Author Topic: Reverse Gear  (Read 1622 times)
Offline birdmannn101
  • My Fixerupper 73 CB750K3
Reverse Gear
« on: September 20, 2014, 01:00:14 PM »
Finally got this 76 CB750A with a 78 wire harness and 78 indicator running after cleaning the carbs.  I asked earlier if the rear wheel spun in Neutral and some people said, "Yes."  It starts in Neutral with the side kickstand down.  Wheel spins and can't be stopped with your foot.  Apply gas and the wheel spins faster (like it might be in "L" gear).  Raise side stand and pull shift lever up and it goes into "L" and the wheel stops.  Add throttle and wheel stays stationary.  Pull shift lever up again and it goes into "H" gear, wheels starts spinning and will go faster if you add throttle.  Drop the side stand and it goes back to Neutral and wheel keeps spinning.
CB110
CB160
CB750K
CB750A
S90
CB350Four
CT200
C100
C102
VTX1300
Re: Reverse Gear
« Reply #1 on: October 10, 2014, 11:15:00 AM »
Since I didn't get any help from the group I decided to take another look at this.  This wheelchair bound, handicapped person who owned this bike before me changed the manual valve around so that he could start the bike (in neutral) and drive off (in low) without touching the shift pedal.  So, I will pull the left engine cover and see if I can see what he changed on the master cylinder.
CB110
CB160
CB750K
CB750A
S90
CB350Four
CT200
C100
C102
VTX1300
