Author Topic: Increasing mileage on mechanical odometer?  (Read 1251 times)
Offline eideteker
« on: September 19, 2014, 01:21:39 PM »
Preamble: this does not have anything to do with odometer fraud, please read on!
I want to use this old Suzuki Hustler gauge (like this) on my CB500, but the mileage is way less than what the bike actually has on it.  I know I can go mileage exempt but I'd really like to have the odometer reflect the "true" mileage.  Is there any way to set it to a higher mileage?  I already have the gauge apart and spinning with a drill bit (but that's going to take ages and I'd rather not put the wear on the instrument or my drill).  Any ideas?
"Spit on the tip of your finger, lube the inside of the hole, and then wiggle it around and twist a bit back and forth as you apply pressure." - mystic_1
1973 CB500K - not bad for a first bike
2009 SFV650 - torquey, reliable 90° V-twin
Offline brandEn
« Reply #1 on: September 19, 2014, 01:26:52 PM »
Gonna have to take it apart and roll em forward. I have done it with 750 gauges. Probably about the same thing. I am curious how that will work it's a cool gauge.
Offline eideteker
Re: Increasing mileage on mechanical odometer?
« Reply #2 on: September 19, 2014, 01:33:13 PM »
Yeah it is cool, that's why I'm so set on using it.  8)
How do I go about moving the numbers?  Like I said, I have the odometer part out and I'm increasing the mileage very slowly at the moment...
Offline eideteker
« Reply #3 on: September 19, 2014, 01:38:51 PM »
Obligatory bikes pic, just because...
Offline brandEn
« Reply #4 on: September 19, 2014, 01:43:54 PM »
Looks like that little tab on top where the needles mount, ya need to pry that thing loose from the crimps and then CAREFULLY loosen things up until you can roll the numbers freely. I did this and then used 2 part epoxy to hold the crimps back in place.
Offline faux fiddy
  • bike in a box
« Reply #5 on: September 20, 2014, 01:24:21 AM »
Heck, just hook it up and ride the snot out of it, the mileage will increase.
^^^^^^^/l^^^^^^^^^^^^^^/l^^^
Offline eideteker
« Reply #6 on: September 20, 2014, 09:25:54 PM »
Will wheelies make my mileage increase faster?
Offline brandEn
« Reply #7 on: September 20, 2014, 09:30:43 PM »
Actually no...
lol
Offline eideteker
« Reply #8 on: September 20, 2014, 09:52:40 PM »
 ;D
But seriously, I took another look at the odometer assembly and I don't see the part you are referring to...I guess I just don't know what I'm looking for.
Offline wowbagger
  • Not much of an
« Reply #9 on: September 21, 2014, 04:26:42 PM »
I did this exact thing with and early cb77 Superhawk gauge on my cb500. Branden had it right. Remove the retainer clip on the end. Then, separate the wheels, spin them to the desired reading, realign and replace the lock clip.
« Reply #10 on: September 21, 2014, 05:12:48 PM »
X6 does have cool gauge, that was my first bike.  250cc twin and would do 100 mph.
Offline eideteker
« Reply #11 on: September 21, 2014, 06:00:47 PM »
I'll take another look tomorrow, thanks.
Cool!  Yeah I've heard that they were bad little bikes, but I definitely love the gauge.  Only thing I'm sweating is the ratio, I've searched all over and couldn't find the Suzuki speedo ratio for the X6 and whether it matches the Honda or not.  I know another member used the X6 gauge on his 750 (I think?) and had a member (count_Chockula) redo the face for him.
