwed up.  I wasn't planning on running an oil cooler.  I could plug the holes in the oil cooler housing and use the chrome oil filter I bought, but it's going to stick out an inch.  Anybody have any experience with an oil cooler adapter like this?
« Last Edit: March 28, 2016, 05:24:55 PM by budman »
Bud
Offline budman
  • 1914X
CB750 K4 Build
« Reply #259 on: March 28, 2016, 06:09:07 PM »
I panicked too soon.  I zoomed up on the photo I took and the splines looked shallow.  I was able to remove the adapter by tapping it with a screwdriver and a hammer on the edge of the ID.  It came out real easy.  I've never seen an adapter like that before.  The threads in the case look fine and the chrome oil filter will screw right on with no cooler housing.
« Last Edit: March 28, 2016, 06:11:44 PM by budman »
Bud
Re: CB750 K4 Build
« Reply #260 on: March 28, 2016, 06:24:18 PM »
I haven't seen me of those before, Bud. Glad it worked out.
Offline budman
  • 1914X
Re: CB750 K4 Build
« Reply #261 on: March 28, 2016, 06:32:03 PM »
Yeah, it's weird.  I was looking at some other oil coolers online and all of them had a one piece adapter that held the housing in place.   The splines had me worried.
« Last Edit: March 29, 2016, 06:24:07 AM by budman »
Bud
Offline budman
  • 1914X
Re: CB750 K4 Build
« Reply #262 on: April 02, 2016, 04:38:43 PM »
I decided since I was this far along I might as well split the cases.  My engine stand brackets worked great for flipping the engine over.  A few blocks of wood to support it and it's sitting just right.  Everything looks pretty good in there.
I should have my cylinders and head back on Wednesday.  I sent them out to be rebuilt.  The cylinders needed to be bored so that means new 1 over pistons.  I'm getting a new primary chain tensioner too.
Also been working on shaping the seat foam.  Gonna try and work on that some more tomorrow.
Bud
Re: CB750 K4 Build
« Reply #263 on: April 02, 2016, 07:57:59 PM »
Seat looks great, Bud.
Offline mystic_1
  • 1970 CB750K
Re: CB750 K4 Build
« Reply #264 on: April 03, 2016, 08:32:21 AM »
Looking good, glad you decided to go the rest of the way!   ;D
Motor stand adapter works well indeed.  Sell a few sets to fund you build!  8)  Looks like when the engine is flipped like that, it ends up at a nice height for working on while standing.
Your internals look to be in good shape from what shows in the pics.  Sludge isn't even all that bad.
mystic_1
- John Augustus Shedd
Offline budman
  • 1914X
Re: CB750 K4 Build
« Reply #265 on: April 03, 2016, 02:29:52 PM »
mystic_1
Yeah, it's pretty clean.  Just a thin layer of grime inside the cases for the most part.  There was some thick stuff in the oil pan, but it's gone now.
With the cases spilt and up side down the work height on the stand is just about perfect for me while standing.  I'm 6' tall.  With the engine in normal position I sit on a stool I'm good.  The height is adjustable though.
« Last Edit: April 05, 2016, 09:51:10 AM by budman »
Bud
Offline budman
  • 1914X
Re: CB750 K4 Build
« Reply #266 on: April 06, 2016, 06:11:18 PM »
Got my head and cylinders back today.  New pistons too.
Bud
Re: CB750 K4 Build
« Reply #267 on: April 06, 2016, 06:36:16 PM »
Beautiful
Offline budman
  • 1914X
Re: CB750 K4 Build
« Reply #268 on: April 06, 2016, 07:06:31 PM »
Sadly I won't be able to do much work on it for a few weeks.  Got family coming in town this weekend and planning a ride next weekend. :-\
Bud
Offline budman
  • 1914X
CB750 K4 Build
« Reply #269 on: April 12, 2016, 06:44:02 PM »
Got the cylinders painted.  I had to bust out the airbrush to get way down in there, in between the fins.
« Last Edit: April 12, 2016, 06:49:00 PM by budman »
Bud
Re: CB750 K4 Build
« Reply #270 on: April 12, 2016, 06:53:50 PM »
What paint ya use, Bud?
Offline budman
  • 1914X
Re: CB750 K4 Build
« Reply #271 on: April 12, 2016, 07:00:23 PM »
PPG acrylic urethane over their epoxy primer.
Bud
Re: CB750 K4 Build
« Reply #272 on: April 12, 2016, 08:27:32 PM »
Will that handle the heat? I just painted my motor with Duplicolor engine enamel.
Offline budman
  • 1914X
Re: CB750 K4 Build
« Reply #273 on: April 12, 2016, 09:13:35 PM »
Yep, better than the rattle can stuff.  Engines get painted with acrylic urethane all the time.
Bud
Offline budman
  • 1914X
Re: CB750 K4 Build
« Reply #274 on: April 15, 2016, 05:37:14 PM »
I spent way too much time trying to find an adapter for an oil pressure gauge.  The one that came on the engine was aluminum and chewed up.  I could have bought a factory plug, drilled and tapped it, but they're aluminum too.
The first adapter I bought I some how ordered the wrong size.  I was able to return it.  The second one I ordered was out of stock.  Finally got the third one right.  Got it off eBay and its steel.
Bud
