Author Topic: Oil line fitting available cb750  (Read 3724 times)
Offline atm cycles
« on: September 18, 2014, 01:54:47 PM »
Is there a source for new engine end oil line fittings ?
Re: Oil line fitting available cb750
« Reply #1 on: September 18, 2014, 02:05:33 PM »
CycleX makes them I think.
http://www.cyclexchange.net/Oil%20System%20Comp%20Page.htm
More like adapters than replacements though.
Offline bjbuchanan
« Reply #2 on: September 18, 2014, 03:57:08 PM »
They have 'replacements' that aren't as internally large, gimmicky IMO. If your hoses leak just get a set from one of us members, they rarely leak. I use black spray paint to freshen the fabric cover so they don't look dingy and gray anymore. Others use fabric dye but that is overkill IMO and doesn't work all that great anyway
Offline atm cycles
« Reply #3 on: September 18, 2014, 04:06:47 PM »
Was looking to make my own out of copper or something to go on the sacrilegious Rat Racer  I'm workin on.
Offline bjbuchanan
« Reply #4 on: September 18, 2014, 05:29:23 PM »
Probably not a great idea because it will most likely crack in a short amount of time from vibration. Gonna have to be function before form in this case
Offline goldarrow
  • one day, i'll be an
« Reply #5 on: September 18, 2014, 05:43:45 PM »
If you need oil lines, I have a spare set of stock ones
CB550 K0
Offline atm cycles
« Reply #6 on: September 18, 2014, 05:50:43 PM »
Thanks!!! I have plenty. Just doin something different with this one. I see stainless lines and wonder how they're made if someone isn't making new factory type fittings.
« Reply #7 on: September 18, 2014, 06:08:08 PM »
I make my own from SS hose, reusing original fittings.
The threads at the tank are M22 and M24?  Not that easy and common to find tooling for that.
Offline atm cycles
« Reply #8 on: September 18, 2014, 06:12:45 PM »
Really!! Do you have thread in tip n tricks or anything like that???? How to take apart without damage and reusing. I'd like to see that!!!
« Reply #9 on: September 18, 2014, 08:31:18 PM »
When assembling the Amen and other chopper frames, we cut off the fabricpart, then welded on an AN fitting.... A -6 or -8.=
Offline bjbuchanan
« Reply #10 on: September 18, 2014, 09:34:38 PM »
The stainless is a sleeve, stainless braided, not solid like copper lines...
Offline spiffy587
« Reply #11 on: September 19, 2014, 12:19:57 AM »
Grind off the crimped portion and it has a barbed fitting then use rubber hose.
« Reply #12 on: September 19, 2014, 04:18:49 AM »
I use hacksaw to cut through the crimped ferrule.  Hoses from hydraulic shop - the pressure is very small, but the hose needs to be able to handle hot oil - and ferrules from McMaster Carr:
http://www.mcmaster.com/#hose-ferrules/=tsf4j9
The crimp easiest is to find a shop that will crimp it for you.  Only one of the hoses needs to be indexed - i.e. ends have to be in certain position against each other.
Offline bjbuchanan
« Reply #13 on: September 19, 2014, 09:44:35 AM »
My house doesn't roll around much with a hard mounted engine so I can't compare notes but I still think it is a lousy idea.
Bikes with this kinda stuff on it usually don't get ridden anyway so it shouldn't matter in the end huh ::)
« Reply #14 on: September 19, 2014, 09:56:49 AM »
He could adapt these hoses:
 ;D
For some reason I think the rigid copper tubing would do just fine as oil lines; I used copper for air distribution in my shop and it is holding up well even the connection to the compressor.
But it would be a pain to install.
Edit:  I just remembered, the oil pressure gauge in my jeep is hard connected to the engine by copper tube.  I installed it many years ago, because it is more reliable than electrical pressure sensor and electrical gauge. The tube goes from engine to the dash and as I said it works without issues for 15 years now.
« Last Edit: September 19, 2014, 09:59:39 AM by 70CB750 »
Offline atm cycles
« Reply #15 on: September 19, 2014, 10:00:16 AM »
Nonferrous metals do work harden. If annealed it would work fine on a motorcycle or car. As for riding hope that wasn't aimed my way.
Offline AbbyRider
« Reply #16 on: September 20, 2014, 11:24:00 PM »
I've seen lots of examples of copper being used for oil lines. Wrenchmonkees have used it on a few of their builds.
'98 VTR1000 Superhawk
'78 CB750F
'77 CB750F (in the works)
'81 KZ650 sitting in pieces in my basement
Offline atm cycles
« Reply #17 on: September 21, 2014, 04:03:07 AM »
So nobody makes replacement fittings ?? Seems there would be a market. So many after market parts for these bikes I m a little surprised
