Author Topic: CB750 K4 Build - The Cafe Tracer  (Read 121445 times)
Offline budman
  • 1914X
    • LeCompte Electric Bass
Re: CB750 K4 Build
« Reply #500 on: January 16, 2017, 12:40:13 PM »
Seems when we do these "rebuilds" for a hobby, it takes much longer than anticipated, especially when we have other ridable bikes!
Plus we're old.
Bud
1973 CB750K3 Chopper
2021 Indian Scout
Offline budman
  • 1914X
Re: CB750 K4 Build
« Reply #501 on: January 21, 2017, 03:22:19 PM »
I finally made a license plate frame.
Also got the front brake line sorted out.  Piece of cake connecting the Harley style master cylinder to the front caliper with the right adapter.  Just need to ad fluid and bleed.
I ordered the custom throttle cables and the custom clutch cable from Motion Pro this week.  The clutch cable is just basically a short Harley clutch cable.  The throttle cables are Harley on the throttle end and Honda on the carb end.  Spent a lot of time working out the measurements and sent some detailed drawings to Motion Pro.  They said they could make the cables, no problem.  I might have them next week.
I also got my carb rebuild kits and a jet kit this week.  I need to do some homework before I dive in.
The only major parts left to buy are the air box and the fuel petcock.
Just some minor paint and polishing work and some minor assembly left to do.  I hope I can fire it up in about four weeks.
Bud
2021 Indian Scout
Re: CB750 K4 Build
« Reply #502 on: January 22, 2017, 09:22:31 AM »
What kind of carb kits, you buy, Bud? I'm sure you've heard the warning of cheap aftermarket kits.
Offline budman
  • 1914X
Re: CB750 K4 Build
« Reply #503 on: January 22, 2017, 11:24:27 AM »
I don't know who makes the kits, but I got them from 4into1.com.  I didn't cheap out.
I also got a jet kit, supposed to be specific to my spec's.
Bud
2021 Indian Scout
Offline budman
  • 1914X
Re: CB750 K4 Build
« Reply #504 on: January 28, 2017, 09:10:41 PM »
Tried my hand at zinc plating.  All the small carb parts needed some help.  I derusted everything first with Metal Rescue.  Pretty pleased with the results.
Before.
After.
Bud
2021 Indian Scout
Offline MauiK3
  • A K3 is saved
  • Old guy
Re: CB750 K4 Build
« Reply #505 on: January 30, 2017, 02:27:06 PM »
Wow, what a great build. I'm more or less an "enhanced stock" kind of guy but this is really great. Did you put together your own zinc kit?
Again, really nice bike.
Steve
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline budman
  • 1914X
Re: CB750 K4 Build
« Reply #506 on: January 30, 2017, 07:55:54 PM »
Steve
Thanks, Steve.  I looked at some zinc plating kits, but they were kind of expensive considering I had everything I needed around the house minus the zinc ingots.  I bought a couple of ingots for $12 off of EBay.  Way more zinc than I needed.  I just cut off a couple of chunks and I'll save the rest for another day.  Pretty simple process.
Bud
2021 Indian Scout
Offline budman
  • 1914X
CB750 K4 Build
« Reply #507 on: February 04, 2017, 02:48:02 PM »
It's the little things that get you.
I had to make a small pin because I drilled out the carb rack in order remove the throttle rod so I could clean up and re-plate all the linkage.  Got the idea from the Hackaweek vids.
I also had to make a new collar that goes on the throttle rod.  I seemed to have misplaced the original.  I can't remember if I zinc plated it or not.  The plan was to have the carbs mounted on the bike today, but not sure it's going to happen.  I'm zinc plating the new collar at the moment and it takes a while.
« Last Edit: February 04, 2017, 08:11:37 PM by budman »
Bud
2021 Indian Scout
Offline budman
  • 1914X
Re: CB750 K4 Build
« Reply #508 on: February 04, 2017, 07:45:10 PM »
Any chance you filled that little notch you got in the rod, from drilling the old pin out?
If not; your new pin may get caught in there and lock up your throttle.
Nah.
Bud
2021 Indian Scout
Offline budman
  • 1914X
Re: CB750 K4 Build
« Reply #509 on: February 04, 2017, 07:46:17 PM »
Just about ready to install on the bike.
Bud
2021 Indian Scout
Offline budman
  • 1914X
CB750 K4 Build
« Reply #510 on: February 05, 2017, 04:42:02 PM »
Installed the carbs, but I have to take them back off.  I forgot to install the four washers that go on the choke linkage before the small cotter pins.
« Last Edit: February 05, 2017, 04:44:27 PM by budman »
Bud
2021 Indian Scout
Offline WesTenRacing
Re: CB750 K4 Build
« Reply #511 on: February 06, 2017, 07:20:00 AM »
I've been following this build since I joined the forum.  Very nice job!  I look forward to the maiden voyage.
Offline budman
  • 1914X
Re: CB750 K4 Build
« Reply #512 on: February 06, 2017, 08:09:43 AM »
Thanks. I'm looking forward to the maiden voyage too.
Bud
2021 Indian Scout
Offline budman
  • 1914X
Re: CB750 K4 Build
« Reply #513 on: February 06, 2017, 03:21:02 PM »
My custom cables arrived.  Sure hope they fit.  Only one way to find out.
Bud
2021 Indian Scout
Offline budman
  • 1914X
Re: CB750 K4 Build
« Reply #514 on: February 11, 2017, 05:48:11 PM »
For the most part the cables worked out.  I had to send the push cable back and have a little bit a free play added.  It was about 10mm too short.
Today I sprayed the final coats of clear on the wooden tail section.  Next weekend I'm going to cut and polish the tank and tail section.
The carbs are pretty much ready to go.  Just waiting on a tee so I can hook up the fuel line.  I ordered an Airbox from Cognito Moto.  Hopefully I'll have it next week.
I had to take the CB750 off the lift today so I could install a new starter in my Chobber.  The CB750 looks so much better on the ground.  Can't wait to ride it.
Bud
2021 Indian Scout
Offline palepainter
    • Mike Learn custom paint and airbrush.
Re: CB750 K4 Build
« Reply #515 on: February 17, 2017, 07:55:12 PM »
Oh ya.... Looking so sweet.  What tank did you start with?  IT is going to be a sweet scoot.
Offline budman
  • 1914X
Re: CB750 K4 Build
« Reply #516 on: February 17, 2017, 09:50:30 PM »
Thanks.  It's a heavily modified Suzuki GT750 tank.  1975 I think.
Bud
2021 Indian Scout
Offline budman
  • 1914X
Re: CB750 K4 Build
« Reply #517 on: February 18, 2017, 02:06:13 PM »
Shiny!
Bud
2021 Indian Scout
Offline budman
  • 1914X
CB750 K4 Build
« Reply #518 on: February 18, 2017, 03:19:19 PM »
Major milestone.  Just put oil in the bike, hooked up the starter wire, turned the key on and hit the start button.  So smooth.  Only thing better would be to put gas in it and hear it run.  Soon!
« Last Edit: February 18, 2017, 04:55:39 PM by budman »
Bud
2021 Indian Scout
Offline budman
  • 1914X
Re: CB750 K4 Build
« Reply #519 on: February 18, 2017, 04:03:35 PM »
Bud
2021 Indian Scout
Re: CB750 K4 Build
« Reply #520 on: February 18, 2017, 05:15:12 PM »
A shot of the tank here, a shot of the tail there, in my day you'd be called a "Pr1ck teaser".... ;D ;)
Offline budman
  • 1914X
Re: CB750 K4 Build
« Reply #521 on: February 18, 2017, 05:24:00 PM »
Hold on to your ying yang.  You'll see a finished bike at some point.
Bud
2021 Indian Scout
Offline budman
  • 1914X
Re: CB750 K4 Build
« Reply #522 on: February 23, 2017, 07:28:48 PM »
After some futzing I have a slightly modified Cognito Moto airbox that fits.
Bud
2021 Indian Scout
Offline markreimer
Re: CB750 K4 Build
« Reply #523 on: February 23, 2017, 08:24:57 PM »
Oh I like how that looks!!
Re: CB750 K4 Build
« Reply #524 on: February 24, 2017, 05:08:15 AM »
Shiny!
Simply beautiful, Bud!
What main jets do you plan to use with that airbox and exhaust?
What else is needed to fire her up?!
