Author Topic: New Tappet cover Wrench  (Read 1453 times)
« on: September 25, 2014, 03:02:33 pm »
 I designed this after hearing of, broken and rounded off tappet covers.
 I felt that if was installed with a shorter wrench, less likely to overtorque the nuts.
Take a look, see what you think.
Offline BPellerine
Re: New Tappet cover Wrench
« Reply #1 on: September 25, 2014, 05:00:44 pm »
looks nice Frank good for getting in the tight spot,ie 2+3 cyls .bill
1978 CB 750K ard and webers
another anfob
Offline Rocky2010
  • Live in Strayla
« Reply #2 on: September 25, 2014, 05:07:04 pm »
Good stuff, yes those caps should't be tightened to much  8)
2010 Harley Fatboy Lo
1972 Honda CB750/4 Under Restoration
1971 Honda CB500/4 Original Condition
1972 Honda CB350/4 Original Condition
1972 Honda XL250 Motorsport Under Restoration
1967 Honda C90 Original Condition
1968 Honda S90
1962 Triumph Speed Twin
1952 Triumph Speed Twin
1970 Bultaco Sherpa T
1971 Bultaco Alpina
1958 Moto Guzzi Zigolo
1970 Moto Guzzi Ambassador Original Cond
1973 Yamaha RD250
1948 Velocette x 2
1942 WLA Harley Davidson
2006 Kawasaki ZX12R (Sold)
1980 Corvette
Offline calj737
  • I refuse...
« Reply #3 on: September 25, 2014, 05:55:03 pm »
What would make that wrench THE bomb is if it had the oil filter wrench on the other end. 2 birds, 1 wrench!
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #4 on: September 26, 2014, 06:44:56 am »
--Evan
1975 CB750K "Rhonda"
Offline AbbyRider
« Reply #5 on: September 26, 2014, 07:48:12 am »
Forget the oil filter wrench. Put a half circle on the other end to open up my beers. Nice work Frank.
'98 VTR1000 Superhawk
'78 CB750F
'77 CB750F (in the works)
'81 KZ650 sitting in pieces in my basement
Offline calj737
  • I refuse...
« Reply #6 on: September 26, 2014, 08:05:48 am »
Suddenly it's becoming a multi-tool!
Offline wowbagger
  • Not much of an
« Reply #7 on: September 26, 2014, 08:14:10 am »
Very nice. I've always just used my stubby handle 3/8" drive ratchet but even then It's possible to crank down too hard.
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #8 on: September 26, 2014, 10:02:48 am »
I think all of the above! Tappet cover, oil filter, and beer opener. I like multi-use tools. Nice looking finish on it too frank.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
« Reply #9 on: September 26, 2014, 11:54:48 am »
It also appears you rotated the HEX slightly so you can flip it over and get a 1/2 flat more travel. I was going to suggest that but when I checked, it was already there. Nice!
Offline Old Scrambler
« Reply #10 on: September 26, 2014, 03:44:14 pm »
Great Idea..............the other end could be a hex to fit on the plug-wrench.........similar torque.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
« Reply #11 on: September 26, 2014, 07:50:20 pm »
It's made out of 6061 aluminum, so use on a steel nut is out, so is bottle opener.
The problem with most sockets. And wrenches is the leading taper to find its way on the bolt easier. This can be up to 2 mm on some tools...this has none.
The hex on the tappet cover is only about 5mm long so losing a mm or two means very little engagement.
« Reply #12 on: September 27, 2014, 02:35:48 am »
good tool frank,you sure you cant get it to open beers?the lead in ramp on sockets can round the caps off easily especially with 12 point types,just get a cheap six point and grind it away so you have a nice square engagement.
« Reply #13 on: September 27, 2014, 07:49:04 am »
If it will open beers, I'm in.  My Craftsman multi point wrench gives me no issues getting the covers off. But not good to open beer bottles!
« Reply #14 on: September 27, 2014, 10:25:21 am »
I never found a wrench that fits nice.
 When you try this, with the nice tight fit, and featherweight,  you won't go back to your steel one.
« Reply #15 on: September 27, 2014, 01:41:38 pm »
you could custom cut forum user names in them for people?
