Author Topic: BENT fork tubes...  (Read 699 times)
Offline tfrasca
    • CB550 Project
BENT fork tubes...
« on: September 14, 2014, 01:04:12 PM »
It's one thing after the other with this bike! After several attempts to get my triple trees aligned, I pulled my fork legs out to confirm my suspicion that they were bent. Damn...
I guess this little project is going to be more in-depth than I'd originally planned. After looking around, I found these Japanese fork tubes on eBay. Anyone have any experience with them?
http://www.ebay.com/itm/75-76-HONDA-CB550F-SUPER-SPOT-FRONT-FORK-TUBE-INNER-SET-2TUBES-CI-CB550FFTS-1-/131087561952?pt=Motorcycles_Parts_Accessories&hash=item1e856d74e0&vxp=mtr
Budget is tight, but I obviously don't want to die when my cheap fork tubes shear off.
TF
Offline MoMo
  • Ride like you're invisible
Re: BENT fork tubes...
« Reply #1 on: September 14, 2014, 01:10:51 PM »
As long as the metal is not creased fork tubes can easily be straightened with a hydraulic press and a bit of patience. Cannot tell you how many times bent tubes were straightened at the various shops I worked...Larry
Offline calj737
  • I refuse...
« Reply #2 on: September 14, 2014, 01:20:20 PM »
Straightening them is an option. The only thing I would point out to you is these forks are for the Super Sport. Be sure your lowers and forks are for a Super Sport because they differ just slightly by numerous reports.
Offline tfrasca
    • CB550 Project
« Reply #3 on: September 15, 2014, 12:13:25 PM »
Upon further inspection, I noticed a very bent steerer tube (where it's pressed into the lower triple), and severe pitting right above the seals on the fork tubes. Needless to say, this fork needs to go away. I bought a straight, clean-ish used fork off a member here. (Thanks Nick!)
Thanks for all the advice.
TF
Offline calj737
  • I refuse...
« Reply #4 on: September 15, 2014, 12:57:10 PM »
Did you find a replacement lower tree with a straight stem too?
Offline tfrasca
    • CB550 Project
« Reply #5 on: September 15, 2014, 01:04:55 PM »
Yes, I bought an entire used fork. Upper and lower triples, fork tubes and lowers. Pretty clean, just needs seal and a rebuild. I checked out the frame for damage, assuming the bike had been run into a wall at some point, but everything looks straight.
TF
Offline Hannibal Smith
  • 3rd Grade Dropout
« Reply #6 on: September 15, 2014, 03:56:31 PM »
At least it wasn't a bent Kawi fork, they are mongrels to work with.
Follow my build "P38 Racer" in Project section
