Author Topic: '71 750 K1 W/7A Carbs T-tube Leaking AND The fuel bowl drain plug stripped  (Read 388 times)
Offline andys71k1
The fuel supply t-tube between #3 and #4 is leaking.
 - Are the o-rings for the t-tubes included with the Carb kits?
 - Are the o-rings a standard size that can be purchased separately?
 - Are the inner and outer o-rings different sizes?
Fuel bowl drain plug.
 - The head of the plug is stripped. Are replacements available?
Offline harisuluv
Re: '71 750 K1 W/7A Carbs T-tube Leaking AND The fuel bowl drain plug stripped
« Reply #1 on: September 23, 2014, 01:12:15 PM »
 - Are the o-rings for the t-tubes included with the Carb kits?   Depends on what kit you get.
 - Are the o-rings a standard size that can be purchased separately?  Yes, the fuel T rings are 2mm x 8mm.  I find 1.9 x 7.8 fits a little more snug.
 - Are the inner and outer o-rings different sizes?  No.
 - The head of the plug is stripped. Are replacements available?  Some places make repops.  If it's stripped, you should first see if you can get it out.  Use vice grips, you are planning on replacing it anyways right?  The reason is, if it is stuck in there or breaks off, you need a new bowl probably too unless you are lucky with an extractor.
If you want all the stuff you mentioned pm me and I can help you out with it.
Offline andys71k1
« Reply #2 on: September 23, 2014, 01:40:57 PM »
Thanks for the reply. I'll send you an e-mail.
