Author Topic: CB750 K4 Build - The Cafe Tracer  (Read 118822 times)
Offline budman
  • 1914X
    • LeCompte Electric Bass
Re: CB750 K4 Build
« Reply #475 on: December 11, 2016, 11:48:28 AM »
The Harley cables witj the loop end up top, should last forever..
Yep, that's what I'm using.  Dang near bullet proof.
Bud
1973 CB750K3 Chopper
2021 Indian Scout
Offline budman
  • 1914X
CB750 K4 Build
« Reply #476 on: December 26, 2016, 06:23:53 PM »
I need a little help/advice.  I've been working on the clutch and maybe I'm not understanding something right.  I've assembled the clutch and got the cable adjusted.  The lever that's on the part of the disengagement mechanism that's mounted on the clutch cover is working properly when I squeeze the clutch lever on the handlebars.  I can see the shaft move inwards, which I'm pretty sure is making the clutch lifter plate move, disengaging the clutch.  But when I squeeze the lever at the handlebars when the engine is in gear I'm not able to spin the sprocket on the engine by hand in any gear.  The sprocket should spin freely when in gear with the clutch disengaged, correct?  Say I wanted to push start the bike...put it in gear, pull the clutch in, push the bike, pop the clutch and it starts.  But the way it's acting now it doesn't seem like I would be able to do that.  Maybe it takes more leverage to turn the sprocket by hand when in gear and the clutch disengaged?  I've assembled and disassembled the clutch at least a dozen times using parts from two engines.  The clutch is a new Barnett clutch.  I tried the old stock springs.  It's as if the clutch is not disengaging, but I'm 99% sure it is.  The engine shifts smoothly in all gears.  Maybe I'm just not understanding.
« Last Edit: December 26, 2016, 06:26:48 PM by budman »
Bud
2021 Indian Scout
Offline Medyo Bastos
  • Gusto mo titi ko?
    • project
CB750 K4 Build
« Reply #477 on: December 26, 2016, 07:19:01 PM »
Is this a stock, or aftermarket lever? Some aftermarket levers do not have enough travel. BLAHHHHH, just read earlier posts...
How longs it been since this motor has run? Can you shift gears if you rock the bike back and forth?
The clutch pack may be stuck. I can tell you how to break it loose if you find this is your problem
« Last Edit: December 26, 2016, 07:20:56 PM by Medyo Bastos »
Offline budman
  • 1914X
CB750 K4 Build
« Reply #478 on: December 26, 2016, 08:55:23 PM »
The plan is to use an aftermarket lever, but I thought I wasn't getting enough travel so I've been working with a stock lever and have the same problem, or perceived problem, with both levers.
I rebuilt the engine and it hasn't been run yet.  The clutch is new and was soaked in oil.  I don't think it's stuck.  The clutch pack disengages easily without the lifter plate and springs installed, meaning I can pull or push on the rear basket from the four female threaded posts.
I don't have a chain on the bike yet, so rocking it back and forth wouldn't help right now.  All I can do is grab the sprocket on the engine and try to move it that way.
Bud
2021 Indian Scout
Offline budman
  • 1914X
Re: CB750 K4 Build
« Reply #479 on: December 27, 2016, 05:52:09 AM »
I might add that without the clutch pack installed the clutch shaft will spin when in gear and I rotate the sprocket, which indicates to me that the tranny is put together correctly.  I think that when the clutch is installed and the clutch pack is disengaging the fibers and steels (even though they are oiled up) are sticking together via suction or something.
Bud
2021 Indian Scout
  • Gusto mo titi ko?
    • project
Re: CB750 K4 Build
« Reply #480 on: December 27, 2016, 07:16:23 AM »
correct, they do stick sometimes.  put a chain on it and see if you can rock it back and forth and shift through all gears.  if you can, start the bike up in 1st gear without pulling the lever in.  just hang on, the bike will roll as you turn the key.  ride it a bit, they will free up.
Offline budman
  • 1914X
Re: CB750 K4 Build
« Reply #481 on: December 27, 2016, 07:39:50 AM »
Thanks for the advice.  I still have some things to do before it's ready to start.  Still need an exhaust and I have to rebuild the carbs.  I'm going to tie down the clutch lever and see if I can rock the sprocket with some leverage.
Bud
2021 Indian Scout
Offline budman
  • 1914X
Re: CB750 K4 Build
« Reply #482 on: December 31, 2016, 02:31:55 PM »
Look like I'm going to have to get some different shocks
Bud
2021 Indian Scout
Re: CB750 K4 Build
« Reply #483 on: December 31, 2016, 03:48:30 PM »
Bud,
What shocks are those?
Offline budman
  • 1914X
Re: CB750 K4 Build
« Reply #484 on: December 31, 2016, 05:13:33 PM »
Bud,
YSS.  I bought them two years ago.  I thought I might have problems with them.  I don't think YSS has any US Distributors anymore and I can't find this shock on their website.
Bud
2021 Indian Scout
Offline markreimer
Re: CB750 K4 Build
« Reply #485 on: January 01, 2017, 02:23:31 PM »
Bummer. I put a YSS shock on a BMW airhead I had a couple years back. After less than 100 miles the rubber bushing in the mounting eyelette disintegrated. I was on a tour no less, and had to jerry rig a temp fix while they overnighted a new one to me....which promptly failed the same day. The shop I bought it from gave me a deal on a new Wilbers shock and told me to throw the YSS off a cliff.
.....So maybe you dodged a bullet there?
Offline budman
  • 1914X
Re: CB750 K4 Build
« Reply #486 on: January 01, 2017, 03:40:02 PM »
Well, that ain't no good.  Sorry to hear that.
I paid a pretty good chunk of change for these shocks.  They don't even have 1 mile on them, but since I've had them for two years it's doubtful I can get my money back.  The seller doesn't even carry YSS anymore.
These were obviously engineered upside down.  I thought I might have trouble with the sprocket plate hitting the spring perch with the wheel all the way in the forward position, and I was prepared to take a little off the O.D. of the sprocket plate.  But until I actually tried to install a chain I wouldn't know.  Well, it took me two years to put a chain on the bike and it never occurred to me in all that time that the chain might actually rub up against the spring.
I'll probably write to the seller and see if there's anything they can do.  Can't hurt.  In the mean time I've got new shocks headed this way.
Bud
2021 Indian Scout
Offline calj737
  • I refuse...
Re: CB750 K4 Build
« Reply #487 on: January 01, 2017, 04:02:17 PM »
Hey Bud, what are the specs on those? I may have an application for them on one of my bikes and be willing to buy them from you.
Offline budman
  • 1914X
Re: CB750 K4 Build
« Reply #488 on: January 01, 2017, 04:13:54 PM »
All I have is this from when I ordered them:  YSS E-302 330mm Eye/Clevis Twin Shocks 69-80 CB750 (MM-E-302-330EC-CB750)  If there's a specific dimension your wanting to know I can measure it.  They might work on a bike that utilizes a small rear sprocket.
I paid almost $300 for them.  I just wrote to the retailer who I bought them from, whom it appears no longer carries YSS products.
Bud
2021 Indian Scout
Offline calj737
  • I refuse...
Re: CB750 K4 Build
« Reply #489 on: January 01, 2017, 04:22:25 PM »
I'd take them, but at 13", they're too short for my use. Sorry, Dude. I mean, Bud.  :)
Offline budman
  • 1914X
Re: CB750 K4 Build
« Reply #490 on: January 01, 2017, 05:10:33 PM »
No problem.
Bud
2021 Indian Scout
Re: CB750 K4 Build
« Reply #491 on: January 02, 2017, 06:22:28 PM »
A buddy had these on his CB400F. Not very good.  The back end was pogoing.
Offline budman
  • 1914X
Re: CB750 K4 Build
« Reply #492 on: January 04, 2017, 03:57:44 PM »
One of the last pieces of the puzzle.  Hope it fits.
Bud
2021 Indian Scout
Re: CB750 K4 Build
« Reply #493 on: January 04, 2017, 04:01:27 PM »
Sorry to hear about the shocks, Bud.  Consider Ikons, member Nobelhops is now the U.S distributor.
What exhaust?
Offline Davez134
Re: CB750 K4 Build
« Reply #494 on: January 04, 2017, 05:20:15 PM »
Looks like the yoshi replica from Yamiya
Offline budman
  • 1914X
Re: CB750 K4 Build
« Reply #495 on: January 04, 2017, 06:42:55 PM »
What exhaust?
I've got some shocks coming.  I had to compromise a little due to finances.  If they turn out to be junk I'll look at upgrading to Ikons.
The exhaust is a Yamiya as Dave stated.
Bud
2021 Indian Scout
Offline budman
  • 1914X
Re: CB750 K4 Build
« Reply #496 on: January 04, 2017, 07:19:08 PM »
I'm really impressed with the chrome job.
Bud
2021 Indian Scout
Re: CB750 K4 Build
« Reply #497 on: January 04, 2017, 08:07:24 PM »
I love the smooth bends of that Yamiya Yosh replica.
Offline budman
  • 1914X
Re: CB750 K4 Build
« Reply #498 on: January 05, 2017, 05:48:14 AM »
Me too.  Kind of funky looking, but I think it will go with my build.
Bud
2021 Indian Scout
Re: CB750 K4 Build
« Reply #499 on: January 05, 2017, 06:52:48 AM »
+1...first thing that came to mind when I saw it. Cant wait to hear it, Bud.
